POV-Ray : Newsgroups : povray.binaries.images : Megapov MCP sample (77k) Server Time
23 Oct 2026 22:24:58 EDT (-0400)
  Megapov MCP sample (77k) (Message 1 to 15 of 15)
Subject: Megapov MCP sample (77k)
Date: 4 Mar 2001 11:42:45
Message: <3AA2707C.CC717FC2@gmx.de>
Just a sample scene for the new combination of different patches.  See
things on: http://www.schunter.etc.tu-bs.de/~chris/povcyg.html
and my posting in p.u.p for details.
The cloth was made with Christophe Bouffartigue's Clothray patch (it's
strongly based on the sample scene), the sphere uses a PovMan shader
(based on the one david gemelli posted on 16 Jan 2001) The yellow stuff is
made with Chris Huff's particle system patch.
Download 'mcp01.jpg' (77 KB)
Preview of image 'mcp01.jpg'
Subject: Re: Megapov MCP sample (77k)
Date: 4 Mar 2001 11:50:25
Message: <mes4atchdogfvdbee8sgi823vheem48180@4ax.com>
On Sun, 04 Mar 2001 17:42:36 +0100, Christoph Hormann
>Christoph
I like, probably because it reminds me of my girlfriend eating :-)
(Not quite as bad as this, but she does make a mess.)
_  __                                           __  _
 \/  \ Justin Whitton                          /  \/
_/\__/ mail: jus### [at] rayjayclaracouk \__/\_
 \/  \ web: www.rayjay.clara.co.uk             /  \/
_/\__/\MSN Messenger ID:msn### [at] rayjayclaracouk/\__/\_
Date: 4 Mar 2001 12:48:56
Message: <3AA28014.11A48887@exmail.de>
Looks nice!
looking at the cloth makes me feel a little bit drunk ;-))
best wishes,
Robert
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
Date: 4 Mar 2001 13:11:08
Message: <3AA2853E.E259C4D8@gmx.de>
Robert Günther wrote:
> Looks nice!
Thanks, i forgot to mention that the cloth texture uses the new blur
pattern.
Date: 4 Mar 2001 13:55:22
Message: <Xns905ACADFD9D45seed7@povray.org>
>pattern.
Christoph,
how does the combination object_pattern + blurr_pattern compare to the
proximity_pattern? Speedwise and for turning an object into pattern
usable for an isosurface.
Ingo
Date: 4 Mar 2001 14:05:28
Message: <3AA291F9.3E734EF6@gmx.de>
That's one of the things i was going to check, but i did not yet have time
to do so.  Anyway right now there are only non adaptive blurring methods
implemented and therefore it is quite slow when using a lot of samples.
I already started to write a recursive algorithm only taking additional
samples if the values differ, but i did not yet finish it.
Date: 4 Mar 2001 14:49:37
Message: <chrishuff-436056.14464004032001@news.povray.org>
In article <3AA291F9.3E734EF6@gmx.de>, Christoph Hormann
I had done a pattern blurring patch before, but got stuck trying to
figure out a good way to get smooth blurring without a huge number of
samples. I don't know how suitable it is for isosurfaces, there are
still areas with infinite gradient. I think I can figure out a way to
get smooth blurring, though...
My patch worked differently, it was a pattern modifier, like the
waveform modifiers. I never thought of implementing it as another
pattern...seems like a good idea, especially in the case of block
patterns, which wouldn't be block patterns any more after being blurred.
I would suggest a different keyword, though..."blur_pattern", for
example.
One question: why do you still have the "grad" pattern, which should be
possible with the "warp_pattern" pattern?
Also, I would suggest that "visibility" be a separate pattern...it
doesn't seem to fit in with the object pattern, and would be better off
not being a block pattern. Incorporating distance would be a useful
feature.
Christopher James Huff
Date: 4 Mar 2001 15:20:25
Message: <3AA2A38A.28F03C1C@gmx.de>
That would be interesting, i can't imagine a method right now that would
do this without a lot of samples. Adaptive sampling would help a lot IMO,
esp. woth block patterns, but it's quite difficult to implement.
> example.
I don't like too much typing :-)
Seriously, i think the '_pattern' stuff started with pigment_pattern where
it's a good idea, like for warp_pattern too, but i'm not sure if that
should be continued with all patterns.
It was written before :-)
i will probably check if there is a difference in speed and take it out if
it's negligible.
> feature.
There is already a seperate visibility pattern, but i did not yet include
it in the documentation, because it's quite preliminary.
try:
  visibility {
    object { test_Obj }
    direction z
Right now the effect of the object pattern with visibility can not be
identically achieved with the seperate visibility pattern.
Date: 4 Mar 2001 16:00:20
Message: <chrishuff-25D656.15572204032001@news.povray.org>
In article <3AA2A38A.28F03C1C@gmx.de>, Christoph Hormann
I'll take a look at your source code, and see if I can make it use my
method...and if my method will work. With luck, you will see some sample
images from me soon (and a description of the algorithm, of course). :-)
I think it makes sense in this case...actually, "blurred_pattern" seems
even better. Just plain "blur" seems kind of ambiguous...it doesn't seem
as apparent that the *pattern* is what is being blurred.
Alright...I just downloaded the source code, and will probably integrate
your stuff into MegaPOV+. (it will be the last thing added, though, in
case you release a new version before I complete MP+)
Now *that* has some potential for confusion...
Date: 4 Mar 2001 16:21:27
Message: <3AA2B1D7.1530E613@gmx.de>
All right, since English is not my native language i will not argue that.
Will that be based on Megapov 0.7 ?
Integrating your particle system patch I also saw that some other things
were not yet included in Megapov like the curvature pattern.  What's the
reason?
Yeah :-)
While the 'shadows' in the object pattern with visibility are infinitely
long, the value raises to 1 at the length of the distance vector in the
visibility pattern.
Date: 4 Mar 2001 16:31:58
Message: <Xns905AE56C0E6ECseed7@povray.org>
>> seems even better. Just plain "blur" seems kind of ambiguous...it
>> doesn't seem as apparent that the *pattern* is what is being
>> blurred.
>that.
Should it be a pattern at all? Why not as a method of 'transformation'
like turbulence, maybe even within a warp statement.
pigment{
    	wood
    	warp{ blurr .... }
Ingo
Date: 4 Mar 2001 16:37:25
Message: <chrishuff-C97D7C.16342804032001@news.povray.org>
In article <3AA2B1D7.1530E613@gmx.de>, Christoph Hormann
> > blurred.
I just added it to my code, and realized it takes a pigment, not a
pattern...why is that? It kind of messes up my logic for the name...it
should be "blurred_pigment_pattern". ;-)
I think my first modification will be to change it to use a
pattern...that might speed it up slightly. I can't think of any benefit
to using a pigment...
> > integrate your stuff into MegaPOV+. (it will be the last thing
> > added, though, in case you release a new version before I complete
> > MP+)
Yes.
> reason?
They aren't finished, some of them just don't work.
> Yeah :-)
> visibility pattern.
So the value tends toward 0 as the object gets nearer, and the effect of
an object gets stronger with distance? That doesn't seem right...an
object should have less influence with distance.
Date: 4 Mar 2001 16:49:07
Message: <3AA2B84F.351234C7@gmx.de>
It can be declared, furthermore: just laziness.
Probably better the other way round, in both patterns.  The idea in the
object pattern was shadow -> 0, but that's not that important.
Date: 4 Mar 2001 16:52:11
Message: <3AA2B90B.8851890C@gmx.de>
> pigment{
>         wood
>         warp{ blurr .... }
Since it is no transformation in fact, i'm not sure if that's possible.
Values get changed, in block patterns like checker even totally new values
occur.
Date: 4 Mar 2001 16:56:21
Message: <chrishuff-89DEE8.16532404032001@news.povray.org>
In article <Xns### [at] povrayorg>, ing### [at] homenl (ingo)
This is how my patch worked...however, block patterns, which have a
fixed number of flat areas, might not work as expected when the blurring
returns "in-between" values.
