POV-Ray : Newsgroups : povray.binaries.images : Odd Transformation Server Time
21 Oct 2026 06:07:46 EDT (-0400)
  Odd Transformation (Message 1 to 5 of 5)
Subject: Odd Transformation
Date: 16 Jul 2003 09:33:12
Message: <3F1553EE.ED12B0C7@duratechindustries.net>
Hi all.  Can someone help me understand why my translated and rotated
grass would suddenly become airborne?  According to the Pov code, there
is no transformation on the y-axis, and I don't ever rotate it upwards
or downwards, either.  Attached is the picture and below is the
pertinent code for the grass circle.
#declare Rad=10;
#declare R_V=0;
#declare R3 = seed (27143);
#declare R4 = seed (R3);
#declare Offset1=-67+rand(R2)*6.357;
#while(Rad > 0)
  #local R_V = 0;
  #while(R_V<360)
    object{ Blade
      translate rand(R4)*1.5+z*Rad
      rotate y*R_V
    #local R_V = R_V+300/Rad/10;
  #local Rad = Rad - 0.5;
Download 'gardenborder.jpg' (51 KB)
Preview of image 'gardenborder.jpg'
Subject: Re: Odd Transformation
Date: 16 Jul 2003 09:41:55
Message: <3f155623$1@news.povray.org>
"Ghost" <flu### [at] duratechindustriesnet> a écrit dans le message de news:
3F1553EE.ED12B0C7@duratechindustries.net...
In the following line
rand(R4)*1.5 is actually promoted to rand(R4)*1.5*<1,1,1>
so that you have a random <x,y,z> movement
To get it right it should be for instance <rand(R4),0,rand(R4)>
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 16 Jul 2003 09:42:46
Message: <iclahv828bjo9tkrmgk2cefgf93bcb9sb5@4ax.com>
On Wed, 16 Jul 2003 08:32:30 -0500, Ghost <flu### [at] duratechindustriesnet> wrote:
this line means in fact
       #local temp=rand(R4);
       translate <temp,temp,temp>*1.5+z*Rad
which means
       translate <temp*1.5,temp*1.5,temp*1.5+Rad>*1.5
so as you seen there is translation along y axis.
ABX
Date: 16 Jul 2003 09:45:01
Message: <web.3f15568047a69323397cf110@news.povray.org>
Actually, you are translating the grass in the y-direction, right here:
>    object{ Blade
>      rotate y*R_V
the statement:
will be promoted to:
  translate <rand(R4)*1.5, rand(R4)*1.5, rand(R4)*1.5+Rad>
with the rand statements all being equal. You need to explicitly set the
direction that you want this translation to occur. Hope that helps!
 - Nick (FitchN.com)
Date: 16 Jul 2003 10:49:55
Message: <3F1565EE.9BD902D8@duratechindustries.net>
Ack... now I see what I did.  I guess it never occurred to me that this would
happen.  Oh well, now I know!    Thanks guys!
> #declare Rad=10;
> #declare R_V=0;
> #while(Rad > 0)
>   #local R_V = 0;
>   #while(R_V<360)
>     object{ Blade
>       rotate y*R_V
>   #end
> #end
