POV-Ray : Newsgroups : povray.binaries.images : Geo_Trigo Server Time
30 Mar 2026 10:18:32 EDT (-0400)
  Geo_Trigo (Message 1 to 8 of 8)
Subject: Geo_Trigo
Date: 28 Oct 2001 15:29:54
Message: <3BDC69A5.E7C900A8@sympatico.ca>
Here is the final version of the #macro I did last
week;  the smoother keyword is now working properly;
it fact,  it works very well,  and it allows to smooth the
wavy curves... One can adjust the number of waves
from 2 to "a very large number of waves".
Not very usefull,  but worth the effort !
A lot of different Pov trig calculations inside
this macro;  if some of you are interested,  i will
post the code...
Alex P
Download 'us-ascii' (1 KB)
Subject: Re: Geo_Trigo
Date: 28 Oct 2001 19:48:12
Message: <3BDCA7B1.128CA9B3@hotmail.com>
> post the code...
> Alex P
I'm curious how you did it, but I can't think of where I would use it.
Dan Johnson
http://www.geocities.com/zapob
Date: 29 Oct 2001 06:54:14
Message: <3bdd4366$1@news.povray.org>
Isn't it obvious? Look at the lower-right object. Voila! A slinkie! :-)
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
"Dan Johnson" <zap### [at] hotmailcom> wrote in message
news:3BDCA7B1.128CA9B3@hotmail.com...
> > post the code...
> > Alex P
> Dan Johnson
Date: 29 Oct 2001 08:48:26
Message: <3BDD5D40.FD6C8B8D@sympatico.ca>
> Dan Johnson
I know;  there is the main problem!  May be it could be used as
a decorative elements...  More of cartoon elements.
Anyway,  the code will be on binaries.scene-files today.
Look for "Geo_Trigo_Code"
Alex P
Date: 29 Oct 2001 08:50:23
Message: <3BDD5DB7.F55C2AA6@sympatico.ca>
I would have liked to push a bit farter this idea,  but it is very
memory consumming...
Code on binaries.scenes-files    "Geo_Trigo_Code"
Alex P
Date: 29 Oct 2001 14:54:38
Message: <3BDDB3FD.F3A51AA0@gmx.de>
Since you often (although not always) post HTML, could you please adjust
your newsreader not to do this!
Interesting macro idea BTW, i just started to think how you would define
the shape of the stack on the right with an isosurface function, but i
soon decided i don't really want to know...
Subject: Re:html removed
Date: 29 Oct 2001 17:37:38
Message: <3BDDD948.C636015E@sympatico.ca>
I apologize,  I did change it into the preferences now.
Does it works ?
Alex P
Subject: Re: html removed
Date: 29 Oct 2001 17:57:58
Message: <3BDDDEF6.A8E07B94@gmx.de>
> Does it works ?
Yes, this time it does.
