POV-Ray : Newsgroups : povray.binaries.images : Hawaii from SRTM (25+21+46k) Server Time
22 Oct 2026 09:51:14 EDT (-0400)
  Hawaii from SRTM (25+21+46k) (Message 1 to 15 of 15)
Subject: Hawaii from SRTM (25+21+46k)
Date: 17 Jul 2002 05:44:37
Message: <3D353C84.D716A99A@gmx.de>
I made these images some time ago, but forgot to post them.
I used the SRTM test data available on:
ftp://edcsgs9.cr.usgs.gov/pub/data/srtm/
to make an air view of the main island of hawaii.  The height scale should
be correct, the resolution of the data is about 50 meters per pixel.
The first image has some fog and media for the atmosphere and clouds, the
second one is without.  The texture uses a combination of several slope
patterns, surely not that realistic, but getting a realistic image map of
that resolution is probably nearly impossible.
The third image shows a detail view.
Comments?
Last updated 15 Jul. 2002 _____./\/^>_*_<^\/\.______
Download 'hawaii_a.jpg' (25 KB) Download 'hawaii_b.jpg' (21 KB) Download 'hawaii_detail.jpg' (46 KB)
Preview of image 'hawaii_a.jpg'
Preview of image 'hawaii_b.jpg'
Preview of image 'hawaii_detail.jpg'
Subject: Re: Hawaii from SRTM (25+21+46k)
Date: 17 Jul 2002 05:50:33
Message: <gbfaju0padcd3lul3qr5c1if2v15b1e3mh@4ax.com>
On Wed, 17 Jul 2002 11:44:36 +0200, Christoph Hormann <chr### [at] gmxde>
nice
what is the resolution here ?
ABX
Date: 17 Jul 2002 07:41:38
Message: <3D3557F2.15E9B210@gmx.de>
The terrain is the same resolution as in the full images, the detail view
is cut from a 5000x1000 render.
Date: 17 Jul 2002 08:54:32
Message: <3d356908$1@news.povray.org>
Try that with media.  ;o)  Well the one with media looks really good. The
horisont seems too bright but the island is like a photo! This setup is not
so simple, I'm also trying something with landscapes these days, so this
image prooves your experience with landscapes!
Hugo
Date: 17 Jul 2002 12:27:20
Message: <3D359AE8.38ACE2BB@gmx.de>
No problem, thanks to 'method 3'. IIRC render time was quite reasonable
(<10 hours)
Thanks, a darker horizon usually looks quite 'dirty'.
Date: 17 Jul 2002 13:29:46
Message: <3D35A983.1020809@caltel.com>
Cool. I especially like hawaii_a.
> Comments?
> Christoph
Samuel Benge
sbe### [at] caltelcom
Date: 17 Jul 2002 21:22:18
Message: <7731097.r21fFXx3dr@3-e.net>
Can you use a lowres image map to bias a hires slope map?
Date: 18 Jul 2002 02:14:51
Message: <s0ncjuk4s2d0di7pd58lm6gf6994docmih@4ax.com>
On Wed, 17 Jul 2002 13:41:38 +0200, Christoph Hormann <chr### [at] gmxde>
Oh, I wrongly made my question. How wide in kilometers is first image? How
wide in kilometers is detail view?
ABX
Date: 18 Jul 2002 02:38:37
Message: <3D36626C.CBE78DC5@gmx.de>
Well, the island is - others may correct me - about 200 km wide.  So the
detail view in the foreground is about 20 km i would estimate.
Date: 18 Jul 2002 02:38:59
Message: <3D366283.DA30FA49@gmx.de>
Thanks.
Date: 18 Jul 2002 02:40:25
Message: <3D3662D9.CA781177@gmx.de>
I don't understand, could you explain more detailed?
Date: 18 Jul 2002 17:45:18
Message: <3D37455A.C99A8A6F@tiscalinet.de>
High!
Awesome images... as I'm also about to model some realistic landscapes, I
would like to ask you how you did the distribution of surface colors exactly -
obviously it's not a simple image map, it more looks like a Terragen scene to
me! Did you still
use 3.1 or already 3.5?
See you in Khyberspace - http://home.arcor.de/yadgar/khyberspace/index-e.html
Afghanistan Chronicle: http://home.arcor.de/yadgar/index-e.htm
Yadgar
Date: 19 Jul 2002 00:33:32
Message: <1431736.sZ7DoVzkc0@3-e.net>
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Well if you have a lowres file that you can interpolate you get a fuzzy
image map, but if you use that interpolated data to set some sort of
threshold for hires pov maps the you will get good textures, and they will
be in the correct place.
Your connection failed because: Dyslexics retyping hosts file on servers
Date: 19 Jul 2002 02:13:41
Message: <3D37AE15.2F907895@gmx.de>
I still don't understand, maybe just make an example.
Date: 19 Jul 2002 02:18:57
Message: <3D37AF50.D9E66A50@gmx.de>
Jörg 'Yadgar' Bleimann wrote:
> High!
> Awesome images...
Thanks.
> me!
As said in the first post it uses slope patterns.
>  Did you still use 3.1 or already 3.5?
Since when are slope pattern and method 3 media available in 3.1?
