Hi all. Can someone help me understand why my translated and rotated
grass would suddenly become airborne? According to the Pov code, there
is no transformation on the y-axis, and I don't ever rotate it upwards
or downwards, either. Attached is the picture and below is the
pertinent code for the grass circle.
#declare Rad=10;
#declare R_V=0;
#declare R3 = seed (27143);
#declare R4 = seed (R3);
#declare Offset1=-67+rand(R2)*6.357;
#while(Rad > 0)
#local R_V = 0;
#while(R_V<360)
object{ Blade
translate rand(R4)*1.5+z*Rad
rotate y*R_V
#local R_V = R_V+300/Rad/10;
#local Rad = Rad - 0.5;
Download 'gardenborder.jpg' (51 KB)
Preview of image 'gardenborder.jpg'
"Ghost" <flu### [at] duratechindustries net> a écrit dans le message de news:
3F1553EE.ED12B0C7@duratechindustries.net...
In the following line
rand(R4)*1.5 is actually promoted to rand(R4)*1.5*<1,1,1>
so that you have a random <x,y,z> movement
To get it right it should be for instance <rand(R4),0,rand(R4)>
G.
http://www.oyonale.com
- Graphic experiments
- Posters
On Wed, 16 Jul 2003 08:32:30 -0500, Ghost <flu### [at] duratechindustries net> wrote:
this line means in fact
#local temp=rand(R4);
translate <temp,temp,temp>*1.5+z*Rad
which means
translate <temp*1.5,temp*1.5,temp*1.5+Rad>*1.5
so as you seen there is translation along y axis.
ABX
Actually, you are translating the grass in the y-direction, right here:
> object{ Blade
> rotate y*R_V
the statement:
will be promoted to:
translate <rand(R4)*1.5, rand(R4)*1.5, rand(R4)*1.5+Rad>
with the rand statements all being equal. You need to explicitly set the
direction that you want this translation to occur. Hope that helps!
- Nick (FitchN.com)
Ack... now I see what I did. I guess it never occurred to me that this would
happen. Oh well, now I know! Thanks guys!
> #declare Rad=10;
> #declare R_V=0;
> #while(Rad > 0)
> #local R_V = 0;
> #while(R_V<360)
> object{ Blade
> rotate y*R_V
> #end
> #end
> [Image]
