POV-Ray : Newsgroups : povray.binaries.images : a book Server Time
24 Oct 2026 00:08:05 EDT (-0400)
  a book (Message 1 to 24 of 24)
Subject: a book
Date: 11 Feb 2001 09:17:45
Message: <3A869EF4.19CA765A@usb.ve>
Hi.
It started as an exercise on how to make a book. At the end, this scene
came out.
Alberto
Download 'cuarto.jpg' (61 KB)
Preview of image 'cuarto.jpg'
Subject: Re: a book
Date: 11 Feb 2001 09:31:23
Message: <3a86a23b@news.povray.org>
The lighting is a bit strange. Is it possible, that the lamp shade has the
"no_shadow" applied? I would expect, that the room is darker above the
shadow of that ring. The cup and the candle holder are a bit to shiny and
reflective, I think.
But that all doesn't really matter. It's almost photorealistic! That book
cover looks really good and the table is just ... realistic.
Good work!
Marc-Hendrik
Subject: Re: a book
Date: 11 Feb 2001 10:24:23
Message: <qebd8t8g0g91ncr09dp1ntnihcta1dd84t@4ax.com>
  I agree. Alberto's paper book cover texture is perfect. I can't figure
out what those seed-like objects are in that glass tray, though.
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Subject: Re: a book
Date: 11 Feb 2001 10:32:53
Message: <3a86b0a5$1@news.povray.org>
"Alan Kong" <ako### [at] povrayNO-SPAMorg> wrote in message
How about peanuts, looks a lot like them.
Ambis
Subject: Re: a book
Date: 11 Feb 2001 10:44:54
Message: <3a86b376@news.povray.org>
"AC" <amb### [at] teliacom> wrote in message news:3a86b0a5$1@news.povray.org...
Almond halves?
By the way, what are those other objects reflected in the lamp base?
Very nice picture! Have you tried rendering it with radiosity?
Dave
Subject: Re: a book
Date: 11 Feb 2001 10:58:01
Message: <78dd8tcvu846mvfpa693rjfgffdcqnjclv@4ax.com>
>came out.
An excellent scene - and very appropriate. I am sure the book is real, where can
I get one?
Don't like the shiny floor though and the vase(?) is rather strange and detracts
from the scene.
dav### [at] hamiltonitecom
http://hamiltonite.com/
Subject: Re: a book
Date: 11 Feb 2001 13:08:51
Message: <3A86D4FF.8DE99766@vip.cybercity.dk>
Finally something that raytraces with a bit of realism. Good work! I
wish ALL raytraced pictures were easy to give a real look. It *should*
actually be easy! Everything in reality, looks real. Even the most clean
white ball.
And now, computer speed has reached gigahertz measurements. It's time to
rewrite raytracers to use "real" formulas. Especially for lighting.
Well, maybe a provoking comment... Never mind... I like this picture but
I'm sure it's been a battle to adjust everything for the "real look".
Hugo
Subject: Re: a book
Date: 11 Feb 2001 13:24:07
Message: <3a86d8c7$1@news.povray.org>
First I thought, they were stones of plums, but after a closer look I would
agree with peanuts. A bit too big though, or those "Jumbos".
Marc-Hendrik
AC schrieb in Nachricht <3a86b0a5$1@news.povray.org>...
>Ambis
Subject: SV: a book
Date: 11 Feb 2001 13:44:13
Message: <3a86dd7d$1@news.povray.org>
Nice!
I especially like the peanut-bowl-thing, and the reflections in the lamp.
The table texture is perfect! Wanna share it? ;-)
Peter
http://hertel.no/bigone
Subject: Re: a book
Date: 11 Feb 2001 13:57:38
Message: <3a86e0a2@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:3a86d8c7$1@news.povray.org...
would
Yeah, after looking closer I agree also that they must be peanuts. Almonds
are darker brown with an off-white center.
Subject: Re: a book
Date: 11 Feb 2001 14:13:03
Message: <3A86E43E.247245A2@gmx.de>
That looks good, i really like the finishes of all the objects.  Of course
radiosity would be worth trying for the darker areas.
Subject: Re: a book
Date: 11 Feb 2001 16:42:20
Message: <3A870739.A3C247F9@usb.ve>
> "no_shadow" applied? ...
The light source of the lamp looks like a cone with double_illuminate
modifier. So you are right, there is a no_shadow in effect. But above
this cone I put another semi-transparent cone to make the lampshade cast
a shadow.
Mmhhh, may be. I'll see what can I do.
> Good work!
> Marc-Hendrik
Thank you!
Alberto.
Subject: Re: SV: a book
Date: 11 Feb 2001 16:42:31
Message: <3A87074A.649315E7@usb.ve>
Peter Hertel wrote:
> Nice!
> Peter
Thanks for your comments. Bellow is the table texture but sometimes, a
texture which works fine in a scene doesn't in another.
texture{
	finish{phong 1  reflection .075}
	pigment{wood  color_map{[0 rgb <1, .5, 0>][1 rgb .9*<1, .5, 0>]}
		ramp_wave  scale 5  rotate <0 90 0>
		warp{turbulence .0625  octaves 6  omega 3  lambda .35}
		translate  50/6*z
		warp{repeat 50/3*z offset <75,20,0>}
		translate -50/6*z
texture{
	normal{wood .2
		ramp_wave  scale .5  rotate <0 90 0>
		translate  50/6*z
		translate -50/6*z
	pigment{wood  color_map{[0 rgbf .75*<1,.5,0,1>][1 rgbf 1*<1,.5,0,1>]}
		scallop_wave  scale .5  rotate <0 90 0>
		translate  50/6*z
		translate -50/6*z
Subject: Re: a book
Date: 11 Feb 2001 16:42:43
Message: <3A870755.96B60492@usb.ve>
> would
In mi mind their are peanuts. But I'll make them smaller.
Alberto
Subject: Re: a book
Date: 11 Feb 2001 16:45:21
Message: <3A8707F3.5B048559@usb.ve>
Christoph Hormann wrote:
> That looks good, i really like the finishes of all the objects...
Thank you.
> ... Of course
I did some teste with radiosity but with little succes. I'll start a
final version of the scene and I'll post the results.
Alberto.
Subject: Re: a book
Date: 11 Feb 2001 20:21:20
Message: <3a873a90@news.povray.org>
Very nice!
I'm still trying to guess exactly how you accomplished the "worn" look on
the book cover?
Very nice coffee too.  About the only thing that jumped out at me was the
spoon.  Maybe a bit more metallic looking?
"Alberto" <jac### [at] usbve> wrote in message news:3A869EF4.19CA765A@usb.ve...
> Hi.
> came out.
> Alberto
Subject: Re: a book
Date: 11 Feb 2001 22:15:11
Message: <chrishuff-1AD800.22154011022001@news.povray.org>
In article <3A86D4FF.8DE99766@vip.cybercity.dk>, Hugo
What exactly do you mean? Spectral color calculations instead of RGB
based ones? Physically based BRDF functions? Physically accurate
lighting calculations (polarization, dispersion, diffraction, etc...)?
If you want "correct" results using "real" equations, you will have to
use "real" parameters and settings, and probably a new way of specifying
texture and interior...and the result would not be fast and may not
really be easier to use. And you would also have to find someone with
the knowledge and time to write it all...
As it is, POV can produce extremely realistic looking images, and with a
few additions could be improved further...there isn't any need to use
completely accurate equations everywhere or simulate every lighting
effect. That would just slow things down and get in the way of people
who just want to make "pretty pictures".
Christopher James Huff
Subject: Re: a book
Date: 11 Feb 2001 22:37:40
Message: <3A875A48.B3B347B9@faricy.net>
I like the smooth look. The turbulence in the wood is perfect!
The shade must be pretty thin (or translucent, as it were) because it doesn't
cast much of a shadow. That's my one nitpick.
I really hate the glare on this monitor. I put my hands up to the screen and
the reflections in the lamp just jumped out. They're pretty sweet!
Subject: Re: a book
Date: 12 Feb 2001 00:20:35
Message: <3a8772a3@news.povray.org>
love the ashtry!
> Hi.
> came out.
> Alberto
Subject: Re: a book
Date: 12 Feb 2001 00:21:58
Message: <3a8772f6@news.povray.org>
Those look like almond shells to me!
BR.Saadat
news:qebd8t8g0g91ncr09dp1ntnihcta1dd84t@4ax.com...
Subject: Re: a book
Date: 12 Feb 2001 15:06:19
Message: <3a88423b@news.povray.org>
Fisherman's Friend.
~simenkv.
Subject: Re: a book
Date: 13 Feb 2001 11:30:21
Message: <3a89611d$1@news.povray.org>
Wonderful! I love the finish on the book.
C.J. POV User
PRSG (POV Ray Study Gallery)
http://hyperion.spaceports.com/~povstudy/
mailto:hou### [at] yaoocom
Alberto <jac### [at] usbve> wrote in message news:3A869EF4.19CA765A@usb.ve...
> Hi.
> came out.
> Alberto
Subject: Re: a book
Date: 13 Feb 2001 19:38:24
Message: <3A89D382.9599ACF0@usb.ve>
> C.J. POV User
Thank you.
The book cover texture is an agate normal with a little bit of phong.
Alberto.
Subject: Re: a book
Date: 14 Feb 2001 09:50:42
Message: <3a8a9b42$1@news.povray.org>
Thanks!
C.J. POV User
Alberto <jac### [at] usbve> wrote in message news:3A89D382.9599ACF0@usb.ve...
> > C.J. POV User
> Thank you.
> Alberto.
