Well that was a waste of 4 days...
POV 3.5 outputs alpha channels by default. Writes to BMP file.
BMP does not support alpha channels. Ok...
Attached is screen capture of what POV's output looks like.
At least "sorry, POV is running a render" is a good excuse
for keeping annoying friends who want to burn CDs off of
your computer ^_^
Tim Cook
Version: 3.12
Looks cool. . .
But what is it?
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3BEEF714.BFEF65CD@scifi-fantasy.com...
> Well that was a waste of 4 days...>> POV 3.5 outputs alpha channels by default. Writes to BMP file.> BMP does not support alpha channels. Ok...>> Attached is screen capture of what POV's output looks like.>> At least "sorry, POV is running a render" is a good excuse> for keeping annoying friends who want to burn CDs off of> your computer ^_^> --> Tim Cook> http://empyrean.scifi-fantasy.com>> -----BEGIN GEEK CODE BLOCK-----> Version: 3.12> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI> D++(---) G(++) e*>++ h+ !r--- !y--> ------END GEEK CODE BLOCK------
Dayv wrote:
> Looks cool. . .> But what is it?
Underwater scientific research station borrowed from a TV show.
Replaced all of its materials with a media that I made, but it's
nowhere NEAR being finished. Not even done with one floor on
the top pod.
Tim Cook
Version: 3.12
Attached is file 1 of 6 of the original from the TV show.
Play 'name that software' if you like.
Tim Cook
Version: 3.12
File 2 of 6. Note the girders of the surface platform in the FG,
which is probably the last thing I'll add.
Tim Cook
Version: 3.12
File 3 of 6. Seems to be a bit of an optical illusion going on here,
since the tube connecting to the pod at right is at a strange angle
compared to the other shots, and doesn't line up with the same
vertical position as its other end, or it might just be an odd
camera angle.
Tim Cook
Version: 3.12
File 6 of 6. Good shot of the light groups used on original.
I also notice I didn't notice the airlocks on the undersides
of the pods in my initial duplication attempt (more clearly
visible in some of the other shots), will probably redesign
them on my version.
Tim Cook
Version: 3.12
Any geek worth his salt should know the first thing to do with POV-Ray on
Windows is set the option to make PNG output the default. :-P
Jon A. Cruz
http://www.geocities.com/joncruz/action.html
> > Well that was a waste of 4 days...> > POV 3.5 outputs alpha channels by default. Writes to BMP file.> BMP does not support alpha channels. Ok...
Couldn't you render another version at really low quality to get the
alpha channel, and then apply it to the original image?
-Xplo
