POV-Ray : Newsgroups : povray.binaries.images : Subsurface Scattering, 2nd image (43kb jpeg) Server Time
30 Nov 2026 04:22:14 EST (-0500)
  Subsurface Scattering, 2nd image (43kb jpeg) (Message 1 to 19 of 19)
Subject: Subsurface Scattering, 2nd image (43kb jpeg)
Date: 26 Nov 2003 02:50:56
Message: <3FC45B4A.7010906@hotmail.com>
Here's another test image for the subsurface scattering sim I'm
developing in POV 3.5. Does the object look transparent? It's not.
No aa on this one, because it's getting late.
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Download 'oldman_wax.jpg' (43 KB)
Preview of image 'oldman_wax.jpg'
Subject: Re: Subsurface Scattering, 2nd image (43kb jpeg)
Date: 26 Nov 2003 02:55:53
Message: <3FC45C87.40402@hotmail.com>
Oh yeah, nearly forgot to mention that it only took 6 minutes and 41
seconds to render.
Samuel Benge
Date: 26 Nov 2003 06:49:33
Message: <3fc4934d$1@news.povray.org>
Sorry, I can't really comment on it because my jaw has dropped to the floor.
You rule, pal. Will you share your secret?
Best regards,
Roberto
Date: 26 Nov 2003 06:55:01
Message: <web.3fc493c4e15d54f08d7cbbaa0@news.povray.org>
Drooooooooooooooool :P
Great work! And only 6 minutes! This really rocks!
Best regards.
Date: 26 Nov 2003 10:03:40
Message: <3fc4c0cc$1@news.povray.org>
Two slope maps; one taking camera position into account, the other taking
light position into account ?
Hugo
Date: 26 Nov 2003 10:23:25
Message: <3FC4C56B.6060009@hotmail.com>
I'll share the code very soon, but it needs to be cleaned up so that
willing individuals can make sense of it and help develop it further.
> Best regards,
> Roberto
Samuel Benge
Date: 26 Nov 2003 10:25:05
Message: <3FC4C5CF.10900@hotmail.com>
Slope maps would have doomed this project from the beginning. My
technique is more like real SSS. In fact, it's the closest you can get,
I think, without making a patch that throws photons.
> Regards,
> Hugo
Samuel Benge
Date: 26 Nov 2003 10:42:13
Message: <3fc4c9d5@news.povray.org>
Excellent !
Will be in the next megapov ? or mlPOV ? (Pleaaaaase !)
Date: 26 Nov 2003 10:46:14
Message: <3fc4cac6$1@news.povray.org>
> Excellent !
Samuel Benge has done it with pov 3.5 so you could do it right now ...
(well, if you manage to find the trick :)
M
Date: 26 Nov 2003 11:15:31
Message: <3FC4D1A1.8040102@hotmail.com>
I don't plan on keeping it a secret for too much longer..... turns out
it does work with close light_sources by the way.
It actually might work better in mlPOV, but might be slower..... It
would most likely be more accurate with mlPOV.
Mael wrote:
>>Excellent !
> M
Samuel Benge
Date: 26 Nov 2003 11:27:49
Message: <3fc4d485$1@news.povray.org>
When :-))) ?
Date: 26 Nov 2003 11:30:30
Message: <3fc4d526@news.povray.org>
"Samuel Benge" <sbe### [at] hotmailcom> wrote in message
news:3FC### [at] hotmailcom...
Are you using scaled copies of the object in relation to the light
source in order to build some type of illumination map?
Very nice effect.
-Shay
Date: 26 Nov 2003 12:00:01
Message: <web.3fc4db83e15d54f0b4c392b30@news.povray.org>
ok,
my second guess is a mixture of aoi (if accurate) and proximity pattern
Norbert.
>Samuel Benge
Date: 26 Nov 2003 12:19:46
Message: <3FC4E0B1.7000400@hotmail.com>
Your first guess was much closer, except I didn't use mlPOV... although
I believe it could be used to produce a similar result by using a
slightly different method.
Your proximity pattern guess is close as well.
Norbert Kern wrote:
> ok,
> Norbert.
Samuel Benge
Date: 26 Nov 2003 12:24:39
Message: <3FC4E1D4.60700@hotmail.com>
I thought somebody might guess that, but it isn't the case. Such a
design would be kind of hard to implement because the scaling direction
might be hard to align with the direction of the light_source.
While the surface is taken into account, it is only used as a reference,
and not as an illumination map.
> Very nice effect.
> -Shay
Samuel Benge
Date: 26 Nov 2003 13:25:01
Message: <web.3fc4efb9e15d54f03a02ccab0@news.povray.org>
my third guess:
two pass render:
1. blurred b/w image
2. first render used as image_pattern for a texture with high ambient values
according to brighter parts of the first render and ambient zero for
shadowed parts.
That should explain some artefacts.
Norbert
>Norbert Kern wrote:
>> ok,
>> Norbert.
>Samuel Benge
Date: 26 Nov 2003 14:36:56
Message: <3FC500D6.6090500@hotmail.com>
Good guess, but Christoph Hormann has guessed correctly. See the
original Tuesday Mystery thread.
Norbert Kern wrote:
> my third guess:
> two pass render:
> shadowed parts.
> Norbert
Samuel Benge
Date: 26 Nov 2003 18:25:47
Message: <3fc5367b@news.povray.org>
That's gorgeous!
please don't wait too long to post the source.
Bill Hails
Date: 27 Nov 2003 02:13:58
Message: <3fc5a436$1@news.povray.org>
There is a long time i try to do a thing like that.....
Bravo
Friendly
Sylvain
"Samuel Benge" <sbe### [at] hotmailcom> a écrit dans le message de
> Samuel Benge
