POV-Ray : Newsgroups : povray.binaries.images : Subsurface Scattering: A Tuesday Mystery (21kb jpeg) Server Time
30 Nov 2026 04:22:14 EST (-0500)
  Subsurface Scattering: A Tuesday Mystery (21kb jpeg) (Message 1 to 17 of 17)
Subject: Subsurface Scattering: A Tuesday Mystery (21kb jpeg)
Date: 25 Nov 2003 21:34:43
Message: <3FC41137.7080408@hotmail.com>
I think I have found a new way to simulate subsurface scattering(SSS). I
have attached an image of an object with a yellowish diffuse and reddish
SSS.
Can you tell how I did it? I did not use media or photons. I did not use
double_illuminate.
Four stars to the person who figures it out.
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Download 'sss_test.jpg' (22 KB)
Preview of image 'sss_test.jpg'
Subject: Re: Subsurface Scattering: A Tuesday Mystery (21kb jpeg)
Date: 25 Nov 2003 21:38:03
Message: <3FC4120A.8000302@hotmail.com>
Oh yeah, and I used nothing but POV-Ray version 3.5;
> SSS.
> double_illuminate.
Samuel Benge
Date: 25 Nov 2003 22:51:30
Message: <3fc42342@news.povray.org>
"Samuel Benge" <sbe### [at] hotmailcom> wrote in message
news:3FC### [at] hotmailcom...
> SSS.
> double_illuminate.
Hey Samuel. You deserve the four stars yourself for the stuff you've come up
with.
This one has a unique look. Layering of multiple surfaces? Perhaps including
a fade color too?
There's some irregularity of the shading in certain places (at corners of
the base) so seems that radiosity might also be employed for this.
Bob H.
Date: 25 Nov 2003 22:59:44
Message: <3fc42530$1@news.povray.org>
That's really excellent. After you announce the winner, may we see the code?
I really would love to try the effect.
Great work (as always!)
D.
> SSS.
> double_illuminate.
> Samuel Benge
Date: 25 Nov 2003 23:02:01
Message: <3FC425B7.5000900@hotmail.com>
Hi Bob, long time between greetings.
> with.
Yes, four stars for the introverted hermit :)
> a fade color too?
Close.....
> the base)
Maybe a more advanced version of what I'm doing could clean that up.
Nope, way off.
Samuel Benge
Date: 25 Nov 2003 23:05:52
Message: <3FC4269E.2020907@hotmail.com>
Yes, of course! I will still need to fix a few things since it does not
currently work well with radiosity (but it should if things go well).
I have tested it successfully in a number of situations so far, and it seems to
perform well.
> D.
Thanks!
Samuel Benge
Date: 25 Nov 2003 23:59:15
Message: <cjameshuff-E8C765.23581125112003@netplex.aussie.org>
In article <3FC### [at] hotmailcom>,
> SSS.
Very nice.
> double_illuminate.
A semitransparent, porous isosurface filling the interior?
http://tag.povray.org/
Date: 26 Nov 2003 02:47:53
Message: <3FC45AA8.4090607@hotmail.com>
Christopher James Huff wrote:
> Very nice.
Thank you Chris.
>"Can you tell how I did it?"
Nope, pretty far off. You know, I've tried doing it that way, but could
never get any good results.
Here's a hint: this method doesn't take the interior of the object into
account at all.
Samuel Benge
Date: 26 Nov 2003 02:57:48
Message: <3fc45cfc$1@news.povray.org>
> SSS.
> double_illuminate.
The image is really nice and gorgeous...
Is your method faster than "regular" sss ?
Nico
Date: 26 Nov 2003 03:00:28
Message: <3FC45D9B.3000605@hotmail.com>
Thanks.
> Nico
If you are comparing it to media, then yes, it's much faster.
Samuel Benge
Date: 26 Nov 2003 03:30:58
Message: <3fc464c2$1@news.povray.org>
This is really impressive. Did you try to do a candle ? Does your
technique work with a very close light ?
My guess for your technique is a two pass render, first pass with a
black and white spherical pigment depending on the light position that
you apply to all objects with subsurface scattering, and then a second
pass where you use the first one to evaluate the color. While explaining
my guess I have no really precise idea on the how you did it though.  :-)
Am I any close ??   8-p
JC
> SSS.
> double_illuminate.
Date: 26 Nov 2003 04:32:07
Message: <7h8e91-pq2.ln1@triton.imagico.de>
> SSS.
> double_illuminate.
Tricky, but i have an idea.  Could you render it with the light source
in the middle between the two shapes?
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 26 Nov 2003 10:21:10
Message: <3FC4C4E3.8020800@hotmail.com>
Thanks JC. Nope, haven't tried a candle yet, it was getting quite late
last night.
 > Does your
I don't think it will, but only because my math is sloppy. I'm hoping
when I release the code that somebody with better coding skills will
develop it further.....
You are very close. A black/white pigment is involved, and a preliminary
pass to establish subsurface scattering effects is used.
Samuel Benge
Date: 26 Nov 2003 10:22:12
Message: <3FC4C522.3060606@hotmail.com>
Nope, not until the math is fixed. Then I should be able to render it
with very close light_sources.
Samuel Benge
Date: 26 Nov 2003 11:20:01
Message: <web.3fc4d292c4cfe4f2736664ab0@news.povray.org>
Hi Samuel,
my guess is a mlpov render with use of shadow_pigment, use of the object on
itself, a nonzero ambient value for nonshadowed and ambient zero for
shadowed parts. For the smooth transition you perhaps used an area light to
define the shadow pigment and a point light for the scene.
Norbert
>SSS.
>double_illuminate.
>Samuel Benge
Date: 26 Nov 2003 13:04:12
Message: <nf6f91-sh8.ln1@triton.imagico.de>
Well, i thought the slope pattern might be involved.  In this case it
would only work well for a distant light source, otherwise you would
need the aoi pattern instead.
Looking closer at the image reveals that there are indeeed problems,
strong scattering occurs at places where it should not occur.
I have two other things in mind:
1) you use saved radiosity data from a different but related scene
setup.  This is far fetched of course but it might be an intersting idea
for such effects
2) you use trace() to place blob components on the surface and use the
blob with the object pattern (not sure how you could achieve the smooth
transit with this method though)
Date: 26 Nov 2003 14:34:44
Message: <3FC50051.30406@hotmail.com>
 > Christoph
Congratulations, you get four stars :) While you didn't explain the
whole technique, you explained the guts of my setup.
I used trace to place blob components randomly onto the object. The blob
object is made into a pigment using the object pattern . The blobby
pigment is then jittered about 100 times inside an average pattern's
color_map.
I have made a few enhancements and bug fixes, and I think it's about
ready to be released. In order to allow the use of multiple
light_sources I might have to make it into a macro which you place into
an average pattern's texture_map.
It will be ready very soon.
Samuel Benge
