the attached pic shows some objects that
were created with my include file for
rounded/beveled objects -- see my post
from today in povray.binaries.scene-files.
Sputnik
e-mail: fr### [at] computermuseum fh-kiel de
Download 'round.jpg' (51 KB)
Preview of image 'round.jpg'
This looks very interesting! Many times, making rounded shapes of primitives
means lots of work.
I'm curious how your code works... I've browsed your include file and I can
see, you've done an effort to describe everything. That's very nice. But if
I may give you a suggestion? I think you need to make things clearer. For
example by breaking up the file into smaller portions, and make a few simple
toturials, with focus on simplicity for the users of your macro. At the
moment, it looks overwhelming. I would have to spend all day to figure out
the user-interface for the macros.
Anyway, assuming you've rendered these shapes in the attached picture with
primitives, your macro will be fast, and has good potential. Those shapes
would be a pain to calculate in hand... at least for me. :o)
Best regards,
Hugo
Hi Hugo,
don't hesitate to start, it's easier than you think. Only
5 macros are needed, with intuitive parameters. You'll not need
a day to understand their application, 15 minutes will suffice.
The other macros are used only internally; I've documented them
because they might be helpful elsewhere.
To trigger your learning motivation, watch the slide show --
if you had opened Brett.inc in the windows version 3.5 of POV-Ray,
you were only 3 mouse-clicks and 2 seconds away from the show:
(1) right-click on the line containing the options for the show,
(2) click on 'Copy ... to command line options',
(3) click on 'Run' -- that's all!
The modification of the variable 'Show', as described in the post
containing Brett.inc, is only used to adjust the duration of a
short pause between the pics.
... clearer ... a few tutorials ...
Oh boy, it *is* sooo easy! But OK, a tutorial and a test arena
will surely help getting started; look at my new post in the
'Round/bevel'-thread in povray.binaries.scene-files.
Please let me know if tutorial and arena enabled you to create
your first 'Brett' (for example: a square with round corners)
within the promised 15 minutes!
Sputnik
