POV-Ray : Newsgroups : povray.binaries.images : egypt (83ko bu) Server Time
13 Jun 2026 09:00:31 EDT (-0400)
  egypt (83ko bu) (Message 11 to 14 of 14)
Subject: Re: egypt (83ko bu)
Date: 18 Jul 2001 08:27:58
Message: <3b5580ce@news.povray.org>
Thanks.
Date: 19 Jul 2001 11:42:32
Message: <3B57004C.A52C377C@gmx.de>
gemelli david wrote:
> This is an egypt scene I made on sunday...statues are viewpoint objects
> I smoothed for a better lighting.
> A little of radiosity and a bright light source.
> The original version is a 1600*1200 picture I did for my windows
> wallpaper. It took 1h10 to render on my poor K6-2 400MHz 128Mo...
> The POV scene is about 29Mo.
Looks good!
Fairly nice use of image maps, the most common problem about those is
their internal lighting interfering with the scene's light sources.  Here
this seems to work quite well.  Do you also use a bump map or is it only
the image map?
How about an area light for the sun?
Date: 19 Jul 2001 12:24:22
Message: <3B5709E7.7040708@xlstudio.com>
> Looks good!
thanks
> the image map?
all is in the image map. For this render, I used the MAX plug-in we are
developping with Paul Blaszczyk. The bump is not implemented yet.
for the same reason as above...the area lights are not yet
implemented...I can do a test by editing the scene by hand...will do it
when my new computer will be in one piece !!
               David
Date: 20 Jul 2001 16:30:15
Message: <3B589553.29C6C1DE@209software.com>
Where is Angelina Jolee?
>             David
Bryan Valencia
Software Development Engineer
