POV-Ray : Newsgroups : povray.binaries.images : recursion problems ?? Server Time
18 Oct 2026 12:31:35 EDT (-0400)
  recursion problems ?? (Message 1 to 3 of 3)
Subject: recursion problems ??
Date: 23 Sep 2001 02:33:54
Message: <3BAD8574.A4E4F6B0@earthlink.net>
new to macro, having problems... =[
simple macro to make a spiral out of
spheres...
It does not want to go above 98 max.
recursive level...
Why... ??
Q?
How to get the spiral to extend to
the edge... By means of the macro...
Download 'reck.jpg' (8 KB)
Preview of image 'reck.jpg'
Subject: Re: recursion problems ??
Date: 23 Sep 2001 02:36:46
Message: <3BAD8625.78FDA717@earthlink.net>
Oops =p
the macro:)
#macro Rec (current)     //define macro
sphere { <0,0,0>, 0.75 pigment {rgb
0.5}        //macro component
translate <0,current*0.125,0>
//squash by 0.125
rotate 55*current*z        //wrap the
compact line into spiral
#if(current < Max-1)        //if current
< max recursion
Rec(current+1)        //recursion and
increment
#end        //if
#end        //mcro
> spheres...
> recursive level...
> Why... ??
> Q?
Date: 23 Sep 2001 03:30:51
Message: <xqinXBAi9Yr7Ewpw@econym.demon.co.uk>
>//squash by 0.125
>< max recursion
>increment
>#end        //if
>#end        //mcro
>> spheres...
>> recursive level...
>> Why... ??
That's the limit of recursive macros. You'll have to use a loop instead
of recursion if you want to go further. Something like this:-
#macro Rec (Max)// Parameter is now the number of spheres required
  #local current=0;
  #while (current < Max-1)
    sphere { <0,0,0>, 0.75 pigment {rgb 0.5}
    rotate 55*current*z
    #declare current = current+1;
  #end //while
#end //macro
Rec(300)
Mike Williams
Gentleman of Leisure
