POV-Ray : Newsgroups : povray.binaries.images : Civilization of sorts, or, Fun with crackle Server Time
24 Nov 2026 01:25:29 EST (-0500)
  Civilization of sorts, or, Fun with crackle (Message 1 to 20 of 20)
Subject: Civilization of sorts, or, Fun with crackle
Date: 8 Dec 2001 00:49:43
Message: <3C11AAD2.E059B8F3@faricy.net>
Sort of, not really, based on Incan, Aztec, and Mayan stuff.  Every
object but the cloud pigment on the sky_sphere, which is not discernably
reflected in the brass spheres anyway, uses crackle.  Also my first use
of rad_def.inc in 3.5, and I was quite pleased.
The surface normals got averaged out a bit when I resized it from
1280x960.  The stonework looks less precise than I wanted, but I
increased the beveling in the normal to make the cracks more visible.
Everything looks better at 1280x960.
Comments?
Download 'civilization.jpg' (146 KB)
Preview of image 'civilization.jpg'
Subject: Re: Civilization of sorts, or, Fun with crackle
Date: 8 Dec 2001 03:43:24
Message: <3C11D2C7.80203@ignorancia.org>
David Fontaine wrote:
 > Comments?
Strange but nice... perhaps the sun is too vertical (if there were not
spheres, sun position will be very difficult to understand).
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 8 Dec 2001 04:58:21
Message: <3c11e43d@news.povray.org>
An excellent image with a sense of the ancient - perhaps less perfection,
some ruination? Nice colour and textures.
Mick
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3C1### [at] ignoranciaorg...
>  > Comments?
> La Persistencia de la Ignorancia
Date: 8 Dec 2001 08:23:13
Message: <3c121441@news.povray.org>
I really like this although I agree with Jaime that the sun is too vertical.
Try lowering it towards the horizon and then you should be able to see a
more dramatic effect from the radiosity.
Kev
Date: 8 Dec 2001 08:59:12
Message: <3C121CB0.513C5132@gmx.de>
Really effective, the crackle pattern offers indeed a lot of
possibilities.  Is it a heightfield or an isosurface?
Date: 8 Dec 2001 12:14:07
Message: <3c124a5f@news.povray.org>
Understated, but definately cool!
- Kevin
news:3C11AAD2.E059B8F3@faricy.net...
> Comments?
Date: 8 Dec 2001 23:02:08
Message: <3C12E320.22E49C05@faricy.net>
Jaime Vives Piqueres wrote:
> Strange but nice...
Thanks
perhaps... i might try some different positions.
Date: 8 Dec 2001 23:05:56
Message: <3C12E404.86C22BBD@faricy.net>
Thanks.  More ruination might be difficult though, I might have to go to
an isosurface, and then, the displacement is vertical so it'd be hard to
take chunks out perpendicular to the inclined faces without skewing the
chunks.  If I want to wait years I can always difference two isos.
Date: 8 Dec 2001 23:06:42
Message: <3C12E432.AC2C7685@faricy.net>
Thanks.  I agree, a little more contrast might help it.
Date: 8 Dec 2001 23:07:31
Message: <3C12E463.8D50CBB0@faricy.net>
Height_field.  Isosurface goes much much slower.  :(
Date: 8 Dec 2001 23:08:47
Message: <3C12E4AF.5A130A4@faricy.net>
Thanks!
Date: 12 Dec 2001 20:51:25
Message: <3c180a3a.8577140@localhost>
On Fri, 07 Dec 2001 23:53:22 -0600, David Fontaine <dav### [at] faricynet>
wrote:
>This is a multi-part message in MIME format.
>--------------8A793892BEEF8EA0C9E51442
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
>Comments?
	Freakin cool!
Pete
Date: 13 Dec 2001 00:40:40
Message: <3C18403C.8C676413@faricy.net>
Pet### [at] nymaliasnetalmost wrote:
>         Freakin cool!
Thanks!
Subject: version 2
Date: 13 Dec 2001 01:05:54
Message: <3C184626.AEB03636@faricy.net>
Lowered the sun's position and tweaked the surface normals a bit.  The
blue/yellow contrast from the radiosity is more pronounced now.  Perhaps
a bit dark now though, could be adjusted.
http://davidf.faricy.net/renders/civilization.jpg
(resized from 1152x864)
Subject: Re: version 2
Date: 13 Dec 2001 14:31:11
Message: <3c1901ff@news.povray.org>
news:3C184626.AEB03636@faricy.net...
Much better, but I still think it should be lower. At this angle you get a
bad line diagonally through the center of the image where you can just see
the shadow which is kind of distarcting.
Kev
Date: 13 Dec 2001 19:41:08
Message: <3C194B8A.12E2EFDA@faricy.net>
(mumble mumble groan) Though, perhaps you are right...
Subject: version 3 (final?)
Date: 15 Dec 2001 22:44:34
Message: <3C1C1987.D7BDEEFD@faricy.net>
version 2 was:
http://davidf.faricy.net/renders/civilization_.jpg
I think it's very close to finished now.  Any comments?
Subject: Re: version 3 (final?)
Date: 16 Dec 2001 06:20:02
Message: <3c1c8362@news.povray.org>
news:3C1C1987.D7BDEEFD@faricy.net...
> version 2 was:
The chipped stone looks good.  What occured to me about the vines, or
vegetation, is that there isn't any thick ground cover on the lowest flat
areas.  Guess that could be explained by the predominant places for growth
being only on angled walls.  Would be great if there were a way to get the
smaller walls to have less greenery and the larger ones more.  Not sure if
slope texturing can vary in that way.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
Date: 16 Dec 2001 16:12:43
Message: <3C1D0F22.CD6E5EDB@faricy.net>
I don't think that's possible.  Also, to get better contrast between the
vegetation in the high and low flat areas, I had to make the texture
depend to much on elevation and too little on slope, and couldn't get
realistic contrast between the walls and the flat areas.  I decided this
was an okay compromise.
Maybe I could have a look into combining two vine textures, one more
dependent on elevation and one more on slope.
Date: 17 Dec 2001 09:21:47
Message: <3C1DFEFC.B740FB87@namtar.qub.ac.uk>
Is there any chance I could get a copy of the code for that Christmas
tree in your gallery? I tried to replicate it, but very weird things
started to happen, so I abandoned that pretty fast...
signature{
  "Grey Knight"
  contact{ email "gre### [at] yahoocom" }
  site_of_week{ url "http://enphilistor.users4.50megs.com/" }
