POV-Ray : Newsgroups : povray.binaries.images : Variable radiosity parameters test (~220k) Server Time
17 Oct 2026 06:02:55 EDT (-0400)
  Variable radiosity parameters test (~220k) (Message 1 to 16 of 16)
Subject: Variable radiosity parameters test (~220k)
Date: 1 Sep 2002 12:42:48
Message: <3D724384.B9BF687F@gmx.de>
I have made some tests with variable radiosity parameters.  See
news://news.povray.org/3d6f88fa%40news.povray.org
for the discussion on this subject.
Varying count seems much more useful than varying error_bound.  It's also
possible that changing error_bound depending on the position has some side
effects that are problematic.  In any case the overhead produced by a
function based count value is much lower since the function only has to be
evaluated for every radiosity sample taken while an error_bound function
has to be called for every Compute_Ambient() call.
The following pictures show a fairly simple example.  The first is
rendered with a fixed count of 60, the second with varying count.  The
last shows the simple function used for defining the count: red means low
count (<20), yellow 20-50, blue >50.
The render times were:
 126 seconds for fixed count
 138 seconds for variable
about 13000 radiosity samples (and function VM calls), error_bound was
0.4, pretrace_start 1, pretrace_end 1/image_width, recursion_limit 2.
I think the difference is noticeable, notice especially the artefacts on
the outside of the cubicle.  Anyway the parts with low count are looking
noticably worse too and the render time is longer.  Testing with a real
scene and a better optimized function for the count value would be
important of course.
Download 'var_rad_1.png' (70 KB) Download 'var_rad_2.png' (74 KB) Download 'var_rad_fn.png' (77 KB)
Preview of image 'var_rad_1.png'
Preview of image 'var_rad_2.png'
Preview of image 'var_rad_fn.png'
Subject: Re: Variable radiosity parameters test (~220k)
Date: 3 Sep 2002 09:40:28
Message: <3D74BBC8.97037B2@gmx.de>
No comments concerning this?
At least some 'looks useful' of 'i could not think of anything this would
be needed for' would be nice.
Date: 3 Sep 2002 09:46:07
Message: <3d74bd1f$1@news.povray.org>
Okay, okay, a comment. The variable version
does look better, but how difficult is it to set?
I mean, if you simply have to add "use_variable_count on",
that's nice, but if you'd got to build a function
describing the basic layout of the scene...
Don't know.
Tim Nikias
Email: Tim### [at] gmxde
Date: 3 Sep 2002 09:49:54
Message: <m9f9nu8l72vd1ugvaq1ie3ptb51aqeo2bn@4ax.com>
On Tue, 03 Sep 2002 15:40:24 +0200, Christoph Hormann <chr### [at] gmxde>
I'm an amoteur in radiosity so not started anything, sorry
Nice colors. :-)
ABX
Date: 3 Sep 2002 10:29:20
Message: <3d74c740@news.povray.org>
OK: Some day I should also start to care about radiosity parameters --
at least to the extent that I understand your post. ;-)
Date: 3 Sep 2002 10:31:25
Message: <3D74C7B8.D77FE9DF@gmx.de>
Well, if you have a suggestion how to define the count that is easier to
set up i would be pleased to hear.  As already explained defining it on
per object basis would not be very useful.
And it's not that difficult with functions after all, you can for example
use a df3 file to describe what parts of the scene you need high count
for.
Another idea i have been thinking about is adaptive count.  This would
mean when taking a sample the program shoots a minimum number of rays,
analyzes their results and decides whether to shoot more.
Date: 3 Sep 2002 10:43:10
Message: <3D74CA7E.E59ED0AA@gmx.de>
ABX wrote:
> Nice colors. :-)
I already feared to get replies like that now, but considering radiosity
was quite commonly used recently i assumed there would be more interest in
such extensions.
Date: 3 Sep 2002 12:24:11
Message: <3d74e22b@news.povray.org>
> for.
  That's inseresting...
  ...but that would be ideal for lazy raytracers like me. I always prefer
these things to be automatic (because if they depend on my knowledge of
inner working, I'm lost).
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 3 Sep 2002 12:45:27
Message: <3d74e727@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> a écrit dans le message de news:
3D74CA7E.E59ED0AA@gmx.de...
> such extensions.
I guess that the lack of answers is due to the fact that demo doesn't show
off the benefit of it as some artefacts disappear but other come up (like
the brighter spots in the middle of the walls or on the underside of the
door). And the render time is longer too, which is an undesired effect I
suppose.
Still any idea about controlling the radiosity quality is interesting and
may prove to be valuable, so keep on trying !!! And like Jaime says, the
more automatic the better...
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 3 Sep 2002 13:51:09
Message: <3D74F68D.386A557D@gmx.de>
But it would not have the same effect.  With the demonstrated technique i
intended to give the user a tool to do something about specific artefacts
by locally increasing the count value.  The adaptive method would (if it
works, i have not tried yet) increase quality in general while not
increasing render time too much.  Without doubt this would be useful, but
it would not be a replacement for the other technique.
Date: 3 Sep 2002 13:58:33
Message: <3D74F849.D90E207@gmx.de>
> suppose.
It was just a first test mainly showing two things:
- increasing quality locally by increasing count is possible.
- there is a drawback because of increased calculation time because of the
function evaluations.
The bright sports are cased by really low count in that area (i tried to
bring down the calculation time). The Door does not look good because the
function does not take account of it.
Thanks to all for the replies BTW.
Date: 3 Sep 2002 15:58:18
Message: <3d75145a$1@news.povray.org>
I share some sentiments with the others. Automatic or a adaptive 'count'
would be the most useful to most people. But I also see your reasoning to
try and get the radiosity refined where needed most by this more direct
user-applied means. If a df3 way were possible then how would a person go
about creating it and then editing it? Render the original scene using a
sort of monochromatic media (emission-only for example) for all objects?
That couldn't be right though... it's only surfaces you'd be after. And then
I don't see any straightforward way of manipulating where to increase or
decrease the count. Object pattern seems an obvious choice, if I even knew
first that could be used for this, but there's still the question of how to
edit.
It's a nice idea but, from what I can tell, some already available settings
might do well enough when it comes to refining the radiosity results. Just a
IMHO statement there. This is a noble cause of course. I think what it comes
down to is whether or not it can be done simply enough and still be some
improvement all around. There is such a potential complexity as I see it
that only a few people would ever get real decent end results after a lot of
effort. Or maybe I'm just not seeing the whole concept right.
Date: 3 Sep 2002 18:38:34
Message: <3d7539ea@news.povray.org>
news:3D7### [at] gmxde...
> Gilles Tran wrote:
[snip of Gil's intervention]
I don't have all the technical background to help you with technical
criticism but I can forsee the interest of your studies.
About the drawback, for a complex scene it mustn't be that important since
your function could help POV-ray "focuses" on the areas that need lots of
treatment. If that function can be optimized to gain time in its treatment
is a question that I leave to you since I cannot unfortunately help you :-(
Suggestion (if you already thought about it, sorry :-))
Would it be possible to use a something like empties to pinpoint the place
we think wil require more work?
An empty is an object used in almost all modellers that present all
qualities of an object except that it doesn't appear at render time.
The POVdude could put those in the scene according to what he sees in the
test rendering that way for the final rendering your function will
automatically knows where to work.
I suppose that there must be a box attribute in POV that allow to define a
zone that will be treated (I'm reading in parrallel the POVdoc so forgive me
if I'm nuking some open doors). Each empty could be given a zone that it
represent and the function will work on those zones by pointing to the
empties.
Voilà!
Well I don't know if it makes sens but I hope that's something that could
help you by giving you a glimpse at the solution or a warning sign about the
direction not to follow ^___^
Jean-luc who has lost 800 000 neurones during that exercise -__-
Date: 4 Sep 2002 01:27:42
Message: <3d7599ce$1@news.povray.org>
> place we think wil require more work?
> the test rendering that way for the final rendering your function will
> define a zone that will be treated (I'm reading in parrallel the
> POVdoc so forgive me if I'm nuking some open doors). Each empty could
> be given a zone that it represent and the function will work on those
> zones by pointing to the empties.
> Voilà!
I never used it yet, but the object_pattern should do.
Well - function {pigment_pattern {object {...}}}, that is.
See docs: 6.7.11.23 and 6.7.11.25
E.g.
Simply declare an union with boxes covering all the area, that POV-Ray should
have a closer look, and use it as an 'object_pattern' in a function.
It seems, it's not too difficult to use Christoph's technic with those
functions...
#declare Function =
  function {
    pattern {
      pigment_pattern {
        object {
          union {
            box{...}
            box{...}
            box{...}
To Christioph: Keep it up, it's always good to have the posibilitys of
POV-Ray anhanced.
One day won't want to miss it...
cukk
Date: 5 Sep 2002 08:41:30
Message: <3D7753BB.7CB6762D@reading.ac.uk>
Hi Christoph,
Do you think you could post the source for your test scene? And whatever
rendering parameters you use? I've been tinkering with the radiosity
code too, and I'd like to see how the results compare with your images.
I've used a simple scene for testing - I'll attach the results from the
official and custom compiles as well as the scene file.
Bye for now,
	Mike Andrews.
Download 'rad_custom.jpg' (5 KB) Download 'rad_official.jpg' (5 KB) Download 'rad_tile.pov.txt' (2 KB)
Preview of image 'rad_custom.jpg'
Preview of image 'rad_official.jpg'
Date: 5 Sep 2002 09:21:22
Message: <3D775A53.CE92F83B@gmx.de>
Michael Andrews wrote:
> Hi Christoph,
I have use a slightly modified version of one of the radiosity scenes
(rad_def_test.pov) in the distribution, changes are:
- removing the cylinders loop
- adding 'box { <2, 0, 0>, <1.9, 2, 1.6> }'
- using 'ambient 2' for the sky
- using camera:
  location    <2, -4, 1.0>
  direction   y
  sky         z
  up          z
  right       1.3333333*x
  look_at     <0.0, 0.0, 1.0>
  angle       40
But for recent tests i have used a different scene anyway, this one is not
that suited for demonstrating artefact problems and way too fast for
realistic speed measurements.
