![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Cool. I especially like hawaii_a.
Christoph Hormann wrote:
> I made these images some time ago, but forgot to post them.
> I used the SRTM test data available on:
> ftp://edcsgs9.cr.usgs.gov/pub/data/srtm/
> to make an air view of the main island of hawaii. The height scale should
> be correct, the resolution of the data is about 50 meters per pixel.
> The first image has some fog and media for the atmosphere and clouds, the
> second one is without. The texture uses a combination of several slope
> patterns, surely not that realistic, but getting a realistic image map of
> that resolution is probably nearly impossible.
> The third image shows a detail view.
> Comments?
> Christoph
Samuel Benge
sbe### [at] caltel com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Can you use a lowres image map to bias a hires slope map?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 17 Jul 2002 13:41:38 +0200, Christoph Hormann <chr### [at] gmx de>
wrote:
> > what is the resolution here ?
> The terrain is the same resolution as in the full images, the detail view
> is cut from a 5000x1000 render.
Oh, I wrongly made my question. How wide in kilometers is first image? How
wide in kilometers is detail view?
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, the island is - others may correct me - about 200 km wide. So the
detail view in the foreground is about 20 km i would estimate.
Last updated 15 Jul. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't understand, could you explain more detailed?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
High!
Awesome images... as I'm also about to model some realistic landscapes, I
would like to ask you how you did the distribution of surface colors exactly -
obviously it's not a simple image map, it more looks like a Terragen scene to
me! Did you still
use 3.1 or already 3.5?
See you in Khyberspace - http://home.arcor.de/yadgar/khyberspace/index-e.html
Afghanistan Chronicle: http://home.arcor.de/yadgar/index-e.htm
Yadgar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
Well if you have a lowres file that you can interpolate you get a fuzzy
image map, but if you use that interpolated data to set some sort of
threshold for hires pov maps the you will get good textures, and they will
be in the correct place.
Your connection failed because: Dyslexics retyping hosts file on servers
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I still don't understand, maybe just make an example.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> High!
> Awesome images...
Thanks.
> me!
As said in the first post it uses slope patterns.
> Did you still use 3.1 or already 3.5?
Since when are slope pattern and method 3 media available in 3.1?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
