POV-Ray : Newsgroups : povray.binaries.images : Re: preview of deform patch (53 kbu) Server Time
21 Oct 2026 12:52:48 EDT (-0400)
  Re: preview of deform patch (53 kbu) (Message 1 to 8 of 8)
Subject: Re: preview of deform patch (53 kbu)
Date: 11 Dec 2000 11:49:58
Message: <3a3505b6@news.povray.org>
Christoph Hormann wrote in message <3A34E9C5.48E56C4A@gmx.de>...
> I must admit that i don't understand much of the code.  I thought it would
> be something like a displace warp for objects but it does look different.
> Could you explain it a bit more detailed?
I choose keyword "deform" becouse this is short
I know that this is some kind of transformation and perhaps should be placed
beetween object's modifiers but I choose different statment becouse of different
usage it has. This example is simple deformation but I'm thinkin on some
complicated which in the truth create different objects - my defformations are
objects. It means they can be assigned to variables, puted as base of another
deformation, as part of csg, can be scaled, rotated etc.
I try describe but I'm affraid of vocabulary
deform {
  TYPE
  contained_by{ CONTAINER }
  [ DEFORM_PARAMETERS ]
  [ DEFORM_TYPE_PARAMETERS ]
  [ object modifiers ... ]
description:
TYPE: for develop universal deformation module curently only support "turn" but
I want implement more type of deformations (look below)
CONTAINER: syntax is inspired by isosurface and this show space of base object -
this allow deform only part of object - i.e. you can twist middle part of
woodden column and leave rest of it
DEFORM_PARAMETERS:
  [ ACCURACY float ]
  [ NORMAL_ACCURACY int [ , float ] ]
  [ NORMAL_WEIGHTED ]
this is group of parameters for all types of deformations
ACCURACY - this is connected with method of recive deformed shape - during trace
ray is divided by points with distance described in accuracy parameter, every
point is undeformed to original space of base object, this makes some kind of
curved ray, than look for intersection with base and return coordinate to
deformed space - default value is 0.01
NORMAL_ACCURACY - this is followed by two parameters and is connected with
method of deformation normals - after finding intersection with base object this
find neighbouring points distributed evenly around of intersection point on
surface perpendicular to normal. first integer value determine number of this
points (must be greater than 2); second float determine distance beetwen this
points and intersection point (default values are 4 and 0.001); this points are
deformed to space of scene and appear as some surface aproximate as set of
triangles; than average normal of this triangles for output normals
NORMAL_WEIGHTED - determine method of averaging normal - more in thread "should
be normals weighted" at p.a-u
DEFORM_TYPE_PARAMETERS - this is group of parameters proper for type of
deformation; they control deformation i.e. for deformaion "turn" there is
parameter "full_after" followed by float - this tells that going along axis of
container after every full_after distance space should be twisted 360 degrees
I hope after explanation this is more readable, try understand again:
deform {
  turn box{-1 1 texture{Texture}}
  contained_by { cylinder{ <0,-1,0> <0,1,0> 3 }}
  accuracy 0.05
  normal_accuracy 3, 0.01
  normal_weighted
  full_after 8
what about next deformation types
second will be deformation showed on right side at
http://www.abx.art.pl/pov/nonlinear/test.jpg - this is still deformation "turn"
but with specified parameter "spindle" followed by float greater than 0
another deformation types:
a) put object in cylinder and place along bezier - for curved texts
b) put object in cylinder and create torpatch, tangle
c) put object in box and place beetwen two bezier_patches as top and bottom
surface of this box
d) put object in cylinder or box and stretch out this like rubber (different in
center and at and)
in future I think that this could speed up if deform vertices of mesh during
parse and play like normal mesh
I not have finished sources but if there is any person interested with this I
can public current state of deform.c
ABX
Date: 11 Dec 2000 12:53:58
Message: <3A352441.DBE0DD88@hlavacek-partner.cz>
Great, I thinked about something similar some time ago.
But why don't use curved rays for tracing primarilly a only for those
objects,
which don't suppory intersection with spline (for example) use spline
interpolation by straight rays? Those objects will be all of POV objects
at the beginning, but in the future some of them can support
intersection with curved rays.
Just an idea, I don't know, if exists mathematical solution of
intersection between spline and sphere, for example.
Disnel
Date: 11 Dec 2000 13:31:40
Message: <3A351D86.BF6A26FD@gmx.de>
That was much clearer, thanks.
I think it would be useful to allow to use functions or pigments for
deformation.  Don't know if that's easy to implement, but better than a
whole lot of independent types with new keywords IMO.
It would be interesting to have some info about speed although it's
probably not that slow with a simple 'turn'.
Date: 11 Dec 2000 14:00:55
Message: <3a352467$1@news.povray.org>
Christoph Hormann wrote in message <3A351D86.BF6A26FD@gmx.de>...
> deformation.
I didn't plan such usage but maybe ...
I think deform, accuracy and contained_by is easy to understand
normal_accuracy and normal_weighted are optional and in the truth
I don't think that this has large meaning for output
to describe spline I want use syntax of spline
to describe patch I want use syntax of patch
I try to not annoying with new keywords
current are wrong ? please tell me
I tell you when finish code
Good comparision will be with speed of isosurface with the same equation of
deformed coordinates
ABX
Date: 11 Dec 2000 14:20:09
Message: <chrishuff-00B1BF.14210211122000@news.povray.org>
In article <3a3505b6@news.povray.org>, "Wlodzimierz ABX Skiba"
<abx### [at] abxartpl> wrote:
> deform {
>   TYPE
I think a much more intuitive syntax would be:
deform {
    DEFORMED_OBJECT
    deformation {WARP}
    DEFORM_PARAMETERS
    OBJECT_MODIFIERS
I would also use "weighted_normals" or "weight_normals" instead of
"normal_weighted", "twist" instead of "turn", and a few other little
changes. If the object has a texture, it is deformed along with the
object. If a texture is given in the deform{} block, it isn't deformed.
This would be used like this:
deform {
    sphere {...}
    deformation {turbulence 0.5}
    accuracy 0.01
    normal_accuracy 4, 0.001
    weighted_normals on|true|yes|off|false|no
        // the on/off/etc... would be optional, using
        // only the keyword would turn it on.
Also, I don't know how your deformations work, but it would make sense
to use the warps to do the job, since you are really just warping an
object instead of a pattern. If you do this, you can avoid a lot of
duplicated work by implementing a single warp.
The equivalent code for what you wrote with my suggested syntax would be:
deform {
    box {-1, 1 texture {Texture}}
    type {twist y, 8}// twist AXIS, TWISTS_PER_UNIT_DISTANCE
    accuracy 0.05
    weighted_normals
Christopher James Huff
Date: 11 Dec 2000 14:39:10
Message: <3a352d5e$1@news.povray.org>
Chris Huff wrote in message ...
> deform {
>    DEFORMED_OBJECT
>    deformation {WARP}
>    DEFORM_PARAMETERS
>    OBJECT_MODIFIERS
yes, good suggestion, thanks
> "normal_weighted"
why ? this groups parameters for normal calculation ?
yes, I thought of it, this is hardly to choose english equvalent by
non-natural-english-speak-man
> and a few other little changes
write, please
yes, this is part of my conception
even further - layered textures mixed from deformation and base object!
> deform {
>  sphere {...}
>  accuracy 0.01
what about deformations where they are good described only in part of space ?
turbulence and twist is calculable in evry point but what about placing along
spline ?
I consider it
> deform {
>    accuracy 0.05
>    weighted_normals
thanks, evening, going to daughter and wife I'll consider
ABX
Date: 11 Dec 2000 15:24:02
Message: <3A3537D9.67ED545C@gmx.de>
> > deformation.
Probably Chris Huff's idea of using warps is even more universal.
I didn't mean the general keywords but the ones specific for the different
types.  Each new type will introduce a new keyword although most of them
are probably only simple mathematical functions.
BTW, i'm curious how you want to deform something according to a spline,
since it only supplies some local geometric information (i.e. the shape of
a line) while it would need some deformation function for the whole space.
Date: 11 Dec 2000 15:53:04
Message: <chrishuff-348FE5.15535711122000@news.povray.org>
In article <3a352d5e$1@news.povray.org>, "Wlodzimierz ABX Skiba"
> > "normal_weighted"
Because in English, describing words or actions usually go before the
thing they describe or act on. You say "weighted normals", not "normals
weighted". You tell POV to weight the normals or to use weighted
normals, not to use normals weighted.
> write, please
Allowing a boolean after "weighted_normals"(or "weight_normals", or...)
so you could specify on or off...um, that's all I could think of right
now. I think I mentioned all the ones I thought of.
Yes, I was thinking of that...some interesting possibilities. And if you
use warps to specify the deformations, you could control the textures
yourself...your patch looks like it could be very fun just to play
around with. :-)
> space ?
> placing along spline ?
I'm not sure what exactly you mean...I would assume that parts of the
surface where the deformation is undefined simply aren't deformed. If
you want only part of the object to be deformed, you should probably use
a union of a deform object with ordinary objects.
BTW, multiple deformations would also be useful...just allow them to be
applied one after the other, which should be very easy to do if you use
warps. That way you could make a twisted, turbulated box being sucked
into a black hole. :-)
deform {
    box {<-1,-1,-1>, < 1, 1, 1> texture {Texture}}
    deformation {turbulence 0.2}
    deformation {twist y, 8}
    deformation {black_hole ...}
    accuracy 0.05
    weighted_normals on
> > be:
> > deform {
Oops, that should have been "deformation {twist y, 8}".
Date: 11 Dec 2000 15:55:36
Message: <chrishuff-5BE6B3.15563011122000@news.povray.org>
In article <3A3537D9.67ED545C@gmx.de>, Christoph Hormann
Especially when combined with the "displace" warp and the function
pigment(which is currently vaporware, I haven't gotten it to work right).
Date: 12 Dec 2000 04:36:32
Message: <3A35F19F.94DFD97@enst.fr>
	Wouldn't it be simpler (and faster) to take the normal of the
undeformed object and apply the transformation to it?
		Jérôme
********************************* Jérôme M. BERGER
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 12 Dec 2000 04:57:21
Message: <3a35f681$1@news.povray.org>
> > > "normal_weighted"
Ok, thanks, I'll tell it to POV :-)
> around with. :-)
I hope I do it not only for fun :-)
only with twist just imagine "airscrew", "drill"
> > space ?
I thought of your proposition and looked at the source of warps whole night and
finnaly I think there is big misunderstand, You Chris and Christoph Hormann
think that I deform point only ones but every deformation which I need must be
bi-directional/reversable/invertable
well defined deformation f(x,y,z) must have brather or sister as undeformation
g(x,y,z) where:
A=f(B) and B=g(A)
perhaps I don't understand warps source but I think this is hardly (if possible)
to inverse uniformly all warps
as I see twisting is bad example becouse is well defined for whole space and you
omit bi-directioning of calculation
I try explain again:
I start with patch becouse of bad normals in isosurface
I discover that normals of deformed object can be aproximated insted of
calculating
Here is symbolic notation of my method:
take depth1 and depth2 for container or bounding box
take function deform and undeform (opposite to deform)
for i=depth1 to depth2 step accuracy
  point1=evaluate_ray(trace_ray,i)
  point2=evaluate_ray(trace_ray,i+accuracy)
  pointA=undeform(point1)
  pointB=undeform(point2)
  deformed_ray=create_ray_beetwen(pointA,pointB)
  pointC=find_every_intersection(deformed_ray,base_object)
  for every pointC beetween pointA and pointB
    normal=normal(base_object,pointC)
    array[normal_accuracy_int] = neighbouring points
                                 around pointC
                                 distributed evenly on surface
    point3=deform(pointC)
    deformed_array=deform(each of neighbouring points)
    calculate (weighted) normal from deformed neighbours
    put on stack of intersections point3 and normal
  end for
end for
is inverted function of turbulance and/or warps builded in povray
> If you want only part of the object to be deformed,
with wasting memory if this could be omited ?
I'll consider this behavior
yes, I though of it
> deform {
>    accuracy 0.05
>    weighted_normals on
hmm, but parameters of accuracy should be defined for every deformation becouse
every type of deformations could have "density" of changing, "denisty" of
turbulencing
than perhaps
deform {
  deformation {
    turbulence 0.2
    accuracy 0.1
    weighted_normals on
  deformation {
    twist y, 8
    accuracy 0.5
  deformation {
    black_hole ...
    accuracy 0.01
    normal_accuracy 10, 0.2
    weighted_normals on
ABX with doughter at zuza.org
Date: 12 Dec 2000 06:38:59
Message: <3a360e53$1@news.povray.org>
Jérôme M. Berger wrote in message <3A3### [at] enstfr>...
"should
deform begining and end of normal and calculate returned direction ?
this is wrong method
sure, at first I thought of it but this not works with deformations
why ?
look on top surface of deformed box from begining of this thread
this is flat before and after deformation
and normal is parallel to axis of deformation
but imagine normal before deformation
normal's end_point twist just like other points and after deformation
normal is not parallel to axis of deformation
and smaller normal not help, direction is direction
explain more ?
ABX
Date: 12 Dec 2000 08:37:35
Message: <3A362A1E.AE7BA4CE@enst.fr>
> why ?
> explain more ?
	You're right, it probably cannot be done in a completely generic way
and would need to be done for each deformation. Mmm... maybe not as easy
as I first thought, let's see:
Let <nx, ny, nz> be the normal of the object before the deformation;
Let f be the transformation and fx, fy, fz its components;
Then the normal of the transformed point is:
<nx * dfx/dx + ny * dfy/dx + nz * dfz/dx,
 nx * dfx/dy + ny * dfy/dy + nz * dfz/dy,
 nx * dfx/dz + ny * dfy/dz + nz * dfz/dz>;
	Therefore, all that's needed is to be able to compute the various
df*/d*. In the case of the twist transform along the y axis:
fx = cos(k*y)*x - sin(k*y)*z
fy = y
fz = sin(k*y)*x + cos(k*y)*z
	And the transformed normal becomes:
<nx*cos(k*y) + nz*sin(k*y),
 nx*(-k*sin(k*y)*x-k*cos(k*y)*z) + ny + nz*(k*cos(k*y)*x-k*sin(k*y)*z),
 nx*(-sin(k*y)) + nz*cos(k*y)>
	Notice that for the flat faces, nx=0, ny=1 (or -1), nz=0 and the
transformed normal is correct.
	Hope this helps,
		Jérôme
Date: 12 Dec 2000 09:00:57
Message: <3a362f99@news.povray.org>
Jérôme M. Berger wrote in message <3A362A1E.AE7BA4CE@enst.fr>...
> Hope this helps,
great, thank you for support
ABX
Date: 12 Dec 2000 09:50:49
Message: <3a363b49@news.povray.org>
Christoph Hormann wrote in message <3A3537D9.67ED545C@gmx.de>...
but as I answer to Chris main part of my concept is using "bi-directional"
deformation and if warps support it this could be possible
but I'm affraid it is imposible
no, they aren't simple, only twister is simply
is this simple to calculate x from (A*x-B)(cosx-sinx)=C ?
this is misunderstanding
you think that I want function for whole space but I don't want
I want container for base space and deform function
with this I can describe space of deformed object and bound it
during trace I can recognize steps inside deformed container and undeform
are you curious about placing along spline ?
just like 2d drawing software puts text on curve
I'm not sure if it is possible but perhaps this is beginning:
1. get spline (begin at t=0 and end at t=1)
2. generate function for normal N=f(t) where t is beetween 0 and 1
3. generate function for point P=f(t) where t is beetween 0 and 1
4. generate equation for plane at point P(t) and with normal N(t)
5. resolve equation to find (perhaps derivative of sth) plane
    with minimal distance beetween my point and P(t)
6. calculate t for achived plane
looks this possible ?
ABX
Date: 12 Dec 2000 10:13:10
Message: <chrishuff-7B78FA.10140412122000@news.povray.org>
In article <3a35f681$1@news.povray.org>, "Wlodzimierz ABX Skiba"
> night and finnaly I think there is big misunderstand, You Chris and
> Christoph Hormann think that I deform point only ones but every
> deformation which I need must be bi-directional/reversable/invertable
> undeformation g(x,y,z) where:
> A=f(B) and B=g(A)
Ok, I thought your patch used a method similar to the isosurface to find
the intersections, but generated the functions automatically from a
specified object and simply displaced the function. I still don't
entirely understand what you are doing...but it looks more like
simulating curved rays with short segments.
Unfortunately, no, there aren't any functions to invert warps in
POV-Ray...and many warps aren't reversable.
If it only works with invertable warps, it is a lot more limited than I
thought...maybe another method could be used in addition to what you
wrote. Type 0 deform objects would be what you have now and would use
special, reversable deformations, type 1 deform objects would convert
the object to an isosurface function and apply a warp. Type 1 would be
more versatile, but also potentially slower/less accurate.
Hmm, I wasn't considering memory use...
> deformation becouse every type of deformations could have "density"
> of changing, "denisty" of turbulencing than perhaps
Well, I was thinking of it in terms of warps, all the deformations would
be put in a single chain of warps rather than nested deformations, so
only a single accuracy would be needed, and it would only have to handle
the finest detail of all the deformations put together.
Date: 12 Dec 2000 10:26:13
Message: <3a364395@news.povray.org>
as I wrote at begining :-)
yes, unfortunatly
but you wake up dreams on me :-)
I'll consider this in next version :-)
thanks for support
ABX
Date: 12 Dec 2000 10:32:26
Message: <3A364505.1A11CAEB@gmx.de>
I recognized that, NTL it seems to be possible with isosurfaces.
That wasn't my point, i just meant that it would be better to enter the
function in a common way like an isosurface function than to hardcode it
and introduce a new keyword for each new function.  If it's not possible
to use warps, you maybe should consider using the isosurface function
parser as i first suggested.
Well, it's a bit too much for a tuesday afternoon :-) but anyway it seems
to be a function for whole space although it's constant in one or two
directions.
Date: 12 Dec 2000 10:52:35
Message: <3a3649c3@news.povray.org>
Christoph Hormann wrote in message <3A364505.1A11CAEB@gmx.de>...
my aim was give user-friendly interface deformations available
as isosurfeces to non math-users
if I back to function declaration than I return to begining
sometimes simple things are hardly to achive - equation above
simplest form achived for twist over spindle
(http://www.abx.art.pl/pov/nonlinear/zakrecony.jpg)
you don't like names for types of deformation ?
what about pigments - first was many types (with fast engine)
and than suppport for functions as pigment
perhaps I use the same way of evolution :-)
> directions.
what about spline looped ?
ABX
Date: 13 Dec 2000 04:56:31
Message: <3A3747CF.31FE9B51@enst.fr>
	Something's not clear here... I should have said that f is the
transform that's applied to the *ray*, it's the inverse of the one
applied to the object.
		Jérôme
