POV-Ray : Newsgroups : povray.binaries.images : Almost Sphere Spirals (109 KB) Server Time
6 Jun 2026 15:46:10 EDT (-0400)
  Almost Sphere Spirals (109 KB) (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Almost Sphere Spirals (109 KB)
Date: 26 Jan 2002 09:37:06
Message: <3C52BE54.B91AC28A@hotmail.com>
Bill DeWitt wrote:
>     All it needs is a guy looking up at it. Make him so small that he can be
> mistaken for a spot, then you notice the shadow and the scale suddenly
> shifts...
Thank you for the idea Bill. I'm thinking
about how where I can get a human model from.
Tor Olav
Date: 26 Jan 2002 09:39:57
Message: <3C52BEFE.346A4C0A@hotmail.com>
> Fantastic, I like the image just as it is.
> Congratulations,
I'm very glad you like it Fernando.
Thank you.
Tor Olav
Date: 26 Jan 2002 10:00:56
Message: <3C52C3E7.264794C2@hotmail.com>
Gleb wrote:
> Looks nice.
Thanks.
> Will it form a whole sphere when combined
> with the y-rotated other textured one?
No. I'm sorry if the title of my prior
posts have confused you people.
This shape uses another PhiFn() than the one
I used for the shape in my "The remains of an
iso sphere: Take 2" image.
I think that I'll soon post some source code
for this image to p.t.s-f.
Tor Olav
Subject: Re: Almost ... Iso carpet
Date: 26 Jan 2002 10:01:21
Message: <3c52c4c1@news.povray.org>
news:3c526337@news.povray.org...
> Yes, it is caused by the syntax change.  I posted the revised one
> in p.t.s-f as a reply of that message.  (I've added checker and hexagon
> pattern in that scene)  I hope it is helpful for your project.
Wow!
Thank you very much.
Bye.
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Date: 27 Jan 2002 13:10:27
Message: <3C544294.A02EFA5C@earthlink.net>
that would be great i would like to see the texture details... =]
Tor Olav Kristensen wrote:
> Gleb wrote:
> > Looks nice.
> Thanks.
> Tor Olav
Date: 27 Jan 2002 20:32:16
Message: <3C54A942.617AD2B5@online.no>
> (Because there seems to be some
> calculations that are not calculated
> correctly by POV-Ray. Increasing
> max_gradient or accuracy did not help
> at all.)
Attached are two images that shows
the defect in the shape.
IIRC Riemann16_s1.jpg was rendered with the
it was set to 250.
(The images was rendered at different
resolutions and with different light settings.)
I find the "tongue" that appears in the _s2
image quite mysterious.
Tor Olav
Download 'riemann16_s1.jpg' (13 KB) Download 'riemann16_s2.jpg' (5 KB)
Preview of image 'riemann16_s1.jpg'
Preview of image 'riemann16_s2.jpg'
Date: 27 Jan 2002 20:43:07
Message: <3C54ABD4.95EB6DCA@online.no>
Christoph Hormann wrote:
> If that surface structure is a normal you could make it part of the
> isosurface geometry.  Apart from that, do you have 'normal on' in
> radiosity?
I didn't think of that. Now I have started experimenting
with that. Thank you for the suggestion.
And yes, I had the normal on in radiosity.
> > I should probably mention that I had
> > to "hand correct" the finished image
> > somewhat at the sphere's "south pole".
> > at all.)
> I think it's quite obvious that spiral structures lead to infinite
> gradients which can't be rendered correctly under all circumstances.
Yes that was my first thought too.
But as this shape is symmetric around both
its x and z axes (as Anton Sherwood mentioned
too), there should be infinite gradients at
the opposite pole as well.
But I have not experienced any problems at
that pole yet.
Tor Olav
Date: 27 Jan 2002 20:59:09
Message: <3C54AF97.66DDFC9C@hotmail.com>
Anton Sherwood wrote:
> Tor Olav:
> > > at all.)
> Slime:
> > If you defined the spiral correctly, that's because the spiral
> > never ends, the detail increases towards the poles infinitely.
> > That is, if I understood the description of the shape that I
> > read a while ago correctly.
> In an equiangular spiral (reverse Mercator projection of oblique
> parallels), that would happen at both poles; TOK said only one.
I don't remember what reverse Mercator projection is,
so I don't quite get what you are saying here.
But I guess that you are thinking the same as me:
That the problem should surface at the other pole as
well, because the gradients should be symmetric too.
> What's the formula?
I have posted the source to povray.text.scene-files now:
http://news.povray.org/povray.text.scene-files/21784/
news://news.povray.org/3C549C14.A9009E4%40online.no
> (Love the textures.)
I just modified one that Gilles Tran once made.
"Radiosity test #2", Aug 2000:
http://news.povray.org/search/?s=Radiosity+test+%232&b=Search
Tor Olav
Date: 27 Jan 2002 21:05:24
Message: <3C54B10F.6C11F8A8@hotmail.com>
"R. Suzuki" wrote:
> "Tor Olav Kristensen" wrote in message
> > I'm not sure if this image is finished
> > or not now.
> > What do you think ?
> Nice image.
Thank you.
> > at all.)
> I tried to render your scene file posted in p.t.s-f
> last month.  But I could not find any problem
> on the image.  Did you use the same function?
You are right: The last scene file did not
produce any errors in the image.
For this image a used a different function
for the rotation. See my recent post to
povray.text.scene-files for the source code:
Tor Olav
Date: 28 Jan 2002 11:08:18
Message: <3c557772@news.povray.org>
"Tor Olav Kristensen" <tor### [at] onlineno> wrote in message
news:3C54A942.617AD2B5@online.no...
[snip]
> Tor Olav
Perhaps this defect is only on the inner surfaces so the upper pole
looks OK from outside?
Alf
