POV-Ray : Newsgroups : povray.binaries.images : front of a dutch thesis (2) Server Time
26 Jun 2026 12:10:28 EDT (-0400)
  front of a dutch thesis (2) (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: front of a dutch thesis (2)
Date: 2 Jan 2002 01:26:18
Message: <3c32a80a@news.povray.org>
> And as it was mentioned in p.b-t, there is at the moment a way to save the
> output of VM to a file, perhaps you are able to extract the formula (if
> there is any) or method to build the Klein bottle from there?
Maybe I'll just wait until the POV-Ray source is available and then read it.
Interesting, though, Andrel did provide some good reasons why there can't be
one function for it, at least in 3D space. Unless you consider the
intersection of itself with itself to be a "dead end," sort of.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 2 Jan 2002 05:45:35
Message: <3c32e4cf@news.povray.org>
Slime schrieb in Nachricht <3c32a80a@news.povray.org>...
the
it.
It should be in the MegaPov sources, too. They should be still available at
http://nathan.kopp.com/download.htm.
The VM (of course) just calls the internal function 35, so that's of no
help.
Marc-Hendrik
Date: 7 Aug 2011 14:45:00
Message: <web.4e3edc706565a36ae70ca0910@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote:
> Slime schrieb in Nachricht <3c2ffc25@news.povray.org>...
> >Hmm, what's the formula for a klein bottle?
> How about using the f_klein_bottle(x,y,z, P0) in functions.inc as an
> isosurface?
I've tried that one but it gives very strange results:
#include "functions.inc"
light_source { <10,10,10> color White }
camera { location<4,4,4> look_at<0,0,0> }
isosurface {
function { f_klein_bottle(x,y,z,1) }
        accuracy 0.01
        max_gradient 4
        pigment { color rgb <0, 2, 0> }
//      pigment {image_map { jpeg "test.jpg" map_type 1 interpolate 2 filter all
1.0 } }
box { <-5, -2, -5>, <5, -2, 5> pigment { color White } }
The result is:
http://vanheusden.com/pov/surface.png
Doesn't look like the ones on wikipedia
(http://en.wikipedia.org/wiki/Klein_bottle).
Date: 8 Aug 2011 16:52:09
Message: <4e404c79@news.povray.org>
> "Marc-Hendrik Bremer"<Mar### [at] t-onlinede>  wrote:
>> Slime schrieb in Nachricht<3c2ffc25@news.povray.org>...
>> isosurface?
> light_source {<10,10,10>  color White }
> isosurface {
>          accuracy 0.01
>          max_gradient 4
>          pigment { color rgb<0, 2, 0>  }
> 1.0 } }
> box {<-5, -2, -5>,<5, -2, 5>  pigment { color White } }
> The result is:
The default contained_by object is box{-1, 1} and it's to small for that
object.
You need this:
contained_by{box{<-2.88, -2.42, -3.66><2.88, 3.04, 3.66>}}
As small as possible.
The function have a prety high max_gradient: 180 to 2500 depending on
P0, the orientation and camera position.
As it is, the shape can be considered as "fat".
P0 is required but have no apparent effect: same result with values of
0.1, 1 and 10. It DOES affect the max_gradient: large value = high
max_gradient but don't affect rendering time.
Anyway, the bottle from the function don't look the same as the
representation you mention. It's, owever, topologicaly identical.
Date: 12 Aug 2011 14:25:00
Message: <web.4e456f226565a36ae70ca0910@news.povray.org>
[[ klein bottle ]]
> object.
> You need this:
Hmmm, maybe this should be documented somewhere.
Thanks!
Date: 14 Aug 2011 18:50:41
Message: <4E485151.60208@gmail.com>
>> isosurface?
> isosurface {
>          accuracy 0.01
>          max_gradient 4
> 1.0 } }
> The result is:
It is not really an answer, but I should still have the source for the
bottle somewhere in my archive.
Apparently you can afford your own dictator for less than 10 cents per
citizen per day.
Date: 20 Jan 2013 04:35:01
Message: <web.50fbb9b76565a36ab5e07a870@news.povray.org>
Hi there,
I'm trying to build a Klein Bottle too, do you still have the code to make one?
I'm trying hard but the result is still far away from being a satisfying Klein
Bottle!
Thanks,
Paola
Date: 20 Jan 2013 04:55:14
Message: <50fbbf02@news.povray.org>
> Hi there,
> Bottle!
> Thanks,
> Paola
Have a look at Mike Williams tutorials and examples of built in functions.
http://www.econym.demon.co.uk/isotut/builtin3.htm#kb
algbr023.pov is the one you want from the download
Regards
Date: 20 Jan 2013 06:44:01
Message: <50fbd881$1@news.povray.org>
Oh! reduce max_gradient to 2000 or less. 29300 is a bit high.
Regards
Date: 20 Jan 2013 11:59:10
Message: <XnsA14EB6F777B74seed7@news.povray.org>
> - Slime
There's a mesh klein bottle as demo in my mesh macro's
http://code.google.com/p/mmgm/downloads/list
Ingo
