POV-Ray : Newsgroups : povray.binaries.images : Stupid math error Server Time
22 Oct 2026 17:25:26 EDT (-0400)
  Stupid math error (Message 1 to 18 of 18)
Subject: Stupid math error
Date: 1 Apr 2002 22:49:51
Message: <3CA92AB5.8DAC1279@unforgettable.com>
Okay, this is driving me nuts. I have a bunch of 4 x .5 x 1 boxes which
are stacked corner to corner in a stair pattern. Given their layout, I
thought/assumed that they make a 30 degree angle with the ground (a
plane), but when I added another box on the side and rotated it up 30
degrees, it didn't line up with the blocks!
I'm stumped. Barring some kind of bug, I can't imagine why I'm having
this problem; the math isn't particularly complicated here. Can anyone
help me with this? Code and example image follow:
#declare stair_row = union
	#declare stair_row_members = 1;
	#declare stair_row_count = 0;
	#while (stair_row_count < stair_row_members)
		box { <0, 0, 0> <4, .5, 1> }
		#declare stair_row_count = stair_row_count + 1;
#declare stair_block = union
	#declare stair_rows = 10;
	#while (stair_row_count < stair_rows)
		object { stair_row translate <0, stair_row_count/2, stair_row_count> }
#declare stair_rail = union
	box { <0, -in, 0> <in*1, 0, 15> rotate <-30, 0, 0> }
I'm using MacMegaPOV 0.7 (I don't care for the present interface of the
official beta) on Mac OS 8.6, if anyone cares.
-Xplo
Download 'mnah2-a.jpg' (13 KB)
Preview of image 'mnah2-a.jpg'
Subject: Re: Stupid math error
Date: 1 Apr 2002 23:11:19
Message: <3ca92f67$1@news.povray.org>
The angle between the horizontal and the diagonal of a box with width 1 and
height .5 is
arctan(.5/1) = 26.56505117
The *sine* of 30 is 1/2. Not the tangent. If the *diagonal* had a length of
1, and the box had a height of .5, then the angle would be 30 degrees.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 1 Apr 2002 23:13:01
Message: <3ca92fcd@news.povray.org>
Instead of .5 use the tangent of your desired angle (30) for your y value. Since, your
z value is equal to (1) this will work
(unless I just got a giant case of stupid going).
.5773503
Grim
Date: 1 Apr 2002 23:25:16
Message: <3ca932ac@news.povray.org>
Oops, you'll have to change your translation of the steps in the y-direction by that
same value times your stair_row_count, in order
for this to work out.
Grim
Date: 1 Apr 2002 23:32:22
Message: <3CA934B1.FC270467@unforgettable.com>
> height .5 is
Doh!! Stupid trig functions, I always get them mixed up.. could have
sworn it was sine I wanted.
Thanks a lot.
-Xplo
Date: 1 Apr 2002 23:59:34
Message: <3ca93ab6$1@news.povray.org>
"Xplo Eristotle" <inq### [at] unforgettablecom> wrote in message
news:3CA92AB5.8DAC1279@unforgettable.com...
> #end
> #end
> -Xplo
Perhaps because the tangent of 30 degrees is about 0.577350269, not 0.5 ?
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Date: 2 Apr 2002 00:02:28
Message: <3ca93b64@news.povray.org>
D'oh !  Figures someone else would get the answer to you before I did.  Oh, well.
Robert Chaffe
Date: 2 Apr 2002 13:00:14
Message: <3ca9f1ae@news.povray.org>
There's a pretty good way to remember this. It worked for me, and has for two decades.
sine = opposite/hypotenuse (oh)
cosine = adjacent/hypotenuse (ah)
tangent = opposite/adjacent (oa)
Grim
Date: 2 Apr 2002 13:19:06
Message: <3ca9f61a@news.povray.org>
"GrimDude" <vos### [at] gulfnet> wrote in message news:3ca9f1ae@news.povray.org...
decades.
     You mean "SOHCAHTOA"?  I learnt that at school. I used to be good at trig. with a
tables book... (still got it),  wish I kept
it up...
     I used to play the trumpet fairly good too, but time winds on.
       <sniff>
       ~Steve~  ;)
> Grim
Date: 2 Apr 2002 15:36:18
Message: <3CAA1645.34E2D335@scifi-fantasy.com>
> at trig. with a tables book... (still got it),  wish I kept it up...
I still find it easier to picture, at least, using vectorised versions.
e.g.
x = r*COS(t)
y = r*SIN(t)
t = TAN-1(x/y)
r = SQRT((x^2)+(y^2))
Tim Cook
Version: 3.12
Date: 2 Apr 2002 17:15:07
Message: <3caa2d6b@news.povray.org>
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3CAA1645.34E2D335@scifi-fantasy.com...
> e.g.
> x = r*COS(t)
> y = r*SIN(t)
> t = TAN-1(x/y)
     Tim, sorry, I'm now lost with this... I recognise it though. I think our teacher
showed us the same?
    I could do with someone taking me through the basics again... Are you game? I'd
appreciate it.
   If it's ok, mail me or take me through it here, either way, no probs. I used to
enjoy doing trig. when I was younger.
     ~Steve~
> Tim Cook
> http://empyrean.scifi-fantasy.com
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 2 Apr 2002 18:01:29
Message: <3CAA384B.F4BF1CB8@scifi-fantasy.com>
25ct wrote:
> "Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote:
> > I still find it easier to picture, at least, using vectorised'
> > versions.
> > e.g.
> > x = r*COS(t)
> > y = r*SIN(t)
> > t = TAN-1(x/y)
> our teacher showed us the same?
> you game? I'd appreciate it.
No problemmo.  I actually found vectors to be enjoyable.  Probably
the only part of math in high school I ever did like.  (Actually, I
originally was taught vectors in Physics, but...)
(Side note:  I use the right-hand rule, so Y is north, X is east)
+Y
|   . endpoint (distance r from origin)
| /., angle (theta)
+-------- +X
If you think about the vector in terms of x & y, you realise that
it's the hypoteneuse of a right triangle whose base and perpendicular
side are the axes.  So.  You get a right triangle:
 r  /  | y
  /   _|
o------+
   x
Something about r: it's a radius of a circle with centre at o.
(Which is why I use 'r'.  The only reason I point this our is
'cuz when you rotate an object around a point, the other end
is going in a circle, and the angle is how far it's turned.)
Anyways.  If you know the angle and radius (as with velocity
vectors), the length of x is equal to the radius times the
cosine of the angle.  The length of y is equal to the radius
times the sine of the angle.  If you know x and y and want
to find the radius, use the Pythagorean theorem: a^2 + b^2 = c^2
(or, radius equals square root of x squared plus y squared).
The angle is the arctangent of x divided by y.
Vector addition simply strings together several vectors and
figures out the vector between start/end points.
This is helpful for making a CSG of a box of arbitrary size.
If I have a box at 0,0,0 and it has a scale of 1,2,0.5 and
I want to cut it in half diagonally along the xz surface,
how big do I need to make the differencing box, and how much
does it need to be rotated?  I know X and Y.  So.  It needs
to be SQRT((1^2)+(0.5^2)) along its x axis, or 1.11803399.
It needs to be rotated TAN-1(1/0.5), or 63.4349488 degrees.
Tim Cook
Version: 3.12
Date: 2 Apr 2002 18:26:20
Message: <3caa3e1c$1@news.povray.org>
I was taught a simple rhyme a very long time ago and it stuck.
Silly Old Harry (S=O/H)
Caught A Herring (C=A/H)
Trawling Off America (T=O/H)
Daft, but it works for me.
Dave
Date: 2 Apr 2002 19:39:55
Message: <3caa4f5b@news.povray.org>
news:3CAA384B.F4BF1CB8@scifi-fantasy.com...
<cut and pasted into notepad>
  Thanks 'very' much Tim, I'm working through this.
     BR,
    ~Steve~
> Tim Cook
> Version: 3.12
Date: 2 Apr 2002 21:47:36
Message: <3caa6d48$1@news.povray.org>
Except that Trawling off American would be (T-O/A)
Grim
Date: 3 Apr 2002 02:20:18
Message: <86blau4lu3ng4grid4v1skspsdhosbgcsm@4ax.com>
Hi Dave Brickell, you recently wrote in povray.binaries.images:
The rhyme I was taught only listed the ratios since we could rememeber
the order sin, cos, tan. It went like this:
Old Henry
And His
Old Aunt
I still use it everytime I need to figure an angle out :-)
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 3 Apr 2002 03:29:23
Message: <3caabd63@news.povray.org>
Yeah I spotted my error as soon as I posted it yet I did not spot it when I
read it through twice before posting it. I am sure this is some kind of
phenomenon as it has happed to me before.
Date: 3 Apr 2002 11:57:06
Message: <MPG.1715388ed650ea6c989b15@news.povray.org>
On Wed, 3 Apr 2002 00:22:47 -0800, Dave Brickell wrote...
The Cat Sat
On An Oven
And Howled Horribly
TCS     Tan = Opposite/Adjacent
OAO  =  Cos = Adjacent/Hypotenuse
AHH     Sin = Opposite/Hypotenuse
Is how I remember it.
Jamie.
