POV-Ray : Newsgroups : povray.binaries.images : Shortest code ever for mandel landscape made of spheres Server Time
24 Nov 2026 07:16:36 EST (-0500)
  Shortest code ever for mandel landscape made of spheres (Message 1 to 18 of 18)
Subject: Shortest code ever for mandel landscape made of spheres
Date: 18 Jan 2001 06:22:55
Message: <3a66d20e@news.povray.org>
For very long time I thought that this was the shortest way of getting
a decent-looking mandelbrot landscape made of spheres with MegaPov:
camera{location 2look_at 0}light_source{9,1}$R=-2;#while(R<1)$I=-2;#while
(I<2)$A=R;$B=I;$N=0;#while($T=B*B;N<9&A*A+T<4)$B=2*A*B+I;$A=A*A-T+R;$N=
N+1;#end sphere{<R,N/9,I>.02pigment{bozo}}$I=I+.03;#end$R=R+.03;#end
  However, I just realized that I have been wrong all the time. There's a
much shorter way of doing the same:
(R<1)$I=-2;#while(I<2)sphere{<R,eval_pattern(mandel 9,
<R,I>),I>.02pigment{bozo}}$I=I+.03;#end$R=R+.03;#end
  In practice this makes the exact same thing as the previous. (Images made
with both codes included at the end of the article.)
  By the way, can you guess what does this code do without rendering it?
(Answer forwared to this article)
#macro A()int(rand(R)*4)*90#end$P=union{torus{1,.05translate<1,0,-1>}
torus{1,.05translate<-1,0,1>}cylinder{-y,y,.05}clipped_by{box{-1,1}}}
$R=seed(1);light_source{<99,30,-30>1}camera{location<9,6,-13>look_at
0angle 35}$Z=-11;#while(Z<21)$Y=-11;#while(Y<12)$X=-13;#while(X<12
)object{P rotate<A(),A(),A()>translate<X,Y,Z>no_shadow pigment{
rgb<1,.5>}finish{specular.5}}$X=X+2;#end$Y=Y+2;#end$Z=Z+2;#end
Download 'mandel1.jpg' (33 KB) Download 'mandel2.jpg' (32 KB)
Preview of image 'mandel1.jpg'
Preview of image 'mandel2.jpg'
Subject: Re: Shortest code ever for mandel landscape made of spheres
Date: 18 Jan 2001 06:23:45
Message: <3a66d23f@news.povray.org>
Download 'pipes.jpg' (127 KB)
Preview of image 'pipes.jpg'
Date: 18 Jan 2001 07:25:49
Message: <3A67172B.4FBD85F@chesapeake.net>
I am getting a new mental image of why you sign your
posts thhe way you do.
> char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
> main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
> c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 19 Jan 2001 18:49:33
Message: <3A68D147.6D05B6A6@faricy.net>
Defines an object that is two semi-torii connected by a vertical rod, going in
opposite directions from each other, and it tiles this object 23x23x23, each
one randomly rotated. There is also a typo, #while(Z<21)...
Date: 19 Jan 2001 18:53:08
Message: <3A68D21F.756DDEE3@faricy.net>
D'oh, I was getting coordinates confused. Of course it is a truchet tile, the
quarter-torii and coplanar and the cylinder runs between them. And the rotation is
a multiple of 90.
I was completely not seeing that!
Subject: Re: Shortest code ever for mandel landscape made of spheres => Not any more (25KB)
Date: 20 Jan 2001 08:03:53
Message: <3A698C6A.25CA6C7@online.no>
It can be done with 2 characters less.
(The image below is done that way.)
So Warp, can you spot how to shorten your code ?
And your "spaghetti"-code can be shorten too.
I think the same can be done with (at least)
11 characters less.
Btw.:
What's wrong with your keyboard ?
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
Download 'mandel.jpg' (25 KB)
Preview of image 'mandel.jpg'
Date: 20 Jan 2001 10:10:53
Message: <3A69AA7D.22E3C533@gmx.de>
I could not find it until now, but i have a version that is 8 characters
shorter than Warp's, although i'm not sure if you will accept it, because
it's not made of spheres.
I also managed to eliminate one while loop from Warp's version, but that
makes it slightly larger, maybe someone can also reduce this:
camera{location 2look_at 0}light_source{9,1}$R=0;#while
(R<99)sphere{<int(R)/99,eval_pattern(mandel 9,
<(R-int(R)-.5)*3,int(R)/40-1>),R-int(R)>.01pigment{bozo}}$R=R+.02;#end
Date: 22 Jan 2001 20:34:15
Message: <3A6CDF5D.C4140793@online.no>
Well, here's my solution:
camera{location 2look_at 0}light_source{9,1}$R=1;#while
(R+2)$S=2;#while(S+2)sphere{<R,eval_pattern(mandel 9,
<R,S>),S>.01pigment{bozo}}$S=S-.02;#end$R=R-.02;#end
If you're not doing it with spheres, then what are you using ?
Code please !
Interesting solution !
This reminds me of something Dan Johnson did in
his Arrange_3d macro. See his "Polyhedra include file"
thread in povray.binaries.scene-files, 11. Jan -01:
news://news.povray.org/3A67EB4C.EFE1B3BD%40hotmail.com
Best regards,
Tor Olav
Date: 23 Jan 2001 03:11:15
Message: <3A6D3CA0.D8B4DD91@gmx.de>
Well, that's not the obvious solution for a pascal programmer :-)
> Code please !
camera{location 2look_at 0}light_source{9,1}height_field
{pattern 99,99{mandel 9 color_map{[0 rgb 0][1 rgb 1]}
scale.3rotate-x*90translate.5}pigment{bozo}}
I first tried it with mod(), but it turned out beeing ways longer.  What's
in fact missing is a frac() function returning the fractional part of a
variable (although R-int(R) does perfectly suffice apart from length :-).
Date: 23 Jan 2001 08:27:05
Message: <Xns9032931CE5942seed7@povray.org>
If it's reduction in character count what you're looking for:
(R<99)%S=int(R);sphere{<S/99,eval_pattern(mandel 9
<(R-S-.5)*3,S/40-1>)R-S>.01pigment{bozo}}$R=R+.02;#end
Ingo
Date: 23 Jan 2001 09:07:00
Message: <3a6d9001@news.povray.org>
If we consider "decent-looking" a landscape viewed right from above, then
the code can be shortened even more:
light_source{y,1}$R=-2;#while(R<2)$I=-2;#while
(I<2)sphere{<R,I,4-eval_pattern(mandel 9,<R,I>
)>.01pigment{rgb y}}$I=I+.02;#end$R=R+.02;#end
Download 'Mand_big.jpg' (87 KB) Download 'Mand.png' (30 KB) Download 'Mand_aa1.png' (40 KB) Download 'Mand_aa2.png' (33 KB)
Preview of image 'Mand_big.jpg'
Preview of image 'Mand.png'
Preview of image 'Mand_aa1.png'
Preview of image 'Mand_aa2.png'
Date: 23 Jan 2001 09:19:24
Message: <3a6d92ec@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
: camera{location 2look_at 0}light_source{9,1}height_field
  The idea is to make the landscape with objects. Using a height_field is
too trivial.
Date: 23 Jan 2001 09:20:01
Message: <3A6D930E.ECD6A348@gmx.de>
Oops, it seems i have totally missed that...
BTW, now it seems exactly the same length as Tor's version.
Date: 23 Jan 2001 10:01:01
Message: <Xns9032A309EB081seed7@povray.org>
In Tor's version two more commas can be deleted,
sphere{<R,eval_pattern(mandel 9<R,S>)S>.01pigment{bozo}}
in yours one.
sphere{<S/99,eval_pattern(mandel 9<3*(R-S-.5)S/40-1>)R-S>.01pigment{bozo}}
Ingo
Date: 23 Jan 2001 20:09:09
Message: <3A6E2AF6.DA5AD7@online.no>
Who's that Pascal programmer ?   Is it me or you ?
> > Code please !
Using patterns for heightfields is new to me.
MegaPOV feature ?
I wonder why there are such basic functions
missing from the POV-language.
Even my stone-age-Casio had the frac() function.
Best regards,
Tor Olav
Date: 23 Jan 2001 22:45:43
Message: <chrishuff-0ED374.22463923012001@news.povray.org>
In article <3A6### [at] onlineno>, Tor Olav Kristensen
> MegaPOV feature ?
Yes. And I think the keyword really should be "pigment_image", not
"pattern", since it takes a pigment (well, pattern and color_map) and
produces an image from it. The two numbers before (?!?) the { bracket
specify the resolution of the image, pigment stuff goes inside the
brackets, and I think you can use it pretty much any place that uses an
image file.
They were just overlooked or didn't seem necessary...another missing
function is "sgn()", which would return -1 or 1 depending on the sign of
the parameter. (I've patched that one into my own version.) But people
have gotten along for a long time without them, and now that they can be
done easily with macros, there isn't a lot of demand for them to be
added to the program itself.
Christopher James Huff
Date: 24 Jan 2001 16:54:52
Message: <3A6F4F20.B114F2E3@gmx.de>
> MegaPOV feature ?
Yes, i'm not using it much, but it can be useful if you don't want to
carry around a large image file for example.
It's not much problem IMO, because it can quickly be typed with 'R-int(R)'
or done with a macro.  I think it would probably not be much used with
povray anyway, at least less often than the 'sgn()' function Chris
mentioned.
Date: 14 Feb 2001 07:58:37
Message: <3a8a80fd$1@news.povray.org>
news:3a6d9001@news.povray.org...
>   There's a funny thing about this particular scene. When rendered
> at 256x192 without antialiasing it looks like this:
I really like this version of the image - I think that it would make a good
logo for something (perhaps Morton Peas - yes there is such a product,
although nothing to do with me).
