POV-Ray : Newsgroups : povray.binaries.images : Spiky plant 2 Server Time
19 Oct 2026 09:18:07 EDT (-0400)
  Spiky plant 2 (Message 1 to 16 of 16)
Subject: Spiky plant 2
Date: 19 Dec 2000 17:11:43
Message: <3A3FDE5F.D2197285@unforgettable.com>
As suggested, I tried making the spikes out of isosurfaces. Took me a
while to figure out how to do it but as you can see, I managed.
-Xplo
Download 'spikemaker-c.jpg' (57 KB)
Preview of image 'spikemaker-c.jpg'
Subject: Re: Spiky plant 2
Date: 19 Dec 2000 19:06:12
Message: <3a3ff7f4$1@news.povray.org>
Glad you did - it looks much better :)
a little GI and you might have it cracked
POVray News & Resources - http://povray.co.uk
Kitty5 WebDesign - http://kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 20 Dec 2000 07:44:45
Message: <3a40a9bd$1@news.povray.org>
Its nice, and resembles an Aloe-vera plant. :)
Need small, hooked spikes on the leaves.
ian
Xplo Eristotle <inq### [at] unforgettablecom> wrote in message
news:3A3FDE5F.D2197285@unforgettable.com...
Date: 20 Dec 2000 08:13:07
Message: <3A40B027.A76B13B0@onwijs.com>
The colours and texture (still) look very good.
Is there any improvement in using isosurfaces?
Remco
> -Xplo
Date: 20 Dec 2000 11:30:54
Message: <3A40E021.B7B95EFD@unforgettable.com>
They allow me to add curvature and random defects. They're a bit slower,
though, so it's a tradeoff.
-Xplo
Date: 20 Dec 2000 14:56:58
Message: <chrishuff-1524FF.14580620122000@news.povray.org>
In article <3a40a9bd$1@news.povray.org>, "ian mcdonald"
There is a strong resemblence to aloe...the only difference is that on
every aloe plant I have seen, the leaves don't "fan out", they are
opposite each other and lined up in a vertical plane, each leaf is
always 180 degrees apart from the previous and the next.
Christopher James Huff
Date: 20 Dec 2000 15:04:54
Message: <3a4110e6$1@news.povray.org>
    That depends on the growing conditions. I have some that grow around the
corner of my house and they are 180 on the west side and 360 on the south
side. I have some who start out 180 and then go 360.
Date: 20 Dec 2000 15:44:59
Message: <chrishuff-44D560.15460720122000@news.povray.org>
In article <3a4110e6$1@news.povray.org>, "Bill DeWitt"
> the corner of my house and they are 180 on the west side and 360 on
> the south side. I have some who start out 180 and then go 360.
With leaves only growing on one side of the plant? Are you sure someone
isn't just using the leaves on the other side? :-)
Funny this came up now...I just had to use some on a bad scalding burn I
got on my hand from some very fresh coffee...
Date: 20 Dec 2000 16:42:25
Message: <3a4127c1$1@news.povray.org>
    No, I was using a short cut I thought you would get... some with leaves
growing 0` and 180`, some growing with leaves pointing all around. I also
seem to remember (it's too cold to go look) that the closer they are
together, the more they grow in just two directions.
Date: 20 Dec 2000 17:05:30
Message: <3A412D28.5793AA71@gmx.de>
> -Xplo
It now looks even better, just put a lot of them on a nice isosurface
landscape, add radiosity, area light, ... and wait a loooooong time till
it's finished. :-)
Date: 20 Dec 2000 17:08:42
Message: <3A412F4C.53A679C9@unforgettable.com>
That's partly from the pigmentation on the insides of the leaves; when I
created it, I was basing it on aloe, and I seem to have nailed it right
on the head.
I have since thought of a scene to add this to, and I'll be striving for
something more yucca-like next time I work on it, but if I get bored
enough, I may try making a more convincing aloe as well. :)
-Xplo
Date: 20 Dec 2000 19:13:11
Message: <3A414C79.212C8991@unforgettable.com>
> it's finished. :-)
There IS radiosity, it's just not terribly precise because of speed and
memory considerations. For that matter, I think I turned the area light
on too. And if it hadn't been taking so damn long, it'd be sitting on a
granite function instead of a plane.. so that's almost three out of
four. Not too bad, eh?
As for using a lot of them.. it's in the cards, but I gotta finish
designing one first. ^^;
-Xplo
Date: 21 Dec 2000 13:11:58
Message: <chrishuff-C4A8DB.13130721122000@news.povray.org>
In article <3a4127c1$1@news.povray.org>, "Bill DeWitt"
> leaves growing 0` and 180`, some growing with leaves pointing all
> around. I also seem to remember (it's too cold to go look) that the
> closer they are together, the more they grow in just two directions.
Oh, I see now...just been programming too much lately...I failed Grammar
II last year, ok? :-)
If you had said y*rand()*360, I would have understood...
Maybe it is just different varieties, my plants are planar no matter
what the growing conditions. I had assumed that all aloe plants were
planar instead of radial...
Date: 21 Dec 2000 13:58:24
Message: <3a4252d0$1@news.povray.org>
    If you get a chance, separate out one small one and put it in a large
pot in the middle of a field. I suspect that if yours gets full sun they
will spread out.
    Do you live in the north?
Date: 21 Dec 2000 14:11:59
Message: <chrishuff-FDFA42.14130821122000@news.povray.org>
In article <3a4252d0$1@news.povray.org>, "Bill DeWitt"
> will spread out.
Depends on where you live, I'm in south Michigan...I had some aloe
planted outside on the south side of the house, and it did pretty
well(after recovering from getting crushed by someone/something), but
didn't spread out. I will try to remember to try this out next summer,
but there may just not be enough light.
Date: 21 Dec 2000 15:38:12
Message: <3a426a34@news.povray.org>
    Everything North of Jacksonville is Yankeeville.
    Unless they get some serious overhead sun I don't imagine Aloe will grow
right for you... I am surprised it will grow at all that close to glaciers.
