POV-Ray : Newsgroups : povray.binaries.images : water tunnel 3 (70k) Server Time
13 Jun 2026 12:03:49 EDT (-0400)
  water tunnel 3 (70k) (Message 1 to 10 of 18)
Subject: water tunnel 3 (70k)
Date: 15 May 2001 03:20:26
Message: <3B00D911.C293782F@gmx.de>
I tried reflection_type 0 this time, reflection_max is reduced to get a
result more similar to the old one, with 1.0 the water in the distance has
a quite too strong sky-like color IMO.
For the stones i now tried a granite pigment function, the scaling of the
stones got changed by this so the gaps are slightly larger now.  Also note
that i reused old photon data form the different geometry so the lighting
probably is quite wrong.
render time was about 65-70 hours, but megapov crashed just some lines
before the end so this is unfinished.
Download 'water_tunnel05.jpg' (70 KB)
Preview of image 'water_tunnel05.jpg'
Subject: Re: water tunnel 3 (70k)
Date: 15 May 2001 05:03:29
Message: <MPG.156b0f43ca5cebd698977a@NEWS.POVRAY.ORG>
In article <3B00D911.C293782F@gmx.de>, Christoph Hormann says...
> Christoph
You have some very subtle effects in this image, like the wetted lower
blocks! I like it a lot, especially the texture of those stones, to me
it looks perfect :)
Regards,  Sander
Date: 15 May 2001 05:07:03
Message: <3B00F1C4.ED36757A@rsp.com.au>
I think it is looking fantastic!
Do you feel it's nearly finished?
Date: 15 May 2001 07:24:28
Message: <3b0111ec$1@news.povray.org>
If you were to present this as a photo to someone who didn't know you
did POV, it would pass without question.
Date: 15 May 2001 07:38:05
Message: <3b01151d@news.povray.org>
Looks perfect!
btw 70 hours ouch, and pov crashing is the last thing you want - weird as it
happened to me the other night as well - tho that might have been the
ambient tempreture knocking my cpu off
PGP Public Key
Date: 15 May 2001 09:11:06
Message: <sja2gtkhf0lj04il2gqmnhpl2qj7a2nn8j@4ax.com>
Looking at this I swear I can hear the echoes of the water lapping against the sides
of the
tunnel. (I can't smell the seaweed though :-)
Great work.
David
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 15 May 2001 09:32:02
Message: <3B01302C.4184CA7F@gmx.de>
> it looks perfect :)
Thanks, i'm still in work on reflection and highlights in the wet parts,
mostly reflections seem too strong in the shadow parts and not enough in
the sun...
Date: 15 May 2001 09:34:45
Message: <3B0130D0.EB351FC6@gmx.de>
Thank you, i still have some things in mind that could be improved, but
i'm not sure if rendering speed will allow it.
Date: 15 May 2001 09:38:34
Message: <3B0131B5.7B0A9817@gmx.de>
"Rick [Kitty5]" wrote:
> Looks perfect!
Thanks.
I'm not sure what's the reason, checking for a reproducible crash is quite
impossible with that rendering times.  I already had similar crashes
before, but not with this scene.  BTW, the computer was running for more
than a week without reboot at that time so it's quite possible that it was
just fed up...
Date: 15 May 2001 09:42:22
Message: <3B013298.F49B85B0@gmx.de>
Not sure about that, the water structure for example seems quite too
regular to me.
