![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I was interested in the benchmark scene, so I did a render with 1152x864
resolution.
Because of the big format I kicked the quality somewhat higher:
radiosity: count 300 (was 80)
recursion_limit 3 (was 1)
photons: spacing 0.002 (was 0.007)
It took my PIII 450 MHz 44h 32m in the background. In the beginning (first
30%)
SETI was running too!
If anyone is interested, the PNG is much better, but it is 1.48 MB.
I don't know if it is possible to attach such a big file, but I can always
try it.
Greetings,
Jaap Frank
Download 'benchmark_jjf15.jpg' (72 KB)
Preview of image 'benchmark_jjf15.jpg'
![benchmark_jjf15.jpg](/povray.binaries.images/attachment/%3C3d347613%40news.povray.org%3E/benchmark_jjf15.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jaap Frank wrote:
> Hi,
> resolution.
You dare to cut off my scene? ;-)
There is something wrong with the photons, they don't show up where they
should (i.e. in the metal ring)
Otherwise it looks good.
Last updated 15 Jul. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Jaap Frank wrote:
> > Hi,
> > resolution.
Sorry for that, but a very small render gave the impression that it just
fitted.
I started late in the evening and the following morning I saw the missing
top.
I good not bring myself to start again.
I haven't played with photons much yet, but I expected more from it either.
Maybe the settings are not optimal or the pass_through doesn't work good?
All I changed was the photon_spacing from 0.007 to 0.002.
Any hints about that (for a correct render WITH top)?
Thanks,
Greetings,
Jaap Frank
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Make sure you use version 1.02 of the benchmark scene, some earlier
version had the 'pass_through' missing for the clouds.
Last time i checked the scene photons worked. You should see the effect
quite clearly inside the metal ring.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Jaap Frank" <jjf### [at] xs4all nl> wrote:
> Hi,
> 1152x864 resolution.
Ohh - all this beauty rendered to nothing for thousends times...
cukk
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"KalleK" <kal### [at] gmx de> wrote in message news:3d39bb69@news.povray.org...
> > Hi,
> cukk
In approximately an hour the correct render with photons and the top of
the 'flask' is ready. It took nearly 3 days crawling over the pixels!
Jaap Frank
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
