My first post to this NG. Every time I have planed to post I have seen
so brilliant images that I haven't daret to post mine. It happened
again, but this time I try to break the ice.
Suggestions please,
pto
camera{look_at y+2angle 135}box{-1 9pigment{rgb .8}finish{reflection.3
}no_image}#macro l(a)light_source{8*a rgb a/vlength(a)fade_power 2
fade_distance 3}#end l(x)l(y)l(z)l(1-x)l(1-y)l(1-z)l(x+y+z)sphere{4 3
finish{reflection 1}no_shadow}//pto
Download 'pto08.jpg' (27 KB)
Preview of image 'pto08.jpg'
I like this a lot. I especially like the water and fog aspect.
It is almost spooky....
-p
Paul D. Jones
Penn State University
814-865-2090
pdj### [at] psu edu
"pto" <oja### [at] cs helsinki fi> wrote in message
news:3D3### [at] cs helsinki fi...
> Suggestions please,
> pto
I love the lighting and reduced color palette. The image naturally puts
a lot of emphasis on the water surface. I find it is not quite
realistic when focused on. I think the waves need more peaks for one thing.
Looking great!
I love the long style of the boat and the water is looking nice and
detailed.
I would suggest maybe having the front of the centre beam (keel thing -
i'm no sailor!) extended a bit more, maybe silghtly decorative with a
hole and an iron ring through it...
sorry for the paint-over, but i think it explains what i mean ..
Download 'pto08_paintup.jpg' (8 KB)
Preview of image 'pto08_paintup.jpg'
> have seen so brilliant images that I haven't daret to post
> mine. It happened again, but this time I try to break the ice.
Welcome! :o) It's always nice to see new people here!
I understand what you mean about posting your images, once I felt the same
way about mine.. But this picture is an eye-opener, that you can be proud
of! I assume you made this with POV-Ray and it's very good indeed.
It's almost a bit too foggy, but on the other hand, the details are still
visible.. It looks realistic, and well, even a bit scaring because I wonder
if someone was recently in the boat.
Hugo
Wow! Very atmospheric.
- Kevin R.
> Suggestions please,
> pto
In article <3D3### [at] cs helsinki fi>,
Spooky...great atmosphere. Really makes you wonder what might be in the
bottom of that boat and why it is floating there. It doesn't look like a
typical computer generated image. Can't think of anything to add to
it...maybe a really dingy old ring float and rope or a brown/gray lump
in the bottom like someone under a tarp or blanket, but the image is
really fine as it is. Simple, but looks finished, it doesn't really need
more.
JPEG really killed the subtle colors and shading, going to post the
source code?
Christopher James Huff <chr### [at] mac com>
POV-Ray TAG e-mail: chr### [at] tag povray org
Whoa, nice mood... Good use of color, value, texture, etc.
I imagine a fisherman's wife might be lonely after finding out her
husband was lost at sea... Kind of sad.
> Suggestions please,
> pto
Samuel Benge
sbe### [at] caltel com
> visible..
Too foggy? I've seen fog this thick, usually when driving through the
central valley (yuck) of California.
Samuel Benge
I really like the atmosphere too!
In an attempt to see if there were any water inside the hull (are there) I
added gamma 1.9 brightness 14% and contrast 80% in paint shop pro,
and came up with the attatched image. Which I think is quite interesting,
especially the water get a certain feel to it..And you see the great amount
of detail you've put in the boat, better.
Looks great! Welcome, and keep them coming!
_.-=^=-._.-=[ Peter ]=-._.-=^=-._
_.-=[ http://hertel.no/peter ]=-._
Download 'gamma and contrast.jpg' (13 KB)
Preview of image 'gamma and contrast.jpg'
> >details are still visible..
> the central valley (yuck) of California.
Sure, it's not unrealistic but at a certain point, everyone begins to think
a *picture* is too foggy. :o) This one almost reach the limit, but doesn't
cross it, in my opinion.
However, the perceived quality of such a picture depend and rely largely on
monitors, and the surrounding light from the room in which we stand.. When
someone can't see a picture clearly; they will usually give it less credit /
praise.
Hugo
You were afraid to post this? This is *really* good.
I think it may add some realism if you tilt the boat a little; it looks too
straight for sitting in such turbulent water. Just try tilting it a little
one way or the other. If you want even more realism, you might work on the
water at the edge of the boat, make it look more like it's splashing up
against it, maybe add some little droplets of water in the air near where it
would splash.
How did you model the water? And texture it?
- Slime
[ http://www.slimeland.com/ ]
Slime wrote:
<snip>
I don't think that this style of boat tilts much, they have a very wide
and shallow keel.
Great comments, Thank you a lot - You really took effort with this one!
I planed to add "the fisherman" trying to find his way back to "the
fisherman's wife", but Your "spooky" reaction speaks against it. Perhaps
I should try to add some subtle hints and continue in that direction
(and avoid modelling of the fisherman =)) ?
There is small amount of water inside the boat, but not a lot. In have
object called water_difference that can be used to remove extra water
inside the boat.
I post the source to p.b.s.
pto
camera{look_at y+2angle 135}box{-1 9pigment{ rgb .8 }finish{ reflection
.3 }no_image}#macro l(a)light_source{8*a rgb a/vlength(a)fade_power 2
a very nice picture - for an empty boat it sit a little bit deep in the
water ...
Wolfgang
> Suggestions please,
> pto
That kind of boat with nobody on board to pump water out should embark a
good amount of water on a rough sea, so the flotability is diminished and
she sits deeper.
"Wolfgang Manousek" <wol### [at] hotmail com> a écrit dans le message de news:
3d36df38@news.povray.org...
> water ...
> Wolfgang
