You might want to read my question on povray.advanced-users
concerning my trace scanning script.
The first image is the trace scan of a sphere { 0, 1}.
The second on is the trace scane of a torus { 0.7, 0.3 rotate x*90 }
Images were parsed by povray with my trace scan script, and were
rendered by a home made OpenGL application.
The bug is that the sphere and the torus are strangely scaled; normally
you should get a bunch of circles made of the dots, now you get an egg
shape...
Where does the egg shape comes from??
Here is my TraceRay function; for a given XZ point it gets all the Y
values were it hits a surface of my object.
#declare StartRay = <X,2,Y>;
#declare SurfaceTouch = StartRay;
#while(StartRay.y > -1)
#declare SurfaceTouch = trace(MyObject, StartRay, <X, -2, Y>);
#if(SurfaceTouch.x != 0 | SurfaceTouch.y != 0 | SurfaceTouch.z != 0)
#write(myFile str(SurfaceTouch.y, 0,3), " ")
#else
#declare SurfaceTouch = <0,-2,0>;
#declare StartRay = SurfaceTouch;
Thanks a lot for any help!
Xilo
Dedicated to audio/visual and interactive artwork.
Author of The Primary Colors of CSound:
http://www.geocities.com/simonlemieux/PCCS/index.html
Download 'sphere-gl.jpg' (31 KB)
Download 'torus-gl.jpg' (23 KB)
Preview of image 'sphere-gl.jpg'
Preview of image 'torus-gl.jpg'
Subject: Re: Bug in my code or in trace function? (~60kb)
Date: 10 May 2003 17:15:21
Message: <3EBD6BE9.BF2D0915@gmx.de>
Just read the manual. Apart from that it would also be advisable to check
what the trace function actually returns before jumping to quick
conclusions about bugs. If you did that you would see that all points
returned by a successful trace (which is tested differently than you do in
your code) are perfectly on the object surface.
I think we should introduce a new rule: everyone who falsely assumes there
is a bug in POV-Ray has to do something unpleasant (like 10 times
rendering the POV-Ray benchmark or so...)
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Well, I was just looking to know if that was a known problem of the
trace function, but if you tell me the trace function is not responsible
for the bug, then it is my code and it answers my question!
Thank you!
Xilo
Date: 11 May 2003 16:50:37
Message: <3ebeb79d@news.povray.org>
"Christoph Hormann" escribió..
> Christoph
but this is a good way to attract somebody attention
isn't is?
Bruno Gimeno
esto es la realidad
http://usuarios.tripod.es/game2413
I'm not sure what you exactly mean Bruno, but I was only trying to
catch attention to a problem I had with advanced-user stuff... A
problem that *might* have been a bug... Actually it Was a bug, but not
in the trace function... So the question at first still is correct (see
subject of thread!)
Xilo
this sounds like a POV2CNC comming up...
What is CNC?
Does pov2cnc already exists?
Thanks,
Xilo
