POV-Ray : Newsgroups : povray.binaries.images : water tunnel (3*47k) Server Time
24 Nov 2026 05:46:16 EST (-0500)
  water tunnel (3*47k) (Message 1 to 20 of 20)
Subject: water tunnel (3*47k)
Date: 29 Apr 2001 13:22:27
Message: <3AEC4DE5.818428F7@gmx.de>
This is something i have been working on these days, things turned out to
be very slow again...
The first picture is an early version without photons, but it looks quite
good IMO.  It also took 'only' 16 hours.
The second one was the slowest, 4 hours for the photons (although they are
not much visible), 36 hours in total.
The third one is somehow a combination of the first two, quality settings
for both photons and radiosity were quite low, therefore the upper part
looks quite bad.  It took 24 hours to render.
What's still missing is different coloring of the stones near and under
water.  The versions with photons only have reflective photons, turning
refraction on leads to a visible line here water changes from with to
without photons.
Comments and suggestions welcome as always.
Download 'water_tunnel01.jpg' (47 KB) Download 'water_tunnel02.jpg' (46 KB) Download 'water_tunnel03.jpg' (46 KB)
Preview of image 'water_tunnel01.jpg'
Preview of image 'water_tunnel02.jpg'
Preview of image 'water_tunnel03.jpg'
Subject: Re: water tunnel (3*47k)
Date: 29 Apr 2001 14:58:44
Message: <3AEC65D5.DFAF3B80@qwest.net>
that is very nice.  I'd love to see it animated!
:o)
Some of the best water I've seen in awhile.
Obscure homebrewed graphics utilities and some
pictures:
http://www.users.qwest.net/~dearmad
Date: 29 Apr 2001 19:55:14
Message: <3aeca9e2@news.povray.org>
Hi
Looks very nice, although the bricks could use a little dirtying up at the
water line. I was once trying something very similar yet I went for the cave
option, shame I lost the file.
Kev
http://perso.libertysurf.co.uk/kevin.ellis
Date: 29 Apr 2001 20:39:01
Message: <3aecb425$1@news.povray.org>
very nice work, you have more patience than i :)
PGP Public Key
Date: 29 Apr 2001 21:43:34
Message: <3aecc346@news.povray.org>
I love the water ...
will you share the source ?
thx
Wolfgan
news:3AEC4DE5.818428F7@gmx.de...
> without photons.
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 30 Apr 2001 00:25:30
Message: <3AECE8F3.2E352D7@usb.ve>
To me it's hard to say which image is the best. They are all great!.
I think i'll keep with the last one because of the stones under the
water. However I prefer the water of the first picture and I think you
should keep the row of bricks at the top of the tunnel (2nd image). I
can see you're making some tests with the stone normal. I think the
normal of the second image is better (surely it takes more time to render).
About the color for the stones, at first I thought about green, but I'm
not sure this will do any good for the image. Some white spots
representing salt accumulation could be added but this doesn't solve
your question.
Alberto.
Date: 30 Apr 2001 00:33:34
Message: <3AECE7F3.D7B93BB0@faricy.net>
Hmm, I like the first best... the second one's too grainy.  Maybe smooth the
bricks back a little and keep the photons.
These are awesome!
Date: 30 Apr 2001 02:30:20
Message: <3AED069B.A9310A19@gmx.de>
> :o)
BTW, RMF water would be quite difficult to animate anyway...
Thanks.
Date: 30 Apr 2001 02:33:49
Message: <3AED076D.9DF50F2F@gmx.de>
Kevin Ellis wrote:
> Hi
> water line.
I know, will work on that...
I thought about adding some rocky stuff outside.
Date: 30 Apr 2001 02:34:52
Message: <3AED07AC.CEEAEB0F@gmx.de>
And you have a faster machine than i :-)
Date: 30 Apr 2001 02:43:02
Message: <3AED0996.BBB885D2@gmx.de>
Thank you.
Hmm, the water is in p.t.s-f
the rest is really quite ugly, so i would prefer not to post it :-)
If there are any questions on things feel free to ask.
Date: 30 Apr 2001 02:46:09
Message: <3AED0A50.999C694@gmx.de>
I know, will try making it less strong and larger scale, it's quite
difficult to tweak things if it takes hours to do a simple test render...
> These are awesome!
Thanks!
Date: 30 Apr 2001 02:53:34
Message: <3AED0C0E.E7C46C1D@gmx.de>
Thank you.
I added them because the first version looks too uniform IMO. The 3rd
picture is already a try to combine the first and the second somehow.
> I can see you're making some tests with the stone normal. I think the
Well, it actually is no normal, but real isosurface displacement :-)
The first and third one use normal though.
> your question.
I think i will mostly try to make it wet near the waterline and maybe add
some touch of green algae.
Date: 30 Apr 2001 06:50:32
Message: <3aed4378@news.povray.org>
That water is excellent!
In general I like the third one best, but I think the from of the water in
the first is
even better. There are those flat areas in the third one, which are odd.
For the bricks I would suggest some bigger scaled granite function to break
the regular form.
To bad this stuff renders that slow!
Marc-Hendrik
Date: 30 Apr 2001 21:29:47
Message: <3AEE13CC.EAE92AE7@aol.com>
Remarkable!  I think the first packs the most punch.  The seems wetter if you
will allow.  While the regularity of the stones dones catch attention in the
first version, the following versions don't seem to improve much.  The real
strength seems to be in the simple composition and the convincing suggestion
of texture for the few elements that make up the picture.  I think just a
little more work on the stones would do it.  I have one question...would there
be caustics on the tunnel ceiling?
/jc
Date: 30 Apr 2001 23:07:02
Message: <chrishuff-BA514D.22043430042001@news.povray.org>
In article <3aede572@news.povray.org>, "Kevin Ellis"
<kev### [at] libertysurfcouk> wrote:
> I just looked at the source you gave and you seem to have used colored
> attenuation and realistic exponential attenuation, yet the MegaPov docs
> section 7.2 states 'Colored attenuation does work with this exponential
> attenuation also.'. So it seems that the color of the water is only coming
> from the actual pigment statement.
I'm not sure what you mean by this message...as you mentioned, the docs
say "Colored attenuation does work with this exponential attenuation
also.", and my experience is that this is correct. His scene uses
colored attenuation, so the color of the water comes in part from the
attenuation in the interior, not just the pigment as you said.
Christopher James Huff
Date: 1 May 2001 08:31:56
Message: <3AEEACE3.B913C311@gmx.de>
Thanks!
> the first is
> even better.
They are differently scaled, i thought the waves in the first one were a
bit large, maybe i should make them slightly higher than in the third.
> the regular form.
Hmm, i think i will try to avoid using a pigment function in the
isosurface, otherwise i will soon be no more able to render it...  Anyway
i will make some tests with scaling.
Date: 1 May 2001 08:40:53
Message: <3AEEAEFD.764E9C54@gmx.de>
> will allow.
Thank you,
watering of the stones still has to be done, but i intent to make them
quite dry in the upper parts.
There are in the second and third one, but they are really hardly
visible.  If anyone has suggestions how to improve that...
Date: 1 May 2001 09:06:28
Message: <3aeeb4d4$1@news.povray.org>
Christoph Hormann schrieb in Nachricht <3AEEACE3.B913C311@gmx.de>...
Some scaled noise3d may work as well. But it is often to regular IMO.
Should be fast ...
Marc-Hendrik
Date: 1 May 2001 14:09:27
Message: <3aeefbd7@news.povray.org>
Oops, not sure why but I've always read it as 'does not', my eyes must have
been playing tricks on me and I've read it many times, I wonder why I've had
trouble with fade_color? I just put it down to that it didn't work with the
realistic attenuation, but I must have been doing something wrong, hmmm.
My sincerest apologies.
Kev
