Just thought it's about time to start the winter season, the first
christmas trees are also being grown, so here is some fresh snow...
It's written new from scratch in about 1-2 hours, i wonder if there is
already a good snow macro available, but i don't remember anything.
The construction is quite simple, blob compontents positioned by trace
(47000 in total) so a lot of things are not yet very realistic.
Christoph Hormann <chr### [at] gmx de>
Download 'snow_01.jpg' (72 KB)
Preview of image 'snow_01.jpg'
I like this very much!
I can see some imperfections but it's promising to say the least.
Remco
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
> [Image]
There are some regular patterns from the fact that you used a grid to
position the components...maybe a random placement would be better. You
could also use eval_pattern() or eval_pigment() to control the density
of the snow, make it look more uneven on the flat areas.
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
You cheated, you used shaving foam instead.
Steve email mailto:ste### [at] zeropps uklinux net
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
11:44pm up 48 days, 2:07, 2 users, load average: 1.00, 1.01, 1.00
The snow looks thicker than it probably should, but it is very very cool. It
needs icicles. Also, it looks like the snow fell straight down, does your
method allow you to defind a wind direction that would place the snow to one
side of everything?
Josh
> Christoph
> [Image]
In article <3A22FAC1.6BADE805@spiritone.com>, eng### [at] spiritone com
We had a snow that looked exactly like this a couple days ago...all you
need is a damp snow that is constantly drifting straight down, with
little wind and no sun.
Very funny...
> It needs icicles.
Isosurfaces!
> Also, it looks like the snow fell straight down, does your method
> side of everything?
I think he just used the trace() function going straight down from the
sky. Slanting the direction you give trace() should give you something
like that effect.
> Remco
Thank You.
I think foam would probably need a bit less 'heavy' texture.
I don't think completely random would be good, but some 'jitter' could
probably help.
> You
That's a good idea, thanks.
> side of everything?
Just changing the direction would not be that good, because the snow
should much depend on tho slope, so you would have to take the normal
vector into account (right now it isn't used). Usually the snow on the
wind side of objects is thinner and less regular.
icicles would be nice, but they would involve pretty much calculation to
be placed properly.
Chris Huff wrote:
> > It needs icicles.
> Isosurfaces!
Or maybe blobs would also do for that.
> > side of everything?
> like that effect.
As i said in the reply to Josh, that alone would not be that good, at
least variation of the blob component size according to the normal of the
objects would be necessary.
I also think at some places like the 'N' in 'Snow' some 'surrounding
observation' would be necessary to avoid the snow overlapping with the
objects too much (right now i only use one 'trace' per component). Maybe
some components with negative strength could also help there.
Hi Christoph,
That looks very good, I always wondered whether something like that was
possible in pov. Would you mind posting the code?
> Christoph
> [Image]
In article <3A22E208.5E5690EF@gmx.de>, Christoph Hormann
It wasn't designed as a general-purpose macro, but there was aa good
example of making it snow posted to comp.g.r.r a year or so ago. I used
it on the image at http://www.hoboes.com/jerry/Gallery/Christmas.shtml
It's very christmas-card like, so might not be what you want. But I can
dig up the code if you want.
Jerry
"Give a man a fish and you feed him for a day. Teach him to fish, and you've
depleted the lake."--It Isn't Murder If They're Yankees
(http://www.hoboes.com/jerry/Murder/)
Thomas wrote:
> Hi Christoph,
> Regards,
> Thomas
Is in p.t.s-f.
That looks like something completely different, but it would be
interesting anyway.
In article <3A236554.C7F5B018@gmx.de>, Christoph Hormann
> probably help.
I've been getting good results with completely random snow...why do you
think it would be a problem?
I have not tried it yet, but i thought it would need too many blob
components to fill up all holes.
Looks pretty good, but it needs radiosity or something.. snow just
doesn't look right without a ton of skylight in the shadows. ^_-
-Xplo
In article <3A24299D.80382AB5@gmx.de>, Christoph Hormann
Depends...I went as high as 50000 components with no trouble for a
simple scene I am doing, and I am now using 20000. I haven't tried a
grid formation yet.
I think random placement gives better looking results, though a bit
lumpier, right now my biggest problem is getting it not to overhang
edges too much.
In article <3A2369CC.60EF88B6@gmx.de>, Christoph Hormann
> > Isosurfaces!
Probably...you could even use trace() or eval_pattern() with the object
pattern to place them automatically.
Hmm, yes...that is what my snow macro does. I will post a picture soon...
I'm attempting to use 4 additional traces to determine if there is a
sharp edge nearby and avoid placing flakes there. It is actually a bit
similar to the depth-based find_edges post_process filter in concept, I
am about to modify it to use the normal as well.
That's exactly what i started too, but i did not yet have time to work
enough on it (just got a few funny 'melting ice cream' pictures until
now).
Neat! A 10-day photorealistic version with rad and all that would really be
cool...
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
This might be a good use for a perticle system...
