POV-Ray : Newsgroups : povray.binaries.images : erosion structures (77k) Server Time
24 Nov 2026 02:33:41 EST (-0500)
  erosion structures (77k) (Message 1 to 15 of 15)
Subject: erosion structures (77k)
Date: 23 Oct 2001 04:52:48
Message: <3BD52FDF.36E0175B@gmx.de>
Isosurfaces with pigment functions are a really nice thing to play with.
You can spend hours searching for nice structures in the noise...
But in combination with radiosity it is really slow.  I rendered this in
several parts and no more know the exact render time, but it has been
several days in total.
I wonder if adaptive accuracy would be useful for isosurfaces.  As visible
in the near foreground the accuracy value is too high here, but the
horizon part would look all right with even higher values and would be
much faster then.  Of course I could try to split it up in several
objects, but avoiding the gap between is difficult.
Radiosity quality settings are fairly high (error_bound 0.05) but the
structures in the shadow could still profit from better settings.
Download 'lscp_erosion1.jpg' (77 KB)
Preview of image 'lscp_erosion1.jpg'
Subject: Re: erosion structures (77k)
Date: 23 Oct 2001 05:44:37
Message: <3BD53C0F.2063C73F@ignorancia.org>
  Very natural look! I almost feel the erosion. Of course, the scene is
very well composed and lighted, too. A pain the render times...
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 23 Oct 2001 07:13:49
Message: <3bd550ed@news.povray.org>
Wow
I must admit I've stopped playing so much as I used to with pigment function
for the very reason you mentioned - speed. Perhaps I should try again.
MIck
Date: 23 Oct 2001 07:39:19
Message: <3BD556E6.83BB660F@gmx.de>
Thanks very much.
Date: 23 Oct 2001 07:42:26
Message: <3BD557A2.517E829C@gmx.de>
Mick Hazelgrove wrote:
> Wow
Thank you.
If you do the test render at small size without aa and radiosity it's
possible, although some patience is still required.
Date: 23 Oct 2001 10:01:17
Message: <3bd5782d@news.povray.org>
That's an interesting idea... Anyone have any ideas on how to actually do it
or fake it?
Date: 23 Oct 2001 14:00:12
Message: <3bd5b02c@news.povray.org>
Awesome.
The sky is perfect too.
I only have to complain of the foregroung, which looks like it needs better
precision...
Several days with your Athlon?! You must be a very patient person.
p.s. Just curious: how much slower the first half was compared to the second
one?
Jonathan.
"Christoph Hormann" <chr### [at] gmxde> ha scritto nel messaggio
news:3BD52FDF.36E0175B@gmx.de...
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 23 Oct 2001 14:09:04
Message: <3BD5B27D.CEC7F21F@unforgettable.com>
The sky seems unnatural to me, and you're right about the error_bound
and need for accuracy in the foreground, but otherwise this is a great pic.
-Xplo
Date: 23 Oct 2001 14:38:23
Message: <3BD5B91C.B469611B@gmx.de>
JRG wrote:
> Awesome.
Thanks.
> precision...
As said, the accuracy value should have been lower, but that would have
been even slower of course.
> one?
I can't say precisely since i did not take that much care, but in general
in such scenes the horizon part is quite slow in comparison to the rest.
Date: 23 Oct 2001 14:42:39
Message: <3BD5BA1A.414A0366@gmx.de>
> or fake it?
Faking?  I doubt that's possible.
Implementing it will probably have to wait until the final version of
Povray 3.5.  I will surely have a look when the source code is available.
In general i think it's probably not very problematic to vary the accuracy
value.
Date: 23 Oct 2001 14:46:59
Message: <3BD5BB1F.5458D62@gmx.de>
Thanks,
concerning the sky, it is meant to look a little unconventional, but i
have seen a lot of photos with much less natural sky than this.
Date: 24 Oct 2001 20:42:06
Message: <3BD75EFC.778C847F@sympatico.ca>
> Thanks,
> Christoph
I personally feel that here is a very impressive computer generated
image ! The atmosphere seems to be almost perfect;  I mean,  something
serious "stand out" of the pict. We are looking through a very nice and cool
world.
I think this image is a good part of what CGI should be.
 Alex P
Date: 25 Oct 2001 07:26:32
Message: <3bd7f6e8$1@news.povray.org>
That's impressive image!
Have you tried "adaptive max_gradient" technique, which is already
implemented in 3.5 beta?
I think "adaptive accuracy" is not so useful as "adaptive max_gradient",
The below code is an example.
If you render it with accuracy=0.002 instead of 0.0001, you will
see artifacts near the top of small peaks.
On the other hand, if you render it with adaptive max_gradient
(e.g. "evaluate 2, 1.2, 0.9" instead of "max_gradient 5") and with
accuracy=0.0001, the image quality will be much better and the
rendering speed will be comparable or rather faster than the above.
Note that this technique does not guarantee artifact-free image
and requires experiences to determine the "evaluate" parameters.
(So, this should be only for advanced users.)
BTW, have you tried normal function pattern like below
(commented out) for the foreground?   I usually use it in such
cases.
R. Suzuki
//--- the code ------
#version 3.5;
#include "functions.inc"
#declare Radiosity=off;
global_settings {
  assumed_gamma 1.0
  //max_trace_level 25
  #if (Radiosity)
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.04
      count 35
      nearest_count 5
      error_bound 0.05
      recursion_limit 3
      low_error_factor .5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 1
      adc_bailout 0.01/2
#default {
    pigment {rgb 1}
    #if (Radiosity)
      finish {
        ambient 0.0
        diffuse 0.6
        specular 0.3
    #else
      finish {
        ambient 0.1
        diffuse 0.6
        specular 0.3
  location  <0,1.15,-4>
  look_at   <0,0.8,0>
light_source {
  <500,500,-500>
  color rgb <1, 1, 1>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
isosurface {
  function { y+f_noise3d(x/6,0,z/6)*0.5
     +f_noise3d(x*12,y*1,z*12)*0.1
     +f_noise3d(x*56,y*20,z*56)*0.04
     +f_noise3d(x*120,y*20,z*120)*0.01
     +f_noise3d(x*311,y*53,z*311)*0.005
  contained_by { box { <-150,-3,-150>, <150,0,150> } }
  accuracy 0.0001
  max_gradient 5
//  evaluate 2, 1.2, 0.9
      checker
      color rgb <1.0, 0.8, 0.6>
      color rgb <1.0, 0.0, 0.0>
      scale 0.5
/*    normal{ function{
            f_crackle(x*670,y*270,z*670)*0.2}
          slope_map {
          [0 <0, 1>]
          [0.4 <1, 1>]
          [0.65 <1,-1>]
          [1   <0,-1>] }
  translate y*1.3
Date: 25 Oct 2001 08:17:48
Message: <3BD802DF.D85AFB0C@gmx.de>
Thank you!
Hmm, seems i don't understand completely how evaluate works, but i
remember in the past (with megapov) that scenes using 'eval' sometimes
were much faster than with a sufficient max_gradient value.  I will do
some more experiments on that...
NTL, what i meant with adaptive accuracy was adapting it to the distance
from viewpoint.  Of course it could be useful to adapt max_gradient in the
same way.
> cases.
No, but it's an interesting idea, anyway i suppose with 'normal on' in
radiosity this will be quite slow too.
Date: 25 Oct 2001 08:28:17
Message: <3BD80559.44CA7392@gmx.de>
> world.
Thanks, i think one could do quite a lot more with such a scene scene, if
it wasn't that slow.  You could call it somehow 'brute force realism'
since there is really not much apart from the isosurface function and
radiosity.
