POV-Ray : Newsgroups : povray.binaries.images : The machine Server Time
24 Nov 2026 08:20:40 EST (-0500)
  The machine (Message 1 to 5 of 5)
Subject: The machine
Date: 17 Nov 2000 08:14:54
Message: <3A152F4B.E898035B@enst.fr>
I've been trying to render the damn thing since the end of July, but
it's finally here... If anyone is interrested by a 1152x864 png version
(~1Mo), you can find it here:
http://www.enst.fr/~jberger/images/machine2.png
		Jérôme
********************************* Jérôme M. BERGER
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Download 'machine2.jpg' (65 KB)
Preview of image 'machine2.jpg'
Subject: Re: The machine
Date: 17 Nov 2000 11:39:25
Message: <3A155FAE.2DF64727@interlog.com>
Very cool.
The circuit board type thing on the left hand side in gradient lighted panel, is that
an image map?  It doesn't seem to line up with
the perspective of the panel in that its top edge looks correct but the bottom edge is
pointing at a totally different vanishing
point.  On the other hand I'm making the assumption that it is rectangular with right
angles to begin with.
There seems to be some real thought to the circuit board thingy.  I notice on the back
wall of the image there are three more of
them, all different, and there are none on the right hand side.  Control panels of
some sort?  The brick and stone arrangement is
weird!  The bricks or stones on the back wall seem to be piled up following a curved
surface ... especially where that light is
mounted on the back right hand side.  I guess that light is surface mounted and its a
sphere because it doesn't have and form to it
other than a white hole in the image.
Ahhh .. with a closer look at the full size png image I see that the golden glow for
those panels left and right of the "reactor -
star trek thing" are actually reflections.  The otherwise rusty metal becomes smooth
and polished during reflection.  I wonder is
that a flat surface?  Maybe there is a way to make the same panel surface object with
a large number of patches, each slightly
deviated from the plane of the panel.  If the patches were small enough ( and you had
massive cpu available ) then a realistic
looking and reflecting rusty panel may be the result.  Could be an experiment there.
Is that light or hot fluid in the pipes?  An RGB reactor that supplies light to a
whole society of render artists living like monks
amongst the tunnels of some subterranean tunnels.  Post apocalyptic visions of
rendering monks who live underground and create works
of art with the Light Reactor as the ink source.
Just a thought ...   :)
Dennis
ps: Are the top and bottom of the reactor truncated cones with a CSG subtraction of
cylinders to get the wavy surface?  It doesn't
quite meet the floor.  Is that a floor or sand?
Geez there is a lot going on in this image ...  :)
Date: 18 Nov 2000 07:19:44
Message: <3a1673e0@news.povray.org>
Ooooo....
Thats nice.
May I view the source for it?
ian
Jérôme M. Berger wrote in message <
Date: 20 Nov 2000 11:28:03
Message: <3A19510E.8805B3D@enst.fr>
Dennis Clarke wrote:
> Very cool.
that an image map?  It doesn't seem to line up with
is pointing at a totally different vanishing
right angles to begin with.
back wall of the image there are three more of
some sort?
	Yes, I made a macro to generate random control panels (see attached
sample) then I put several of them on the left of each sidewalk.
a sphere because it doesn't have and form to it
	Brick? Stone? I was going for a "concrete" look! The dark areas are
supposed to be wet stains... The light is indeed surface mounted and a
sphere. Something that might be confusing is the fact that the room is
circular
with a large number of patches, each slightly
had massive cpu available ) then a realistic
	I'm afraid it's more a problem of memory than cpu: as is, the image
required around 90M of RAM to render...
	That was sort of the idea :)
	It's an union of truncated cones
	Mmhh, it's just the same concrete texture as the walls...
		Jérôme
Download 'gauges.jpg' (11 KB)
Preview of image 'gauges.jpg'
Date: 20 Nov 2000 11:35:53
Message: <3A1952E9.12D16EE1@enst.fr>
ian wrote:
> Ooooo....
> Thats nice.
	It's in p.b.s-f
		Jérôme
