POV-Ray : Newsgroups : povray.binaries.images : Help I need it Server Time
6 Jun 2026 07:18:35 EDT (-0400)
  Help I need it (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: Help I need it
Date: 15 Mar 2002 01:43:23
Message: <hyu$jGAjcZk8Ew+c@econym.demon.co.uk>
Wasn't it Flaming Monarch who wrote:
>Hi all I need some help making some shapes,
>I'm trying to kane an octahedron without taking a box and cutting off
>edges, as I later want to make a regular dodecahedron and an icosahedron.
>I finally found the prisim and it makes good stuff for other things but
>i'm still new and cant find how to make the shapes above thanks for the
>help!
#include "shapes2.inc"
object {Octahedron}
Mike Williams
Gentleman of Leisure
Date: 15 Mar 2002 04:55:09
Message: <3C91C58E.977FB886@sw-tech.com>
> help!
I made (by way of reinventing the wheel, apparently) a "platonic.inc" file
that has the solids, vertices and edges for all five of the Platonic
Solids.  If you want it, drop me an email.  If you'd rather do it yourself,
don't drop me an email.  Either way is fine with me.  :)
Deaken
Date: 15 Mar 2002 08:30:40
Message: <3c91f780$1@news.povray.org>
> #mesh {
Good idea, but where did you get the idea that mesh had a hash-mark?  If you
have the beta than you would be better off with a  mesh2 with all the
corners.
Date: 15 Mar 2002 09:12:37
Message: <3c920155$1@news.povray.org>
RAY <RAY### [at] yahoocom> wrote in message news:3c91f780$1@news.povray.org...
Just a type. I never use "mesh 1" and am used to putting the hash in front
of mesh2. I'm not sure if it is necessary there either.
> If you
> corners.
Mesh2 would of course be preferable, but the syntax is not as clear to a
beginner like Flaming Monarch.
 -Shay
Date: 15 Mar 2002 12:29:59
Message: <3C922F9A.4070303@gates.com>
Thank you all for your suggestions
and thanks to everyone for not overloading my limited pov brain with big
complex codes thankyou all!
Date: 15 Mar 2002 13:05:53
Message: <slrna94670.j9k.steve@zero-pps.localdomain>
225k Mar 15 15:45 Shapes for Conn.bmp
Taht's a bit much for a test object scene, try .jpg.
I hope you cancel this post that contains the bmp file.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 15 Mar 2002 16:18:39
Message: <3C926531.3070002@gates.com>
srry dude next time Ill make sure that its jpg
Date: 15 Mar 2002 16:24:15
Message: <3C926680.3090301@gates.com>
have I seen your work on a website somewhere?
its good
however I had to edit it to make it work something was wrong with the
glass texture
>>help!
> Deaken
Date: 16 Mar 2002 00:19:39
Message: <3C92D695.E428BDE@sw-tech.com>
I doubt it.
> its good
I believe the expression is "jaa, mata ne".  :)
> glass texture
Really?  What went wrong with it?  Oh, wait.  Are you using a beta?  That
glass texture is taken from 3.5b9.  If you're using something earlier, it
probably won't work.
Deaken
Date: 17 Mar 2002 15:52:51
Message: <3C950222.7070706@gates.com>
I'm not sure what version it is but I fixed it by cancling out the glass
texture and changing the .inc file
it was just the normal name and I added a bit to the end
no biggy
still looks great
> I doubt it.
>>its good
>>glass texture
> Deaken
