POV-Ray : Newsgroups : povray.binaries.images : double_illumination + radiosity (37.2kb jpg) Server Time
30 Nov 2026 13:47:37 EST (-0500)
  double_illumination + radiosity (37.2kb jpg) (Message 1 to 22 of 22)
Subject: double_illumination + radiosity (37.2kb jpg)
Date: 21 Jun 2002 15:23:50
Message: <3D137D2C.3080506@caltel.com>
I'm glad that POV 3.5 now supports radiosity interaction with double
illumination. When MegaPOV came out with it's double_illumination
keyword, I tried a similar experiement with no apparent effects from the
radiosity.
This is just a simple test of this interaction involving a barn made
from wood beams and fiberglass panels. Sun shines past a tall box
casting partial light onto the barn, thus simulating scattered light inside.
Questions, Comments?
Samuel Benge
sbe### [at] caltelcom
Download 'cornell's_barn.jpg' (38 KB)
Preview of image 'cornell's_barn.jpg'
Subject: Re: double_illumination + radiosity (37.2kb jpg)
Date: 21 Jun 2002 15:35:06
Message: <3d137fea@news.povray.org>
> Comments?
Sweeeet!
-Peter
Date: 21 Jun 2002 15:46:35
Message: <3d13829b@news.povray.org>
I concur with Peter. I would never have thought of that.
Date: 21 Jun 2002 17:16:18
Message: <3d1397a2@news.povray.org>
Beautiful effect! I'm gonna have to think of a scene for this :)
Corey
schitzo.y0ru.net
blob{threshold#macro _(s,i,g)#if(s)sphere{20*(i-<5,1,-10>)16,1pigment
{rgb 9}}_(s-1i+g,g)#end#end.7_(4x,x)_(2,0y)_(5y*2x)_(5x*6x)_(3<6,
1>2*x)_(2<6,2>4*x)}
Subject: different lighting (37.6kb jpg)
Date: 21 Jun 2002 17:56:07
Message: <3D13A0DF.7080900@caltel.com>
Here's a second rendering of the same scene. I placed a blue light on
the other side of the building. It passes through a plane with a fuzzy
chain-link fence texture. Recursion_limit 2 was used with slightly lower
radiosity settings to try and compensate for the increased rendering
time. It took about 44 minutes to render.
Q's, C's?
Samuel Benge
Download 'cornell's_barn2.jpg' (38 KB)
Preview of image 'cornell's_barn2.jpg'
Subject: Re: different lighting (37.6kb jpg)
Date: 21 Jun 2002 18:24:28
Message: <3d13a79c$1@news.povray.org>
I don't know why or how you are able to continue posting images of higher
quality than most of us. These are some of the best radiosity scenes I've
seen in POV!
I'm especially impressed by the apparently small amount of time you need to
code these things. You must have a lot of experience.
Hugo
Date: 21 Jun 2002 18:49:03
Message: <3d13ad5f@news.povray.org>
> inside. Questions, Comments?
Nice idea and image....
...but that's just a cheap trick, you have to use media (^&
Date: 21 Jun 2002 19:32:00
Message: <3D13B76C.2020804@caltel.com>
Corey Woodworth wrote:
> Beautiful effect!
More kudos for the POV Team :)
Hmm, what about a room with a dirty or frosted window, where only part
of the light shines through directly, and the rest is scattered? Might
be a good effect for stained-glass windows.....
Samuel Benge
Date: 21 Jun 2002 19:33:57
Message: <3d13b7e5@news.povray.org>
Wow! This one is even greater!
I'm wishing for a wallpaper which I belive would be used for a looong time
:) (or until your next pic ;-) (How about a 1024 version for my little
desktop? ;)
What hardware do you use? (fast render?)
I just have to say it again, this is great work! :)
Keep it up!
-Peter
> Q's, C's?
> Samuel Benge
Date: 21 Jun 2002 19:50:57
Message: <3D13BBDC.2000305@caltel.com>
Thanks.
> desktop? ;)
I think I can render one next time I go on a hike (when I'm home, the
only things to do are done through the computer).
P4 1.6 ghz, 256 megs ram
> Keep it up!
I will! Someday I'll even finish a scene!
Samuel Benge
Date: 21 Jun 2002 19:58:34
Message: <3D13BDA5.4000200@caltel.com>
Sure you do! A person just keeps learning new tricks and storing them
away for future use. You think of an idea or feature and expand on it.
> seen in POV!
With time you'll see more. The developers of POV(official and
unofficial) have made radiosity faster and easier to use. More people
are using it now, and more will be using it in the future.
I've been using POV since version 3.1(about 4-5 years ago?).
Samuel Benge
Date: 21 Jun 2002 20:08:47
Message: <3D13C009.2000807@caltel.com>
The problem with subsurface scattering via media is that the light still
passes through in a straight line. The light isn't made diffuse after
exiting the object, so all you get on the other side are objects that
have clean shadows. I can only imagine how long a render would take with
radiosity and media coupled together! This trick actually simulates the
effect rather accurately, as far as I can tell.
But I know you must just be kidding, because who would want another
person to endure a month-long render? ;)
Samuel Benge
Date: 22 Jun 2002 00:21:48
Message: <3d13fb5c$1@news.povray.org>
I absolutely AGREE!!!
Please post the source or render a 1152x864 version for my desktop...... :-P
And now for animation......!
Apache
POV-Ray Cloth experiments: http://geitenkaas.dns2go.com/experiments/
Email: apa### [at] yahoocom
ICQ: 146690431
Date: 22 Jun 2002 01:18:58
Message: <3D1408EC.DE08AE2C@infomagic.net>
Of course, having a fast machine helps. Your lamp image, for instance,
is apparently using fairly high-quality radiosity, with normal on, and
an area light to boot. I don't want to think about how long it would
take MY machine to render that.. or to do the requisite test renders to
make it look good.
-Xplo
Date: 22 Jun 2002 01:33:11
Message: <3D140C43.2EC6BB3E@infomagic.net>
My tests with MegaPOV show that radiosity and media don't seem to work
together in the way you imply. In fact, I'm not really sure how they
work together at all; maybe radiosity is affected by emission media or something?
I've no idea if this was fixed in 3.5.
-Xplo
Date: 22 Jun 2002 03:44:45
Message: <3D142AEC.D21A5347@gmx.de>
> radiosity.
Very neat, i never thought the effect could be that realistic.
One thing that i'm missing about double_illuminate is a possibility to
diminish the amount of light from the back surface, something like an
additional float parameter between 0 and 1. Of course for such scenes
where only the back side is visible there is no need for it.
Last updated 14 Jun. 2002 _____./\/^>_*_<^\/\.______
Date: 22 Jun 2002 10:51:20
Message: <3d148ee8@news.povray.org>
That'd be very much appreciated!
>  (when I'm home, the only things to do are done through the computer).
I know how that is ;) I just finished two more than a day long renders..
Pretty scary when you start thinking of how much time you spend in front of
the computer.. And how hard it is to do something else when you're at home
I think the pictures you posted qualify for 'scene', more than 'test'. Looks
more finished than my few finished scenes ;)
-Peter
Date: 22 Jun 2002 11:55:32
Message: <3D149DEF.5080204@caltel.com>
 From the 3.5 docs:
"Media and Radiosity
Radiosity estimation can be affected by media. To enable this feature,
       add media on to the radiosity{} block. The default is off"
Samuel Benge
Date: 22 Jun 2002 12:00:03
Message: <3D149EFD.5060002@caltel.com>
I'm with you there. Even more than that, there should be optional
double_illuminate keywords for texture_maps so you could make, for
example, realistic leaves. You could simulate the effect of variable
thickness on a very minute scale without having to use impossible media
settings.
Samuel Benge
Date: 22 Jun 2002 13:03:49
Message: <3d14adf5@news.povray.org>
Oooo... That looks photoreal in some spots...
Date: 22 Jun 2002 14:36:33
Message: <3D14C3AA.505@bellsouth.net>
Hmm, yeah...the fourty-fifth pixel in the hundred and
nineteenth row is particularly photorealistic...;)
Tim Cook
Version: 3.12
Date: 22 Jun 2002 16:54:17
Message: <3D14E425.6C1F057F@infomagic.net>
Samuel Benge wrote:
>  From the 3.5 docs:
IIRC, the MegaPOV docs made the same claim.
-Xplo
