I rendered a spherical texture for an OpenGL program, I wanted to see
if the perspective would be all right when applied to a sphere in OpenGL.
The povray object is a cube with cylinders at the edges.
You can see that the perspective is pretty right, since the 3 lines are
straight (jaggy but straight).
As for the jaggyness, this is due to the fact that the image is placed
on many triangles which deform the texture to make it fit...
To get rid of the jaggyness I have 3 choices:
-Pre-deform the texture so it looks correct when deformed (This is
probably the most stupid way)
-Add a whole lot more polygons until we can't see the deformation
(This would be a good idea but would take a lot of time to render)
-Try Rohan Bernett's idea to map the SkySphere texture on a cube.
I will try the latter...
First image is a sphere mapped with my skysphere texture in POV-Ray.
Second image is a sphere mapped with my skysphere texture in OpenGL.
Note that angles of camera differ...
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Download 'pov-skysphere.jpg' (22 KB)
Download 'gl-skysphere.jpg' (50 KB)
Preview of image 'pov-skysphere.jpg'
Preview of image 'gl-skysphere.jpg'
Here are snapshots of my school project, where I used this exact same
technique.
The first image is the actual environment map rendered with POV-Ray.
The next four images are snapshots from the OpenGL program.
Download 'environment.jpg' (28 KB)
Download 'snap1.jpg' (20 KB)
Download 'snap2.jpg' (26 KB)
Download 'snap3.jpg' (23 KB)
Download 'snap4.jpg' (24 KB)
Preview of image 'environment.jpg'
Preview of image 'snap1.jpg'
Preview of image 'snap2.jpg'
Preview of image 'snap3.jpg'
Preview of image 'snap4.jpg'
Subject: Re: My GL SkySphere (~120kbu) (Was: GL SkySphere)
Date: 15 May 2003 14:11:15
Message: <3EC3D841.7E0E3E94@gmx.de>
> technique.
I suppose your system does not use high dynamic range image data. In this
situation this would be a good idea (not sure if and how this could be
handled in OpenGL though).
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
I don't understand what would be the use.
AFAIK HDRI data have only effect on reflections and global illumination.
No such things are used in the OpenGL program. When you look directly
to an unmodified HDRI image, you don't see any difference between it
and a regular image, and that's basically what is seen in the OpenGL
program: The environment map itself.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
> technique.
Very... Impressive!
I've read your code and you seem to have only 16^2 polygons for your
skySphere, am I right? Well, I have 10^2, it might explain the
jaggyness, but I do believe my code is not as optimal as yours! =)
I'm also afraid, I don't understand much of too-much-3D-geometry! Would
you let me use the function you wrote in my program, so I can show you
how I can make its use look much much more intense?
I'm currently writting a little EyeCandy program, it's much like a
screensaver, and the story goes like this: Feel the Explorer in the
Need for Speed! Two of which are two of the many symbols of a human mind.
Currenlty, I'd say I'm 40% done with this, if I could use your code for
the skysphere, I would jump to 60%.
Warp, do you agree?
Xilo
Hey, why don't we build an OpenGL game completely stuffed with povray
textures! =)
But there is reflection in your OpenGL images - surely faked somehow but
that's not the point.
Where?
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
If I didn't want you to use my code, I wouldn't have posted it in the
first place (I would have just said what I did).
> Where?
You mean the water is only the environment map?
In that case view 3 of your OpenGL samples will just look horrible in an
animation...
Date: 16 May 2003 08:39:35
Message: <3ec4dc07$1@news.povray.org>
"Xilo Musimene" <xil### [at] hotpop com> schreef in bericht
news:3EC### [at] hotpop com...
You can get 'perfect' results (without any jaggyness) if you use a skybox
instead of a skysphere. It's a little bit more complicated to make suitable
skybox-textures, but the results are faster and better.
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x) // ZK http://www.povplace.be.tf
I've been thinking about this and probably I should need to make 6
images for the skybox, right? Or should I still use the exact same
spherical camera I just used...?
Thanks,
Xilo
Good! =)
Then you will probably see a new EyeCandy on my website in a week or two!
Thanks!
Xilo
Date: 16 May 2003 21:37:38
Message: <3ec59262@news.povray.org>
skybox
suitable
no, a spherical camera won't work (at least, I don't think it will :), you
will have to make 6 perspective-views.
I did it once, maybe it's still available online, let me check :)
It *might* be this: http://sad.studentenweb.org/cg/stad.zip
But I don't know if it is just the source, or if it is compiled, or whatever
good luck anyway :)
cu!
ZK AKA SaD
"I'm spinning!"
I found it in your zip file:
void setSkyBox(GLuint texture,GLfloat helderheid){
glDisable(GL_LIGHTING);
glDisable(GL_CULL_FACE);
glBindTexture(GL_TEXTURE_2D,texture);
gluLookAt
(0.0,0.0,0.0,_lookat.getX()-_locatie.getX(),_lookat.getY()-_locatie.getY(),_lookat.getZ()-_locatie.getZ(),_up.getX(),_up.getY(),_up.getZ());
glColor4f(helderheid*2,helderheid*1.5,helderheid,1.0);
glBegin(GL_QUADS);
// Top
glTexCoord2f(1.0/4.0,1.0/3.0); glVertex3f(-1.0,1.0,-1.0);
glTexCoord2f(0.0/4.0,1.0/3.0); glVertex3f(1.0,1.0,-1.0);
glTexCoord2f(0.0/4.0,2.0/3.0); glVertex3f(1.0,1.0,1.0);
glTexCoord2f(1.0/4.0,2.0/3.0); glVertex3f(-1.0,1.0,1.0);
//Left
glTexCoord2f(2.0/4.0,2.0/3.0); glVertex3f(-1.0,-1.0,1.0);
glTexCoord2f(2.0/4.0,1.0/3.0); glVertex3f(-1.0,-1.0,-1.0);
//Right
glTexCoord2f(4.0/4.0,2.0/3.0); glVertex3f(1.0,1.0,1.0);
glTexCoord2f(4.0/4.0,1.0/3.0); glVertex3f(1.0,1.0,-1.0);
glTexCoord2f(3.0/4.0,1.0/3.0); glVertex3f(1.0,-1.0,-1.0);
glTexCoord2f(3.0/4.0,2.0/3.0); glVertex3f(1.0,-1.0,1.0);
// Far
glTexCoord2f(2.0/4.0,3.0/3.0); glVertex3f(-1.0,1.0,1.0);
glTexCoord2f(3.0/4.0,3.0/3.0); glVertex3f(1.0,1.0,1.0);
// Near
glTexCoord2f(2.0/4.0,0.0/3.0); glVertex3f(-1.0,1.0,-1.0);
glTexCoord2f(3.0/4.0,0.0/3.0); glVertex3f(1.0,1.0,-1.0);
//Bottom
glEnd();
glColor4f(1.0,1.0,1.0,1.0);
glEnable(GL_LIGHTING);
glEnable(GL_CULL_FACE);
glLoadIdentity();
But I don't really understand what texture you used... Did you paste
the six images toghether in one?
Thanks,
Xilo
Date: 17 May 2003 10:09:07
Message: <3ec64283$1@news.povray.org>
> gluLookAt
> glBegin(GL_QUADS);
> // Top
> //Left
> //Right
> // Far
> // Near
> //Bottom
> glEnd();
> glLoadIdentity();
Yes. I used a texture similar to
http://www.turbosquid.com/Previews/Content_on_4_26_2003_07_30_53/1-5-flat.jp
I believe the texture I used, is included in the zip, probably skybox.raw (I
believe it's 1024*1024*24bit, RGB, no header). If it's not included, you
can download it here: http://sad.studentenweb.org/cg/skyboxzonderflare.raw
(3MB!!)
cu!
ZK AKA SaD
"Train you will I. Train you I will. Yes! Step one: touch your tongue to
mine."
> (3MB!!)
Ok, now I understand...
But, this takes twice Video RAM as it should... the white squares are
also on the VRAM and I think it would be more optimised to use 6
different square textures...
And I was wondering what exact kind of camera you used?
Simply a normal camera with angle of 90?
Thanks,
Xilo
Date: 18 May 2003 09:00:25
Message: <3ec783e9@news.povray.org>
it would probably indeed be more efficient if you used 6 different textures
instead of 1 big, and possibly even easier, but I had to do this very
quickly (school-reasons :) and I didn't think of that :)
I believe so, yes... Let me check! :)
hmm, I don't have the POV-file here, sorry :-/
cu!
ZK AKA SaD
"I won't bite... hard."
Good!
Anyway, it's not a big problem, it's not like if there were thousand
kinds of cameras!
I'll do some tests whenever I have the time!...
Thanks a lot!
Xilo
Date: 19 May 2003 07:25:54
Message: <3ec8bf42$1@news.povray.org>
> kinds of cameras!
ok, good luck! :)
> Thanks a lot!
np :)
cu!
ZK AKA SaD
"He can breathe OK, long as nobody unplugs him"
