POV-Ray : Newsgroups : povray.binaries.images : water tunnel 3 (70k) Server Time
24 Nov 2026 05:42:05 EST (-0500)
  water tunnel 3 (70k) (Message 1 to 18 of 18)
Subject: water tunnel 3 (70k)
Date: 15 May 2001 03:20:26
Message: <3B00D911.C293782F@gmx.de>
I tried reflection_type 0 this time, reflection_max is reduced to get a
result more similar to the old one, with 1.0 the water in the distance has
a quite too strong sky-like color IMO.
For the stones i now tried a granite pigment function, the scaling of the
stones got changed by this so the gaps are slightly larger now.  Also note
that i reused old photon data form the different geometry so the lighting
probably is quite wrong.
render time was about 65-70 hours, but megapov crashed just some lines
before the end so this is unfinished.
Download 'water_tunnel05.jpg' (70 KB)
Preview of image 'water_tunnel05.jpg'
Subject: Re: water tunnel 3 (70k)
Date: 15 May 2001 05:03:29
Message: <MPG.156b0f43ca5cebd698977a@NEWS.POVRAY.ORG>
In article <3B00D911.C293782F@gmx.de>, Christoph Hormann says...
> Christoph
You have some very subtle effects in this image, like the wetted lower
blocks! I like it a lot, especially the texture of those stones, to me
it looks perfect :)
Regards,  Sander
Date: 15 May 2001 05:07:03
Message: <3B00F1C4.ED36757A@rsp.com.au>
I think it is looking fantastic!
Do you feel it's nearly finished?
Date: 15 May 2001 07:24:28
Message: <3b0111ec$1@news.povray.org>
If you were to present this as a photo to someone who didn't know you
did POV, it would pass without question.
Date: 15 May 2001 07:38:05
Message: <3b01151d@news.povray.org>
Looks perfect!
btw 70 hours ouch, and pov crashing is the last thing you want - weird as it
happened to me the other night as well - tho that might have been the
ambient tempreture knocking my cpu off
PGP Public Key
Date: 15 May 2001 09:11:06
Message: <sja2gtkhf0lj04il2gqmnhpl2qj7a2nn8j@4ax.com>
Looking at this I swear I can hear the echoes of the water lapping against the sides
of the
tunnel. (I can't smell the seaweed though :-)
Great work.
David
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 15 May 2001 09:32:02
Message: <3B01302C.4184CA7F@gmx.de>
> it looks perfect :)
Thanks, i'm still in work on reflection and highlights in the wet parts,
mostly reflections seem too strong in the shadow parts and not enough in
the sun...
Date: 15 May 2001 09:34:45
Message: <3B0130D0.EB351FC6@gmx.de>
Thank you, i still have some things in mind that could be improved, but
i'm not sure if rendering speed will allow it.
Date: 15 May 2001 09:38:34
Message: <3B0131B5.7B0A9817@gmx.de>
"Rick [Kitty5]" wrote:
> Looks perfect!
Thanks.
I'm not sure what's the reason, checking for a reproducible crash is quite
impossible with that rendering times.  I already had similar crashes
before, but not with this scene.  BTW, the computer was running for more
than a week without reboot at that time so it's quite possible that it was
just fed up...
Date: 15 May 2001 09:42:22
Message: <3B013298.F49B85B0@gmx.de>
Not sure about that, the water structure for example seems quite too
regular to me.
Date: 15 May 2001 09:45:26
Message: <3B013350.E5176F89@gmx.de>
of the
> Great work.
> David
Thanks, now that you mention seaweed i remember that i originally planned
to add some plants growing above the tunnel and reaching into view, but
i'm no more sure if that's a good idea...
Date: 15 May 2001 09:53:00
Message: <3B013517.B7C657DD@gmx.de>
Thanks for the comments, but what do you think of the different
reflection?  The previous version should be more realistic in fact, but
i'm not really sure what's better.
BTW, i forgot to mention that i reduced radiosity recursion_limit from 2
to 1 without much loss in quality (maybe it's even better).  This caused a
major speedup, which of course was compensated by the granite function :-(
I gave up the heightfield brick idea for the moment, because the varying
brick size makes this difficult, but i think about adding some
hierarchical bounding for the single brick rows.
Date: 15 May 2001 11:57:20
Message: <3b0151e0$1@news.povray.org>
news:3B013298.F49B85B0@gmx.de...
you
> regular to me.
    Right, but if the observer didn't -suspect- any trickery, it would pass.
They probably wouldn't even notice the regularity and if they did they would
simply wonder at it, not assume that it must be a fake.
    I think that we who do know better are much more discerning than the
average guy and it is helpful to remember that when tweaking an image for
weeks. Another week to get the light on the underside of a leaf that most
people won't even notice may not be worth it...
Date: 15 May 2001 12:29:53
Message: <3B0159D3.F506737E@gmx.de>
If i do a nice color print with some additional blur, graininess and dirt,
you could be fairly right.  More important than technical aspects are
probably the form of presentation and the actual content of the picture
(if the stones were flying...)
I think we also tend to loose objectivity when looking at the same scene
too often - after several 70hour traces you can simply get bored by
certain details...
Date: 15 May 2001 18:16:52
Message: <3B01A9A2.6CED4FAD@faricy.net>
Bill's right, about it passing...
For us discriminating folk, perhaps you should scale the water rmf down
a little bit and add a slight large-scale undulating pattern like bozo
to it.
The stone is great.  Oh, and the plants are a good idea!  ;)
Date: 15 May 2001 19:48:38
Message: <3B01C2BD.B0992104@aol.com>
I feel a real attachment to this image.  I think it's gorgeous.  The reflected
areas do flatten into the same color a bit but I don't think it necessarily
detracts. You might also watch that the texture of the water and the texture
of the stones don't mimic each other too closely.
/jc
Date: 15 May 2001 21:24:09
Message: <3b01d6b9@news.povray.org>
Now all you need is the small raft with the river rats lounging on it whilst
they sail out to sea.
<BG>
Robert J Becraft
aka cas### [at] aolcom
Christoph Hormann <chr### [at] gmxde> wrote in message
news:3B00D911.C293782F@gmx.de...
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 17 May 2001 14:17:53
Message: <slrn9g7l7e.j5f.steve@zero-pps.localdomain>
Stunning work, but we want plants.
  1:57pm  up 104 days, 14:45,  2 users,  load average: 1.00, 1.00, 1.00
