POV-Ray : Newsgroups : povray.binaries.images : ocean node v2 (35k bu) Server Time
19 Nov 2025 11:35:36 EST (-0500)
  ocean node v2 (35k bu) (Message 1 to 10 of 18)
Subject: ocean node v2 (35k bu)
Date: 22 Jan 2001 22:17:03
Message: <3A6CF81C.FB2D43C1@rsp.com.au>
(formerly ocean pylon)
Hi folks,
it has come quite a way since last time.
expect to see a craft on top eventually.
and i can't wait to add the barnacles around the water line!
render times- around 3 hrs for each @ about 512x384 (the images have
been resized down)
bye,
benp
Download 'pylon2_bp.jpg' (35 KB)
Preview of image 'pylon2_bp.jpg'
Subject: Re: ocean node v2 (35k bu)
Date: 22 Jan 2001 22:51:01
Message: <3A6CFFE5.322DCF48@tiac.net>
That's coming along nicely. Are you using radiosity?
Phil
Date: 22 Jan 2001 22:54:36
Message: <3A6D00EC.D2F53AEE@rsp.com.au>
ta, and, i sure am!
the settings are something like this-
radiosity{
   pretrace_start 0.08
   pretrace_end 0.001//0.001
   count 100//250//40//150// 250
   nearest_count  10//5
   error_bound 0.03//0.03
   recursion_limit 1//1
   low_error_factor 0.1//.1//.1//0.1
   gray_threshold 0
   minimum_reuse 0.015
   brightness 1.6//1.5//4//3//1.75
   normal on
   media 1//on
   max_sample 2
   adc_bailout 0.01/1
but the nice colours come from a light blue sky sphere and a bright
yellow sun.
Date: 23 Jan 2001 05:30:31
Message: <3a6d5d47@news.povray.org>
That looks so real! Great work!
Marc-Hendrik
Date: 23 Jan 2001 06:18:47
Message: <3a6d6897$1@news.povray.org>
"Ben Paschke" <ben### [at] rspcomau> wrote in message
news:3A6CF81C.FB2D43C1@rsp.com.au...
Wow! Ah shaw do lurv radiosity.... What's going to land on it?
Date: 23 Jan 2001 06:51:24
Message: <3a6d703c$1@news.povray.org>
this is looks so 'real', very good work!!
POV-Ray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 23 Jan 2001 06:51:36
Message: <3A6D709E.4937D8F7@unforgettable.com>
> Hi folks,
Very nice. You might consider roughing up the textures a little, though.
That thing sure does look clean...
-Xplo
Date: 23 Jan 2001 07:28:34
Message: <3A6D78F3.4B1C0A90@gmx.de>
That looks interesting, i wonder why there are no artefacts although count
is only 100.
Have you tried an inside view?
I would also try to increase recursion_limit and at the same time reduce
brightness, that could lead to interesting results,
It would be slower oof course.
Date: 23 Jan 2001 08:10:54
Message: <3a6d82de$1@news.povray.org>
I was going to say the same thing.  Its so clean and smooth that only the
ladder gives any hint that it is big.
Without the ladder I would have guessed some sort of new Braun kitchen
appliance:-)
Nice work.
"Xplo Eristotle" <inq### [at] unforgettablecom> wrote in message
news:3A6D709E.4937D8F7@unforgettable.com...
> > Hi folks,
> -Xplo
Date: 23 Jan 2001 17:58:51
Message: <3A6E0D0E.FC669171@rsp.com.au>
Well, to be honest i haven't yet found decent settings for recursion levels
higher than 1. Basically, i'm happy with the recursion level 1 settings i have
because of the overall balance between quality, speed and response.
But i'd still like to hear any ideas on recursion level 2 settings that people
have had success with.
There are afew artifacts, mainly on the interior central column.
By the way, your radiosity tutes are great!
> is only 100.
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
