... but I was interested in the inner structures. Took my machine 2 days to
render at 800x600. I think I have to work on the code...
Original version (800x600) at:
http://www.b0n541.net/povray/pics/mengersponge.jpg (~ 100 KB)
Sheers,
Bonsai
Download 'mengersponge.jpg' (33 KB)
Preview of image 'mengersponge.jpg'
Bonsai wrote:
> [Image]
Needs a mouse :)
Bye,
Pabs
In article <3aa897cd@news.povray.org>, "Bonsai" <bon### [at] b0n541 net>
> to render at 800x600. I think I have to work on the code...
It's too yellow for swiss cheese...
Hmm, I wonder what a semitransparent Menger sponge would look
like...it'd probably take a couple years to render with a decent
recursion level, though. And to get the transparency right, you would
need to use a completely transparent texture and attenuation (fade_color
would be useful).
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
"Chris Huff" <chr### [at] mac com> schrieb im Newsbeitrag
news:chrishuff-913808.06504209032001@news.povray.org...
I never wanted to let it look like cheese. I use the yellow color only for
modelling and testing a new object or shape, because for me it´s good
visible and not too painfull to look at.
> would be useful).
And I want it rendered at 80000x60000 pixels!
Hmmm, let´s wait ´till the 30 GHz processors are available. Then I´ll buy my
own atomic plant and build a big render farm ;-)
Maybe this is a good scene to test the distribute render techniques
currently discussed in povray.general in the large-render-thread. Parsing
time is very short compared to render time (parsing time about 30 seconds,
render time 2 days)
So long,
Bonsai
> would be useful).
Consider rendering a compact subset of R^3 (that is closed and bounded) which
has zero volume but infinite surface area. Thus, it will require infinitely
many recursion levels to trace one single ray accurately through it. And it
would definetely not be transparent, or even semitransparent.
Thus, better and better approximations would tend to a more and more opaque
object which take longer and longer to render. I'd say; skip the
transparency. :)
BTW, the cutaway seems to produce the sierpinsky triangle in the intersection
surface. This might actually be the case!
The menger sponge is actually a generalization of the sierpinsky triangle,
and the s.t. is actually a generalization of the Cantor set. Intuitively, I
think I can see the Cantor set as an intersection between the sponge and some
straight line through it.
Enough rambling, but it _is_ interesting.
~simenkv ( smartass/exessive wiseacre with newly aquired math skills )
"Simen Kvaal" <sim### [at] stress uio no> schrieb im Newsbeitrag
news:3AA8E44A.6218AF06@stress.uio.no...
> Intuitively, I
some
You´re right. But I think there are only a few lines on the surface (like
the red one in the picture below) that represent the Cantor set. Only a
thought...
Download 'cantorset.jpg' (8 KB)
Preview of image 'cantorset.jpg'
There was a thread about this some time (years ?) ago. If I remember well, a
solution for optimising the sponge was to run only a small part of it (a 1/8 or
1/81, for instance), and then to replicate the part as needed. The decrease in
parsing and render time was dramatic.
Hope this helps.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
> render time 2 days)
What computer (how fast) was used to render such picture? Which
algorithm was used? I managed to render menger with same recursion level
and 800x600 (AA0.3) just little over 12 minutes when isosurface was used
(this was when shader was used for calculation, for as it seems, shader
will outperform user's iso functions).
"Gilles Tran" <tra### [at] inapg inra fr> schrieb im Newsbeitrag
news:3AA8FD35.60727F15@inapg.inra.fr...
to
a
1/8 or
decrease in
> Hope this helps.
Yes it did in parts. For the creation of a mengersponge that does not
interact with any other object it is a big increase (now it takes some
minutes to render one at 800x600 with the same complexicity...)
But when I want to do the cut away with a sphere it goes back to the 1 or 2
PPS. From now I can´t say if there is still an increase in rendering speed,
´cause I´m still at work on my 'old and lame' PIII 450 MHz. Can´t wait to
come home and feed my little Athlon with new stuff...
so long and thanks allot,
Bonsai
"Vahur Krouverk" <vah### [at] aetec ee> schrieb im Newsbeitrag
news:3AA90733.A7C66D85@aetec.ee...
Parsing
seconds,
> > render time 2 days)
I wanted to do the sponge in pure csg. So I did a lot of differences, that
resulted in this long rendertime.
Gilles gave me a tricky hint on doing the mengersponge very easy and fast.
My old code is just wasting of electric power and time. :-(
I don´t want to speak about it anymore.
But now I know that my new Athlon works stable even for days...
Bonsai
> PPS. From now I canīt say if there is still an increase in rendering speed,
What about cutting away the (correctly positioned) individual parts first ? It
should render faster than making the union first and cutting the union after.
One fun thing would be to make the sponge out of triangles... I would render
very quickly I guess.
G.
Graphic experiments
Pov-ray gallery
Iīll give it a try this weekend.
But what I know from triangles and meshes is that you canīt do CSG operations
with them. But I want to do some csg-ing with this little sponge thing after I
can create it fast enough.
Thanks for the hints again,
Bonsai
Why differences? You should get *much* faster rendering if you created the
sponge as an union, i.e. stack a lot of little blocks to make up the sponge
structure, instead of progressively cutting holes out of one big block.
Margus Ramst
Personal e-mail: mar### [at] peak edu ee
TAG (Team Assistance Group) e-mail: mar### [at] tag povray org
Home page http://www.hot.ee/margusrt
In article <3aa8d2db@news.povray.org>, "Bonsai" <bon### [at] b0n541 net>
> only for modelling and testing a new object or shape, because for me
> it´s good visible and not too painfull to look at.
It was supposed to be a joke...I just forgot the smiley. But I do think
the smaller piece would look at home on a mouse trap...
In article <3AA8E44A.6218AF06@stress.uio.no>, Simen Kvaal
> bounded) which has zero volume but infinite surface area. Thus, it
> will require infinitely many recursion levels to trace one single ray
Of course, I meant an *approximation* of a Menger sponge...rendering a
real one would literally take forever, and probably not be that
interesting.
> And it would definetely not be transparent, or even semitransparent.
> opaque object which take longer and longer to render. I'd say; skip
> the transparency. :)
Um, with better approximations, the volume the ray passes through will
decrease, and the sponge will become more and more *transparent*. You
will get a fainter and fainter image of the sponge, until it is
invisible. But as I said above, I'm only interested in an approximation,
maybe 3-5 levels...a real sponge would be impossible.
Interesting thought!
I think you're right; it should be invisible.
~simenkv.
Subject: Re: yet another mengersponge...
Date: 12 Mar 2001 05:34:32
Message: <3aaca638@news.povray.org>
Bonsai wrote in message <3AA91E79.770A2F54@b0n541.net>...
> But what I know from triangles and meshes is that you can´t do CSG operations
such object as mesh should be extremly fast
and you don't need CSG - just clippped_by
remember that copy of mesh not waste memory !
and you can balance between memory and speed by spliting object to smaller cubes
(you must find level) and below size create triangles and above size create
copies of meshes with clipping only some of them
ABX
I tried menger with different level of recursion. Iso-surface
calculation precision may affect results, so they are not definite, but
using recursion level of 40 made sponge disappear completely, level 30
showed only some very faint parts of it. Sponge with level 20 looks like
this:
(sorry about incomplete sponge: I left it on table for overnight and
mice thought that it was cheese and eat some of it. Next time I'll put
in place, where they can not access it! ;o)
Seems like sponge with levels up to 6-8 is acceptable, after this sponge
gets too blurry and loses its beauty.
Download 'menger20.jpg' (20 KB)
Preview of image 'menger20.jpg'
Are you saying that this is an isosurface? I have been expecting to see
a fractal isosurface soon but I didn't know one had been made.
No, I wrote that! :-) Yes, it is isosurface, like this (POVMan 0.7 is
required for running it, more complete example comes with
documentation):
#declare xyf=function{
shader{
shader_file "menger.slp"
"rec_depth" 20
isosurface {
function {
xyf
contained_by { box { -1.0,1.0 } }
all_intersections
max_gradient 100
accuracy 0.001
scale 2
shader file is as follows:
iso_function menge(float rec_depth = 8){
float testfirst(output float mx, mn){
float rv = -1;
mx *= 3;
mn *= 3;
float i;
extern float rec_depth;
for (i=0; i<rec_depth;i+=1){
if(mx<=1 && mn <= 1){
rv = 1;
break;
else{
mx = abs(mod(mx*3+1, 6) -1);
mn = abs(mod(mn*3+1, 6) -1);
return rv;
float retv = -1;
if (testfirst(abs(xcomp(P)),abs(ycomp(P))) == 1 ||
testfirst(abs(xcomp(P)),abs(zcomp(P))) == 1 ||
testfirst(abs(zcomp(P)),abs(ycomp(P))) == 1)
retv = 1;
return retv;
"Vahur Krouverk" <vah### [at] aetec ee> wrote :L
> documentation):
> shader{
> "rec_depth" 20
> isosurface {
> function {
> xyf
But is it a fractal isosurface or a fractal shader? Seems like a shader
to me, not knowing anything about shaders.
Shader is probably not the best word for describing this. In version 0.7
I add feature, which allows to use shading language constructs and
virtual machine (which was created for shader byte-code execution) for
computing potential values for isosurfaces. So basically one can write
iso functions in C-like syntax, byte-compile them and use in iso-surface
calculation. As it appears, this works generally faster (2-5 times,
depending from complexity), than functions, which are written directly
in POV-Ray "language". And one can use more advanced features, such as
loops, temporary variables, etc.
Of course shader functions are slower, than built-in (i.e. hard-coded in
source code) iso-functions, about the same margin (2-5 times).
More about this is again in POVMan documentation.
I'd have thought that would depend on the material being used to make
said sponge? With a transparent but reflective material, surely internal
reflections would build up to the point where they would overpower and
obscure any view through the sponge?
I could be wrong though...
Bye for now,
Jamie.
> calculation.
Ah, now I see. Thanks
In article <MPG.1517399eed9bd1a989897@news.povray.org>,
Well, I was specifically talking about transparent sponges, but I think
that the cross-section area of the sponge will tend toward 0 as the
surface area tends toward infinity, so a ray (or in the real world, a
photon) wouldn't be able to hit a perfect sponge, and would just pass
through it.
In article <3aad1a13@news.povray.org>, "Bill DeWitt"
> shader to me, not knowing anything about shaders.
It's a fractal isosurface using a fractal shader as a function. It's no
more a shader than an isosurface that uses a pigment function is a
pigment. The object is an isosurface, defined as all points where a
function is equal to a threshold value...the way the function is
generated doesn't matter.
"Chris Huff" <chr### [at] mac com> wrote in message
news:chrishuff-012D20.18015012032001@news.povray.org...
Right. I got that, thanks.
But I am still hoping that someone will make a fractal or pseudo-fractal
isosurface... as well as a good isosurface tree.
In article <3aad6b4e$1@news.povray.org>, "Bill DeWitt"
> pseudo-fractal isosurface...
What's wrong with the Menger sponge isosurface?
This would probably be unuseably slow and unwieldly at a complexity high
enough for it to look like a tree. You might be able to do it with the
blob pattern in a pigment function, though...
news:chrishuff-947071.22170012032001@news.povray.org...
Doesn't it need the PovMan version to run? I just barely am willing to
go with the MegaPov.
It's the principal of the thing.
I have started one at 4 levels (CSG, no isosurface), but it seems that
this will take a few days (or weeks) to render. At two levels, the
transparent sponge looks rather boring, but the histogram has a mildly
interesting, space-ship-like look, so I'm posting that instead:
Download 'menger-2-t5-h.jpg' (52 KB)
Preview of image 'menger-2-t5-h.jpg'
I did it that way once and while it was faster it wasn't signifigantly
faster. With that many edges you lose a lot of time doing anti-aliasing.
Been there. Done that. Didn't help render times much. Memory use did decrease
however.
The inner structure is very interesting. :)
There are normally a few ways to speed things up. 1) Make meshes, but you can't
because you 're cutting away a chunk. 2) Use unions instead of real CSG, but
that way you'd get artifacts between edges of adjacent cubes. So you're stuck
with a long render. Unless you have megapov and want to try an isosurface. I
have code for an iso-menger-sponge at my website you can use.
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
Did you try hierarchal bounding for the CSG?
"David Fontaine" <dav### [at] faricy net> schrieb im Newsbeitrag
news:3AB### [at] faricy net...
Not yet. Do you mean that I should bound smaller parts of the sponge per
hand. Would this really decrease render time when I do the cut away?
Until now I was trying to get my new sponge macro to work. Now I can give
the recursion level, the length of the sponge and where it´s located. The
sponge is now made of many little mengersponges with recursion level 1.
My next idea is to do only differences with the little sponges that
intersect with the sphere and forget the sponges that are inside the sphere.
This should be easy for the sphere. Other objects might be very hard to cut
away with this approach...
Let´s see,
Bonsai
Hmm, I'm not sure exactly how that worked. You split the CSG components into
however many groups, then those into however many smaller groups, etc, and bound
all the groups, with zero or minimal overlap of any two groups at the same
nesting level. Something like:
difference {
box {}
merge {
merge {
bounded_by {}
bounded_by {}
merge {
merge {
bounded_by {}
bounded_by {}
bounded_by {}
You could split it into 27 parts (3x3x3), each of the 20 edge parts splits
again... maybe it would be more efficient to split the x axis into three, then
the y, then the z, then start the next recursion level... Essentially you make a
bunch of nested bounding that serves to partition the space into smaller and
smaller pieces. It's very efficient because the intersection algorithim is
essentially "walking the tree". It might be tricky to get it arranged so that
you don't have coincident surfaces or anything.
