POV-Ray : Newsgroups : povray.binaries.images : Capriccio v.8 Server Time
21 Oct 2026 11:59:13 EDT (-0400)
  Capriccio v.8 (Message 1 to 13 of 13)
Subject: Capriccio v.8
Date: 7 Apr 2003 04:07:01
Message: <3E912FF5.9CC5BB1F@mail.com>
Let's start new thread :)
I added two new buildings and rearranged objects.
Gena.
Download 'capriccio.jpg' (72 KB)
Preview of image 'capriccio.jpg'
Subject: Re: Capriccio v.8
Date: 7 Apr 2003 06:25:04
Message: <web.3e9151c33e16c196b0d1d5010@news.povray.org>
>Gena.
when this gets textured it will be just wonderfull !!
maybe the possition of the farest white building is a bit strange though.
it doesn't look logical.
nice work, good luck with it
Date: 7 Apr 2003 07:26:15
Message: <3e916057$1@news.povray.org>
hey all
this looks soooo cool! it's so amazing to see how all you pov-gurus do this
one is such a short time. it would take me ages to do sth like it...
you do a really wonderful job! keep up the good work!
florian
Date: 7 Apr 2003 15:33:45
Message: <3E91D294.6D288E66@gmx.de>
The buildings look very good.
I made some try for the clouds with media - not sure whether this is a
good idea since it is slow and will lead to problems with large size
renders.
We really need a consistend lighting setup that does not get modified too
much in the future.  What is currently in the package has several flaws:
- no 'assumed_gamma 1'
- ambient_light -0.2 (should be 0.0)
- radiosity settings:
   * recursion_limit 3 (won't be feasible for the final render and is
unnecessarily slow for test runs
   * gray_threshold > 0 (not realistic)
- too large area_light for the sun
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Download 'capriccio_cloud1.jpg' (273 KB)
Preview of image 'capriccio_cloud1.jpg'
Date: 7 Apr 2003 17:44:14
Message: <3e91f12e@news.povray.org>
I was also heading for media-clouds, and I've had good
experience with using them, even with large size renders.
And it might be a good idea to render the clouds in one
pass, and image-map them later, but using the same
lighting setup.
Didn't have the time yet to begin with it, cause I'm feverishly
trying to finish my Water-Surface-Simulation...
Bit I agree on the lighting setup needing to be finalized
before attempting good clouds.
Tim Nikias v2.0
Email: Tim### [at] gmxde
> renders.
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 7 Apr 2003 20:05:09
Message: <3E92122C.41B9F322@mail.com>
I agree. Though I usually model all objects first and then set the lights.
But it doesn't work in this situation when different people work on
different objects :) So if you can please do those changes assuming
that we won't add any other buildings to the scene besides existing
place-holders. In this case you could also work with light position/shadows.
Then we could freeze that light for a while :)
I would have only the following requirements to the light(s)
- it should be warm (golden hues) to mimic XVIII century painting
  and that time of the day (around 4-6 p.m.)
- those buildings on the right side should also have some visible details
  it should not look like black hole :) Maybe we need some
  shadowless light somewhere in front of those buildings (?)
Gena.
Date: 7 Apr 2003 20:49:37
Message: <3E921FDD.9030608@alphalink.com.au>
What about simply using lighting that is as physically accurate as is
practical, say, with LightSys
(http://www.ignorancia.org/t_lightsys.php), then people can post-process
as they see fit, depending on whether they want a photographic,
painterly, alien or whatever feel to the image.
Date: 8 Apr 2003 02:49:34
Message: <3E9270FE.8545D7C5@gmx.de>
> lighting setup.
Yes, that is probably a good idea.
Date: 8 Apr 2003 02:54:18
Message: <3E927219.CE10707A@gmx.de>
Well, this project is obviously not about giving intelligent suggestions
but doing things yourself.  If you have created an appropriate lighting
using that system you should post it.
Post processing only makes sense if you apply it to a 16 bit render and
for such a cooperative project this is surely not a good idea (everyone
should be able to render the image in its final appearance).
Date: 8 Apr 2003 03:54:42
Message: <3e928042@news.povray.org>
news:3E91D294.6D288E66@gmx.de...
Oops, sorry. Those were my fault. I was trying anything I could to get it
looking like I wanted to see it (meaning only the dome part really). Wasn't
mimicking the painting with that.
About the assumed gamma though... I just can never get a nice high-contrast
image I like with 1.0 and so I always leave it out or make it similar to my
Display_Gamma. It's force of habit and so I can't adjust to it being 1.0.
Old debate, I know, so I'm not going to push the idea of not using it. I'm
just stating my opinion.
Your clouds look interesting. Shadows from the clouds might prove difficult
to impossible to set up exactly as needed, if copying the painting closely
anyway. Thing is, it seems an important aspect to match to the painting too.
Date: 8 Apr 2003 13:57:17
Message: <3E930D76.CB43C579@mail.com>
> > lighting setup.
> Christoph
If it works it would be useful to have two image maps - one low
resolution
for testing purposes and one high resolution for the final rendering.
Gena.
Date: 8 Apr 2003 14:59:32
Message: <3e931c14@news.povray.org>
That shouldn't be a problem. Just render the high resolution
one and scale it down using some image-manipulation
program. Problem is getting the first image though. That's
why the lighting needs to be finalized. Once that is done,
I'll jump onto the train.
Also, I've thought about the ships in the water. It might be
useful to use my Water-Simulation for the individual wakes
of the ships. Once they're finished, I could animate the hulls
across a surface and save those results to disk as a mesh.
These could then be rendered as a heightfield, which could
be applied to the water.
I'd have to recode a macro of mine for that, but thats no big
deal. I'm not so sure though if the heightfield could get applied
to the water that easily, or if I'd have to write a little macro which
will map the heightfield onto the water-surface.
Is it an isosurface, or a plane?
Tim Nikias v2.0
> > > lighting setup.
> > Christoph
> resolution
> Gena.
Subject: RE: Capriccio v.8
Date: 11 Apr 2003 19:00:27
Message: <3e97490b@news.povray.org>
Hi All.
I finally made a boat for Capriccio.
Textures are only for testing purposes, if someone
wants to change them, it's fine, as I'm going to
concentrate in modelling other ships (there are a lot
of them).
I also include the hamapatch file, because maybe
someone will find it useful if he/she wants to make
the man who is standing on this boat.
This one was rendered without radiosity.
Sources posted to p.b.s-f.
Bye.
Txemi Jendrix
http://www.txemijendrix.com
Download 'capriccio_boat.jpg' (80 KB)
Preview of image 'capriccio_boat.jpg'
