POV-Ray : Newsgroups : povray.binaries.images : Happy Christmas [28.3kb] Server Time
19 Oct 2026 08:16:56 EDT (-0400)
  Happy Christmas [28.3kb] (Message 1 to 13 of 13)
Subject: Happy Christmas [28.3kb]
Date: 24 Dec 2000 07:08:28
Message: <3a45e73c@news.povray.org>
Tom Melly
tom### [at] tomandlucouk
http://www.tomandlu.co.uk
Download 'xmas.jpg' (29 KB)
Preview of image 'xmas.jpg'
Subject: Re: Happy Christmas [28.3kb]
Date: 24 Dec 2000 11:29:11
Message: <slrn94c50c.k07.steve@zero-pps.localdomain>
Very Povish and stylish, thanks Tom.
  3:10pm  up 6 days,  2:31,  2 users,  load average: 1.02, 1.06, 1.02
Date: 24 Dec 2000 13:59:29
Message: <3a464791@news.povray.org>
Very cool. Thanks. Ditto! :)
Date: 24 Dec 2000 19:13:56
Message: <3a469144@news.povray.org>
Couple of things - the lettering is added in psp, and there's an odd
side-effect of the scattering media. The back wall that shows through the
shaft of light looks as though it has a nice medieval-style brick normal. It
doesn't. The media seems to work in layers and what you're seeing is the
staggered image of the stained glass at discrete intervals.
It's mp type 3 scattering media. Anyone come across this before?
Date: 24 Dec 2000 21:39:16
Message: <chrishuff-10A254.21403124122000@news.povray.org>
In article <3a469144@news.povray.org>, "Tom Melly" <tom### [at] tomandlucouk>
You need to either use more samples or add jitter to the samples. Adding
jitter will break up the patterns, but will make things noisier.
Putting transparent, hollow planes or boxes in front and behind the beam
of light should also help, since it will force POV to make a new
interval at each surface. This actually might be the best workaround,
since it puts the additional samples right where you need them, but it
requires you to know where the light beam is..
Christopher James Huff
Date: 25 Dec 2000 08:13:17
Message: <3A474700.69191C74@videotron.ca>
> doesn't.
I was just about to commend you for acheiving this...
Francois Labreque | Rimmer: "Let's go to red alert!"
    flabreque     | Kryten: "Are you sure, Sir?  You realize it
        @         |          actually means changing the bulb!"
   videotron.ca
Date: 26 Dec 2000 11:37:38
Message: <3A48C953.7B4F0A7@enst.fr>
he
l. It
e
	You could try using mpov and the sample_spacing patch to help with this
problem... Otherwise, Chris Huff's suggestions are the way to go (or a
combination of the two).
		Jérôme
********************************* Jérôme M. BERGER
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 26 Dec 2000 11:48:25
Message: <3a48cbd9@news.povray.org>
How come your patch has never been added to MegaPOV? I really would like to
try it without having to compile it...
Date: 26 Dec 2000 12:29:08
Message: <3A48D564.D61A41FD@enst.fr>
e to
	I'm not sure. I sent what I had at the time to Nathan just before he
released MegaPov 0.5 and he said he wouldn't include it in 0.5 because
he lacked the time to test it properly. Some of the code made it though
(because it came with a bugfix) but it's #ifdef-ed out. I suppose Nathan
forgot it when he released 0.6
		Jérôme
Subject: Re: Happy Christmas [28.3kb] [2.9 kb]
Date: 27 Dec 2000 06:09:20
Message: <3a49cde0@news.povray.org>
I took the samples up to 30 and, although still noticable if you know what
you are looking for, the artifacts are fainter (as shown in attachment).
Presumably, higher values would diminish them even more.
To be honest, I hadn't realised that the normal POV params applied to
megapov media methods 2 and 3.
Download 'part_xmas.jpg' (3 KB)
Preview of image 'part_xmas.jpg'
Date: 27 Dec 2000 18:03:14
Message: <na5k4tgd4btuk9nscmpqi3u8kj5rudam3j@4ax.com>
On Wed, 27 Dec 2000 11:09:18 -0000, "Tom Melly" <tom### [at] tomandlucouk>
Try using adaptive sampling in MegaPOV to save some render time and
increase quality, too.
Peter Popov ICQ : 15002700
Date: 28 Dec 2000 02:01:28
Message: <3a4ae548@news.povray.org>
'intervals', although said to be unnecessary in MegPov, still affects the
media.  I often find that using a minimum of intervals 2 is required to get a
good media esp. when more than one light_source exists.
Bob H.
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3a49cde0@news.povray.org...
Date: 29 Dec 2000 15:09:58
Message: <3A4CEDE5.9756DDB3@faricy.net>
Cool! The medieval wall pattern is a rather interesting side effect. :O
Now make a whole row of different windows! Render time 10d... ;)
