POV-Ray : Newsgroups : povray.binaries.images : water tunnel 2 (63k) Server Time
18 Oct 2026 21:07:22 EDT (-0400)
  water tunnel 2 (63k) (Message 1 to 22 of 22)
Subject: water tunnel 2 (63k)
Date: 10 May 2001 03:27:23
Message: <3AFA4310.CF61E6E0@gmx.de>
Not sure if this is much improved, but it is much slower now: about 75
hours.  I think i will try to optimize things like using heightfields for
the upper bricks.
I dimmed the light a bit, but it turns out to be quite dark now.
Radiosity quality is even lower than before so the shadow parts look quite
messy.
I really need a faster computer...
Download 'water_tunnel04.jpg' (63 KB)
Preview of image 'water_tunnel04.jpg'
Subject: Re: water tunnel 2 (63k)
Date: 10 May 2001 06:36:59
Message: <slrn9fkpg2.tkh.steve@zero-pps.localdomain>
That looks real good, but up close the surface of
the water looks like concrete that's been moved around
and left to dry.  Something about the sape of it, not
the texture.
 10:30am  up 97 days, 11:17,  2 users,  load average: 1.00, 1.04, 1.06
Date: 10 May 2001 06:43:52
Message: <3afa70e8$1@news.povray.org>
I was going to disagree about it being too dark but I think I know what you
mean.  The sunlit part could be made more intense to match the bright sky,
in that way it might seem to relate to a darkened tunnel better.
I was also thinking that the waters color might do well with a change from
shallow to deep (in the distance).
It is a great rendering.
Bob H.
news:3AFA4310.CF61E6E0@gmx.de...
> the upper bricks.
> messy.
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 10 May 2001 08:40:50
Message: <3afa8c52@news.povray.org>
-- this looks perfect now - really reminds me of riven - but thats probably
because i am playing it like a crazy thing at the moment, so i can finish it
before myst 3 comes out
PGP Public Key
Date: 10 May 2001 09:42:38
Message: <3afa9ace$1@news.povray.org>
Awesome
Christoph Hormann <chr### [at] gmxde> wrote in message
> the upper bricks.
> messy.
> Christoph
Date: 10 May 2001 11:02:44
Message: <3afaad94@news.povray.org>
This looks excellent. I don't know what you're complaining about. If
anything, I would worry about that render time, but it seems to be worth
it... :)
Date: 10 May 2001 11:39:55
Message: <3AFAB67E.99853C22@gmx.de>
> the texture.
I think i know what you mean, for the forground some rounder shapes
different from the sharp ridges of RMF would probably be better.
Date: 10 May 2001 11:49:03
Message: <3AFAB8A6.7C5734A6@gmx.de>
Exactly, the range of contrast in this one is quite low and the brightness
of the shadowed parts much more depends on the fog and other things than
on the light source.
Sounds like a good idea, i am already playing with a darker ground too.
Thanks, having to look at it for >70 hours probably makes it look worse
than it is. :-)
Date: 10 May 2001 11:51:29
Message: <3AFAB939.9693379A@gmx.de>
Thanks,
don't know 'riven', but i rarely know computer games at all, if it really
looks similar, a screenshot would be nice...
Date: 10 May 2001 11:53:25
Message: <3AFAB9AD.486FF527@gmx.de>
Shay wrote:
> Awesome
Thank you.
Date: 10 May 2001 12:00:27
Message: <3AFABB4F.FADC476E@gmx.de>
> it... :)
Thanks,
the main thing i'm complaining about is that i want to change things to
make it look better, but all changes tend to make it much slower - quite a
bad situation.
Date: 10 May 2001 12:06:45
Message: <3afabc95@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> [-- text/plain, encoding 7bit, 17 lines --]
> the upper bricks.
> messy.
Don't we all...
There seems to be a repititive element in the four stones at the waterline
on the left.  Each has the same funky light/dark patch at thenear end.
Looking closes, a similar sort of funkiness is happening on the next row up.
I don't know if it's a trick of the light (heh) or a glitch in your
randomization process, but you might want to play with that a bit.
Other than that, it looks excellent.  The splotchy darness actually works
well for me, as there's reflections from the water.
Geoff
Date: 10 May 2001 13:23:46
Message: <3afacea2@news.povray.org>
quite
> messy.
This looks really really nice..  I love the subtle changes in light on
the tunnel wall, and for me I really like the lighting you've achieved
with this, it looks very natural.  The shadows have a good level of
contrast too.
Steve
Date: 10 May 2001 13:50:37
Message: <3AFAD526.A4538CAD@gmx.de>
> Don't we all...
Ah, finally someone who noticed that, i also saw it when the render was
going on, seems i 'forgot' a random variation of the noise... :-)
Thanks, i agree it looks quite ok, but in a larger render... i probably
should forget about that anyway...
Date: 10 May 2001 13:54:07
Message: <3AFAD5F7.3E8FE018@gmx.de>
sacrofts wrote:
> This looks really really nice..  I love the subtle changes in light on the tunnel
wall, and for me I really like the lighting you've achieved with this, it looks very
natural.  The shadows have a good level of contrast too.
Thanks, but IMO the contrast in a sunlight scene like this should be
higher - if you compare it to the previous renders, i think the difference
is quite obvious.
Date: 10 May 2001 17:41:49
Message: <3afb0b1d$1@news.povray.org>
Beautiful ! I love it! it's photo-realistic...
did you use focal blur?
How did you do the horizon? Fog or media? And for the clouds?
And the rocks, are they isosurfaces or height_fields?
Just trying to learn...
Louis
Date: 10 May 2001 19:11:24
Message: <3AFB2037.F40D064C@comtrade.ee>
Very nice, but IMHO usually sea and sky will have quite the same color
on the horizon.
Date: 11 May 2001 12:25:14
Message: <3afc126a@news.povray.org>
difference
> is quite obvious.
I just found the first version, I see what you mean, but I wouldn't have
noticed the difference without comparing the two.
Steve
Date: 11 May 2001 13:25:56
Message: <3AFC20E3.36D6CA9B@gmx.de>
Thank you.
No, i usually don't like focal blur in outdoor (landscape) pictures.
It's just fog, i would like it more dense, but the foreground does suffer
from that, maybe meadia would be a good idea.
> And for the clouds?
Just a large sphere with bozo.
isosurfaces ('spheres' with granite pigment function)
Date: 11 May 2001 13:46:27
Message: <3AFC25B2.808BA51B@gmx.de>
> on the horizon.
I don't really think so, of course dust can make the horizon line quite
invisible, but i think the color usually differs.
Anyway i use reflection_type 1 and reflection_max 1.0.  I'm not really
satisfied with how the near horizon part looks so maybe i will try some
changes.
Date: 14 May 2001 21:39:33
Message: <3b0088d5@news.povray.org>
The wonderful thing about this image is the "actual transparentness" of the
water: pleasing value-add realism.
> hours.� I think i will try to optimize things like using heightfields for
> the upper bricks.
> messy.
> Christoph
> �[Image]
Date: 17 May 2001 04:20:18
Message: <3B0389E5.229E20FE@gmx.de>
I actually don't really like the under water part that much, it looks too
uniform IMO.  Sadly refractive photons don't work well here as mentioned
before.
