POV-Ray : Newsgroups : povray.binaries.images : Mountains (68kbu) Server Time
17 Oct 2026 23:25:26 EDT (-0400)
  Mountains (68kbu) (Message 1 to 5 of 5)
Subject: Mountains (68kbu)
Date: 18 Feb 2002 12:01:29
Message: <3C713320.503F6D88@spiritone.com>
The Water is based on Christoff Horman's water tutorial, and the stars
are from the standard stars.inc. The mountians are pure-POV. I'm having
a few issues with the scene so far:
Is the scale of the ship beleivable?
I can't get the trees on the mountains to show up better in the dim
light. I'm not sure if upping their ambient value will do what I want,
since they should only be lit from the left.
I hope the image isn't too dark. I rendered it on a Mac and it should be
dark, but not too dark to see any details.
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
Download 'mountains.jpg' (67 KB)
Preview of image 'mountains.jpg'
Subject: Re: Mountains (68kbu)
Date: 18 Feb 2002 12:19:44
Message: <3C7137AE.4916A2FF@gmx.de>
What ship? ;-)
I think the scale is right.
Have you tried radiosity?
The trees look a bit like 'lego'.
It's fairly bright here, maybe you should show a version without gamma
correction so everyone can adjust it for his individual monitor
characteristic.
The mountain on the left looks interesting, how was it done?
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 18 Feb 2002 12:26:37
Message: <3c71394d$1@news.povray.org>
"Josh English" <eng### [at] spiritonecom> wrote in message
news:3C713320.503F6D88@spiritone.com...
<snip>
The trees don't look right - they seem very two dimensional, the base trunk
(i.e. the trunk w/o foliage) seems to long, and in general they seem too
regular. Also, IMHO, they are scaled about *2 larger than I would expect.
I noticed working on my current IRTC entry that it is hard to get away with
simple fir trees even at a great distance.
Date: 19 Feb 2002 11:44:32
Message: <3C7280CC.1A1FC66A@spiritone.com>
> What ship? ;-)
Yep. It washed out all the colors towards a dull brown. Even the clouds
were tinted brown. I can't get the hang of the new radiosity features yet.
They are a simple macro: two cones and a little random turbulence on the
second cone. I'd like to make them a bit more detailed, but there's a
lot of them and I'm worried about memory consumption (Granted, I just
got a RAM boost so I shouldn't have as many problems now)
> characteristic.
I used assumed gamma 1.2 for that render. I forgot to set it back to
1.0. It didn't make any difference on my screen.
Both the mountain peak and the range were the result of an experiment. I
was trying to develop a more realistic background for the IRTC animation
entry I am working on and a happy accident led me to develop this scene,
which I've had in my head for some time. I'd like to say it was
completely done in POV-Ray, but the ship body is an intersection of
three height-fields.
Here is the mountain code:
#declare Peak =
height_field {
      function 400,400 {
            boxed scale 0.45 translate <0.5,0.5,0> turbulence 0.2
octaves 7 lambda 2.1
            poly_wave 2.5 } }
      //water_level 0.001
      translate <-0.5,0,-0.5>
      pigment { slope { <-3,-10,0> 0 0.5 }
                color_map { [0 Tan ] [0.5 Brown ] [0.51 White*2 ] [1.0
White*2] }}
      rotate 30*y
      scale <3,1.5,3>*40
      translate <-50,-1.001,100>
#declare MountainRange =
height_field {
      function 600,600 {
            cylindrical scale 0.40 translate <0.5,0.5,0> turbulence 0.3
            poly_wave 2.0 } }
      //water_level 0.001
      pigment { slope { <1,-10,0> 0 0.5 }
                color_map { [0 Tan ] [0.5 Brown ] [0.5 White*2 ] [1.0
White*2] }}
      rotate 90*y
      scale <-8,1.2,3>*40
      translate <00,-1.001,110>
After plugging the function into a height field I went all out and also
used slope patterns for the first time.
Josh English
Date: 19 Feb 2002 11:46:06
Message: <3C728133.756767D4@spiritone.com>
> <snip>
I'm finding out that it isn't very satisfying. I could alter the heights
quite easily for each tree. I'll try scaling them down a bit.
Thanks
Josh English
