POV-Ray : Newsgroups : povray.binaries.images : Subsurface Scattering: macro now available (21kb jpeg) Server Time
30 Nov 2026 04:22:14 EST (-0500)
  Subsurface Scattering: macro now available (21kb jpeg) (Message 1 to 7 of 7)
Subject: Subsurface Scattering: macro now available (21kb jpeg)
Date: 26 Nov 2003 18:38:51
Message: <3FC5397E.1020307@hotmail.com>
Okay. For whoever is interested, I have placed the code into
povray.binaries.scene-files. There is an example file (see image
attached to this message) as well as an include file containing the macro.
There are still a few things that could be modified, but it should work
well in most cases, where the scattered light doesn't have to be
extra-smooth.
Have fun~
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Download 'sss_3.jpg' (21 KB)
Preview of image 'sss_3.jpg'
Subject: Re: Subsurface Scattering: macro now available (21kb jpeg)
Date: 26 Nov 2003 18:58:51
Message: <3fc53e3b$1@news.povray.org>
"Samuel Benge" <sbe### [at] hotmailcom> a écrit dans le message de
news:3FC### [at] hotmailcom...
This is simply brilliant! Thanks a lot (I'm selfishly glad that you finally
got a more permanent internet connection... Rare as it was, your input was
always impressive)!
Just wondering: how did you came up with this idea? It seems to be a case
example of "thinking out the box"...
And for the potential developers: could this be hard coded for faster
rendering?
Also: could a trick like this be used to create patina effects?
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 26 Nov 2003 19:38:53
Message: <3FC5479B.1010305@hotmail.com>
Thank you. You know, in-between posting the preliminary images, I kept
on thinking you might like to use this technique. You're an inspiration
to all POVers.... you know that, right? :)
If I can find a job soon, I can keep my ISP.
> always impressive)!
I'm terrible about being a stable presence. The problem is, I only post
when I'm sufficiantly inspired, and sometimes I take vacations from POV
for months; it's not all because I can't keep an ISP.
That's a tricky question. For some reason everything I learn about
POV-Ray gets stored in my memory better than most things, which makes
for a good pool of ideas to pull from. Somehow, this idea came as a
flash one night before bed.
> rendering?
 > G.
This *can* be hard-coded. A setup similar to the current implementation
of photons would do the trick, but instead of making them pass through
in refraction or bounce off in reflection, they would simply stick onto
the object's surface and blur out.
Samuel Benge
Date: 26 Nov 2003 23:15:21
Message: <3fc57a59@news.povray.org>
"Samuel Benge" <sbe### [at] hotmailcom> wrote in message
Yea!
> extra-smooth.
Nice rendered example. Great chew-toy too.
Bob H.
Date: 27 Nov 2003 04:45:16
Message: <kktg91-8o2.ln1@triton.imagico.de>
This 'scattering photon mapping' is definitely an interesting idea.  I
don't know it it will work efficiently in practice but that's difficult
to tell.  Note that it is a completely different approach towards
scattering than usual.
But your blob based technique could be much more efficient with Chris
Huff's blob pattern.  This way you would avoid the need for the multiple
object patterns and don't need a slow proximity pattern either.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 27 Nov 2003 13:45:55
Message: <3FC64661.7070303@hotmail.com>
The problem with the way I shot the blobs at the surface is that they
are just randomly shot at the surface. Photon-mapping has a more
efficient way of doing this. The photons are shot at the target object
in a spiral pattern, and therefore cover the surface more completely
with fewer samples.
Chris Huff's blob pattern would be a great benefit. Is that part of
MegaPovPlus? If so, I could get started on something right away :).
> Christoph
Samuel Benge
Date: 27 Nov 2003 14:22:06
Message: <54vh91-76g.ln1@triton.imagico.de>
> with fewer samples.
Then try placing the blob components in a similar way.  You don't
necessarily need a spiral pattern, other regular patterns or random but
uniform distributions like used for radiosity might be useful as well.
Try for example the halton sequence Mael used for radiosity some time ago.
It is part of MegaPOV 0.x.
