POV-Ray : Newsgroups : povray.binaries.images : Rad with Kari-lights Server Time
24 Nov 2026 00:30:41 EST (-0500)
  Rad with Kari-lights (Message 1 to 15 of 15)
Subject: Rad with Kari-lights
Date: 22 Jan 2002 18:01:52
Message: <3C4DEB04.EFB5122@yahoo.com.au>
I saw Kari Kivisalo's suggestions to Tim Nikias on realistic light fading and
gave it a quick go. I set up two identical rooms and a doorway. In one room, a
light was placed slightly lower than the ceiling, but higher than the doorway
height. This light was square and used 25 spotlights are per Kari's suggestions.
I used radiostity with a recursion limit of 5 (probably a little excessive) and
here are the results.
    One is a shot from within the lit room. The other is the same shot, but from
within the unlit room. The imperfect soft shadows are caused by the set up of the
pseudo area-light. No post process was performed.
    I suggest we call these wonderful lights Kari-lights in honour of their
inventor :-)
MJL
light_source{9*(y#macro A(H,B,R,T)prism{0,1H+4,0u*9,9v*9,0#local I=1;#while(I<H)
#local V=asc(substr(B,I,1))-33;<div(V,10)mod(V,10)>#local I=I+1;#end pigment{rgb
y}rotate-<90,R>translate-T}#end-z)rgb 9}A(14",6;MWmhryXN3,"60<15,0,8>)box{-99(x+
z)*99pigment{rgb 1}}fog{distance 11}camera{location(y-z)*25look_at 0}A(8"6hiAG=6
"-60x*-10)A(16"/.@VZno=<PLA89/"0x*5) // MJL
Download 'rad_room_b.jpg' (20 KB) Download 'rad_room_a.jpg' (17 KB)
Preview of image 'rad_room_b.jpg'
Preview of image 'rad_room_a.jpg'
Subject: Re: Rad with Kari-lights
Date: 22 Jan 2002 18:34:48
Message: <3c4df718$1@news.povray.org>
Great!
Pretty cool!
I like it a lot!
Best regards
Date: 22 Jan 2002 18:44:17
Message: <slrna4rtmh.c7s.steve@zero-pps.localdomain>
Lighting is great as you say, but the door way is far too wide.
                                             or http://start.at/zero-pps
 11:33pm  up 106 days, 15:22,  1 user,  load average: 1.06, 1.11, 1.11
Date: 22 Jan 2002 19:11:06
Message: <3C4DFB40.EB832B3F@yahoo.com.au>
JPGargoyle wrote:
> Great!
> Pretty cool!
> I like it a lot!
> Best regards
Thanks!
Date: 22 Jan 2002 19:13:17
Message: <3C4DFBC3.5C30F5C2@yahoo.com.au>
Thanks! Yes, the door is too wide, but you can't expect perfect geometry from a
10 minute "let's see how this turns out" sort of job.
Date: 22 Jan 2002 19:43:55
Message: <3C4E0781.1C9FDCA5@engineer.com>
For this one area_light D*x, D*z, 5, 5 jitter adaptive 0 would be
enough. I would say that if the nearest object is within 3*fade_distance
and more accurate lighting is needed then divide the source. Try it first
with one source and see what it looks like. cornell.pov in the beta
distribution can be used to see how dividing the source affects the lighting.
The N parameter divides the source to N^2 sub sources. N=3 was mainly
used to get better lighting on the front of the tall box, the rest
of the scene is ok with 1 source. Notice how the light intensity remains
constant even when the source is divided without altering source brightness.
It's because the light source color brightness is actually brightness/area
so when a source is divided to smaller sources they still have the same
area brightness.
> and here are the results.
Looks good and a fortunate coincidence is that the scene contrast
ratio matches nicely that of a typical monitor so no post processing
is needed :)
_____________
Kari Kivisalo
Date: 22 Jan 2002 19:51:08
Message: <3C4E0932.3DDCA768@engineer.com>
>  of their inventor :-)
I would more like them as rayalistic lights :)
_____________
Kari Kivisalo
Date: 22 Jan 2002 20:30:51
Message: <3C4E0DEC.D2900806@yahoo.com.au>
> enough.
I seldom see the easy way first :-) I am still amazed at how much  indoor rad
scenes can benefit from these settings.
> is needed :)
Thank you.
If only POV had the ability to adjust colours before they are clipped and written
to file...
text{ttf"timrom.ttf"concat(#local O=1;#while(O<7)chr(val(substr(concat(#local Q=
1;#while(Q<7)str(asc(substr("???<?>",Q,1))-56,0,0),#local Q=Q+1;#end""),O,2))),#
local O=O+2;#end"").1,0pigment{rgb 9}translate-<1,.3,-2>} // MJL
Date: 23 Jan 2002 03:13:21
Message: <3c4e70a1@news.povray.org>
Drooool!!  Now tell me the render time!
Hugo
Date: 23 Jan 2002 03:58:25
Message: <3c4e7b31@news.povray.org>
  Very good! Seems that Kari is a great inipiration for all us. I'm trying
to finish a macro for this kind of kari-lights, which I started some months
ago inspired by Kari comments.
  I'm also playing with another Kari idea, and that's using spectral data
for the lights. His original idea was to wrap spectrum pictures on a sphere
containing the light. But that was slow, so I searched the net and found an
algoritm to convert a sampled spectrum into rgb, and it seems to work
pretty well for common bulbs spectrums (feven luorescents come out
greeninsh!:). The problem is that I never seem to be even close to finish
the macro: RL is a bit annoying sometimes... hope to have something decent
to show soon.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 23 Jan 2002 12:46:14
Message: <3c4ef6e6@news.povray.org>
If I were you I would report this bug to p.b-t:
"Bug: radiosity artefacts disappeared..."
Great job.
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
Date: 23 Jan 2002 17:21:11
Message: <3C4F32FF.31CABA81@yahoo.com.au>
Render time was ~ 20 min on an 800MHz Athlon. The radiosity settings used were
higher than needed, though.
MJL
> Hugo
Date: 23 Jan 2002 17:27:19
Message: <3C4F346E.97642057@yahoo.com.au>
Jaime Vives Piqueres wrote:
>   Very good!
Thank you!
> for the lights [snip]... hope to have something decent to show soon.
I bet lots of people would use something like this. Good luck with it.
Date: 23 Jan 2002 17:33:55
Message: <3C4F35FA.3FD5F92B@yahoo.com.au>
> Great job.
Thank you. Buggy :-) rad settings were...
radiosity
         pretrace_start 0.01
         pretrace_end   0.005
         recursion_limit 5
         count 300
         error_bound 0.25
         nearest_count 7
         minimum_reuse 0.01
         always_sample off
which I would not like to use in a scene any more complex than this...
Date: 26 Jan 2002 17:25:33
Message: <chrishuff-FDF068.17271326012002@netplex.aussie.org>
In article <3C4E0DEC.D2900806@yahoo.com.au>,
> written to file...
MegaPOV has this ability.
