POV-Ray : Newsgroups : povray.binaries.images : Almost Sphere Spirals (109 KB) Server Time
24 Nov 2026 00:30:41 EST (-0500)
  Almost Sphere Spirals (109 KB) (Message 1 to 24 of 24)
Subject: Almost Sphere Spirals (109 KB)
Date: 24 Jan 2002 17:34:05
Message: <3C508AF7.260EBD52@hotmail.com>
I'm not sure if this image is finished
or not now.
What do you think ?
Should I change something ?
I should probably mention that I had
to "hand correct" the finished image
somewhat at the sphere's "south pole".
(Because there seems to be some
calculations that are not calculated
correctly by POV-Ray. Increasing
max_gradient or accuracy did not help
at all.)
I have also used Micrografx Picture
Publisher to increase the contrast a
little.
Tor Olav
Download 'riemann16_.jpg' (109 KB)
Preview of image 'riemann16_.jpg'
Subject: Re: Almost Sphere Spirals (109 KB)
Date: 24 Jan 2002 18:22:38
Message: <3c50973e@news.povray.org>
All it needs is a guy looking up at it. Make him so small that he can be
mistaken for a spot, then you notice the shadow and the scale suddenly
shifts...
Date: 24 Jan 2002 18:49:52
Message: <3c509da0@news.povray.org>
Fantastic, I like the image just as it is.
Congratulations,
Fernando.
Date: 24 Jan 2002 19:01:28
Message: <3c50a058@news.povray.org>
> at all.)
If you defined the spiral correctly, that's because the spiral never ends,
the detail increases towards the poles infinitely. That is, if I understood
the description of the shape that I read a while ago correctly.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 25 Jan 2002 00:59:10
Message: <3C50F653.C48210C0@pobox.com>
Tor Olav:
> > at all.)
Slime:
> never ends, the detail increases towards the poles infinitely.
> That is, if I understood the description of the shape that I
In an equiangular spiral (reverse Mercator projection of oblique
parallels), that would happen at both poles; TOK said only one.
What's the formula?
(Love the textures.)
          --  Anton Sherwood  --  http://www.ogre.nu/  --
"If nobody said anything unless he knew what he was talking about,
a ghastly hush would descend upon the earth."  ---Sir Alan Herbert
Date: 25 Jan 2002 02:35:43
Message: <3C510AC8.CB9FABE3@gmx.de>
> or not now.
> What do you think ?
If that surface structure is a normal you could make it part of the
isosurface geometry.  Apart from that, do you have 'normal on' in
radiosity?
> at all.)
I think it's quite obvious that spiral structures lead to infinite
gradients which can't be rendered correctly under all circumstances.
Date: 25 Jan 2002 05:51:07
Message: <3c51389b@news.povray.org>
Looks nice.
Will it form a whole sphere when combined
with the y-rotated other textured one?
Gleb
"Tor Olav Kristensen" <tor### [at] hotmailcom> wrote in message
news:3C508AF7.260EBD52@hotmail.com...
> What do you think ?
Date: 25 Jan 2002 10:00:51
Message: <3c517323@news.povray.org>
"Tor Olav Kristensen" wrote in message
> or not now.
> What do you think ?
Nice image.
> at all.)
I tried to render your scene file posted in p.t.s-f
last month.  But I could not find any problem
on the image.  Did you use the same function?
R. Suzuki
Date: 25 Jan 2002 17:21:06
Message: <3c51da52@news.povray.org>
"R. Suzuki" <r-s### [at] aistgojp> escribió en el mensaje
news:3c517323@news.povray.org...
Sorry, this has nothing to do with the question, but I wanted to ask you
something:
Today I have had a problem with a file you sent to p.t.s.f. (Iso quilt and
Carpet: 3 torii) in november 2001.
If I render it, I only obtain 2 torii and a black background.
I wanted the iso carpet for an imagen I'm working on, but it seems like it
has dissapear.
Maybe it's caused by the beta versions.
(AMD Athlon 600 Mhz, Win 98SE, Povray for Windows 3.5 beta 10).
Any help?
Thanks in advance.
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Subject: Re: Almost ... Iso carpet
Date: 26 Jan 2002 03:05:11
Message: <3c526337@news.povray.org>
"Txemi Jendrix" wrote ..
> something:
> has dissapear.
Yes, it is caused by the syntax change.  I posted the revised one
in p.t.s-f as a reply of that message.  (I've added checker and hexagon
pattern in that scene)  I hope it is helpful for your project.
R. Suzuki
Date: 26 Jan 2002 09:37:06
Message: <3C52BE54.B91AC28A@hotmail.com>
> shifts...
Thank you for the idea Bill. I'm thinking
about how where I can get a human model from.
Tor Olav
Date: 26 Jan 2002 09:39:57
Message: <3C52BEFE.346A4C0A@hotmail.com>
> Congratulations,
I'm very glad you like it Fernando.
Thank you.
Tor Olav
Date: 26 Jan 2002 10:00:56
Message: <3C52C3E7.264794C2@hotmail.com>
Gleb wrote:
> Looks nice.
Thanks.
No. I'm sorry if the title of my prior
posts have confused you people.
This shape uses another PhiFn() than the one
I used for the shape in my "The remains of an
iso sphere: Take 2" image.
I think that I'll soon post some source code
for this image to p.t.s-f.
Tor Olav
Date: 26 Jan 2002 10:01:21
Message: <3c52c4c1@news.povray.org>
news:3c526337@news.povray.org...
Wow!
Thank you very much.
Bye.
Txemi Jendrix
Date: 27 Jan 2002 13:10:27
Message: <3C544294.A02EFA5C@earthlink.net>
that would be great i would like to see the texture details... =]
> Gleb wrote:
> > Looks nice.
> Thanks.
> Tor Olav
Date: 27 Jan 2002 20:32:16
Message: <3C54A942.617AD2B5@online.no>
> at all.)
Attached are two images that shows
the defect in the shape.
IIRC Riemann16_s1.jpg was rendered with the
it was set to 250.
(The images was rendered at different
resolutions and with different light settings.)
I find the "tongue" that appears in the _s2
image quite mysterious.
Tor Olav
Download 'riemann16_s1.jpg' (13 KB) Download 'riemann16_s2.jpg' (5 KB)
Preview of image 'riemann16_s1.jpg'
Preview of image 'riemann16_s2.jpg'
Date: 27 Jan 2002 20:43:07
Message: <3C54ABD4.95EB6DCA@online.no>
> radiosity?
I didn't think of that. Now I have started experimenting
with that. Thank you for the suggestion.
And yes, I had the normal on in radiosity.
> > at all.)
Yes that was my first thought too.
But as this shape is symmetric around both
its x and z axes (as Anton Sherwood mentioned
too), there should be infinite gradients at
the opposite pole as well.
But I have not experienced any problems at
that pole yet.
Tor Olav
Date: 27 Jan 2002 20:59:09
Message: <3C54AF97.66DDFC9C@hotmail.com>
Anton Sherwood wrote:
> Tor Olav:
> > > at all.)
> Slime:
I don't remember what reverse Mercator projection is,
so I don't quite get what you are saying here.
But I guess that you are thinking the same as me:
That the problem should surface at the other pole as
well, because the gradients should be symmetric too.
> What's the formula?
I have posted the source to povray.text.scene-files now:
http://news.povray.org/povray.text.scene-files/21784/
news://news.povray.org/3C549C14.A9009E4%40online.no
I just modified one that Gilles Tran once made.
"Radiosity test #2", Aug 2000:
http://news.povray.org/search/?s=Radiosity+test+%232&b=Search
Tor Olav
Date: 27 Jan 2002 21:05:24
Message: <3C54B10F.6C11F8A8@hotmail.com>
> > or not now.
> > What do you think ?
> Nice image.
Thank you.
> > at all.)
You are right: The last scene file did not
produce any errors in the image.
For this image a used a different function
for the rotation. See my recent post to
povray.text.scene-files for the source code:
Tor Olav
Date: 28 Jan 2002 11:08:18
Message: <3c557772@news.povray.org>
"Tor Olav Kristensen" <tor### [at] onlineno> wrote in message
news:3C54A942.617AD2B5@online.no...
[snip]
> Tor Olav
Perhaps this defect is only on the inner surfaces so the upper pole
looks OK from outside?
Alf
Date: 28 Jan 2002 14:33:05
Message: <3C55A76B.7ECFA627@gmx.de>
> that pole yet.
Well, there's no guarantee that insufficient max_gradient leads to
artefacts.
To avoid such problems you could cut off the spirals at some distance to
the poles, it would probably not be very visible and should solve the
problem.
Date: 29 Jan 2002 03:29:35
Message: <3C565CA8.BF44B3C6@hotmail.com>
> [snip]
> > Tor Olav
Alf, the defect is visible on the outside too.
I have actually turned the shape upside down
so that the defect should be less visible.
(I.e. in the shadows inside.)
Tor Olav
Date: 29 Jan 2002 09:37:14
Message: <3c56b39a@news.povray.org>
news:3C565CA8.BF44B3C6@hotmail.com...
pole
Sorry. My error. I understood you only had a problem with the one
pole.
Alf
Date: 2 Mar 2002 17:15:28
Message: <3C81515F.CC248432@pobox.com>
> > parallels) . . .
I meant inverse: from the plane back to the sphere.
Anton Sherwood, http://www.ogre.nu/blog/blog.htm
