POV-Ray : Newsgroups : povray.binaries.images : Black Seas Barracuda finished (link) Server Time
30 Nov 2026 13:19:25 EST (-0500)
  Black Seas Barracuda finished (link) (Message 1 to 17 of 17)
Subject: Black Seas Barracuda finished (link)
Date: 8 Jul 2002 00:17:19
Message: <3D2913A5.4010703@faricy.net>
http://davidf.faricy.net/image.php?pic=blackseasbarracuda3.jpg
The render time seems to have magically dropped for some reason...
After brightening the radiosity to make the ship show up better, I
didn't like the big bright splotch on that one sail, so I dimmed the
light from the sun, forgetting it would affect the clouds (slaps head)!
I used light_groups to get it all how I want it.  I finally added
load_file to the radiosity too so I can rerender it faster, but that's
not what made it magically speed up, since this was the render I saved
the rad data from...
BTW, all renders on my site are now shown with a black background when
you click on them.  :)
___     ______________________________________________
  | \     |_         website: http://davidf.faricy.net/
  |_/avid |ontaine           email: <dav### [at] faricynet>
Subject: Re: Black Seas Barracuda finished (link)
Date: 8 Jul 2002 00:42:01
Message: <3D29180D.80D1F79A@pacbell.net>
All I got was a black page with a "back to the gallery" link showing.
Ken Tyler
Date: 8 Jul 2002 00:52:38
Message: <3D291AAA.A6B59597@gmx.de>
Me too.
Tim Nikias
Email: Tim### [at] gmxde
Date: 8 Jul 2002 01:34:34
Message: <3D2925C0.7090305@faricy.net>
Really?  That's not good.  It works fine on my computer, in both
Netscape and IE.  There's always the image itself:
http://davidf.faricy.net/renders/blackseasbarracuda3.jpg
Date: 8 Jul 2002 01:36:50
Message: <3D292648.8000401@faricy.net>
For some reason it was not getting the pic var then.  I know the php
script works, so it must be something with how the URL is handled.
Date: 8 Jul 2002 02:58:09
Message: <3d293801$1@news.povray.org>
> I finally added load_file to the radiosity too so I can rerender
> it faster, but that's not what made it magically speed up, since
> this was the render I saved the rad data from...
That's pretty strange. You rendered this picture in a two-pass and it took
less time than earlier? Well.... How do you load the rad file? Because if
you replace the rad settings with a "load" then you don't get the same
radiosity.. I.e. the radiosity applied is not the same as when you use a
one-pass.. The saved file does not contain all information about how it
should be treated when applied to the scene.
Hugo
Date: 8 Jul 2002 11:31:54
Message: <3d29b06a$1@news.povray.org>
David:
The whole gallery appears to be broken.  Very nice images from the
thumbnails, BTW.  Please fix so we can view!
Date: 8 Jul 2002 11:46:51
Message: <3D29B461.9050001@my.email.address>
It works fine for me, and so does the rest of the gallery. I use
Netscape 6.2, but since it is php it should be browser independent.
/Ib
Date: 8 Jul 2002 13:36:55
Message: <3d29cdb7$1@news.povray.org>
As the other posters said, there is no image. I looked into the HTML
source generated by your PHP code, and found the reason: You are using
backslashes in the path to the image:
<img src=".\renders\blackseasbarracuda3.jpg">
but PHP (to be more exact, the underlying webserver) requires forward
slashes as path separators. The character sequence \r is actually a
single ASCII character (13 => Carriage return), the same is true for \b
(which is 8 => Bell). Just change this and it will work.
Timon Christl <me### [at] christltimonde>
"Hungarian Notation is the tactical nuclear weapon of source code
obfuscation techniques" -- Unknown
Date: 8 Jul 2002 13:49:26
Message: <Xns9245C920DADECraf256com@204.213.191.226>
David Fontaine <dav### [at] faricynet> wrote in
news:3D2### [at] faricynet:
Opera 6.03 crashes every time after opening this link
Rafa³ 'Raf256' Maj
Date: 8 Jul 2002 18:31:13
Message: <3D2A1411.5020503@faricy.net>
 >  \b (which is 8 => Bell). Just change this and it will work.
Hmm, it appears you're right.  I thought I had used the backslash
elsewhere, but I looked through my files and I guess I didn't.  I'll
change that and you tell me if it works.
Probably some browsers change the backslash to a forward slash, as it
worked fine for me in both IE and Netscape.  That or certain browsers
don't like the backslash.  BTW, PHP has nothing to do with it, as it
merely generates the HTML.  PHP uses C-style escape sequences, but the
PHP code had a double-backslash, resulting in HTML with one backslash.
Date: 8 Jul 2002 18:33:55
Message: <3D2A14B3.7070509@faricy.net>
That would be a client-side problem...
Date: 8 Jul 2002 18:38:17
Message: <3D2A15B9.2010100@faricy.net>
The above link should work now.  :)
Date: 11 Jul 2002 23:35:09
Message: <3D2E4FCD.7090805@faricy.net>
Hello?  Is someone going to tell me if image.php works now?  :|
Date: 12 Jul 2002 16:15:43
Message: <3D2F3995.5090903@netscape.net>
Works for me :)
-Roz
Date: 12 Jul 2002 21:46:43
Message: <3D2F87E4.70307@faricy.net>
Roz wrote:
> Works for me :)
Good!  :)
Date: 12 Jul 2002 22:15:58
Message: <3D2F8E16.A1C361CC@applesnake.net>
hehe
first one worked
second works
works
working still
-peter
Modeling slave:
"Ballet pour ma fille."
http://www.applesnake.net
