![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
David Fontaine wrote:
> There's no such thing as a shade of black.
Yes there is.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Kari Kivisalo wrote:
> Margus Ramst wrote:
> > > http://hammer.prohosting.com/~kkivisal/float3.gif
> > Access forbidden.
> > Does prohosting allow direct downloads?
> Works fine in Netscape 4.7 and IE 3, link or location. New IE users seem
> to be the only ones affected.
I get the same error message in NS 4.72 but the image will display
in IE4. Strange !
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Stare at the center of the circle...
What circle ?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3A160B4A.B9507000@faricy.net>, David Fontaine
<dav### [at] faricy net> wrote:
> Your visual system is sensitive to light ratios. The ratio of intensity
> of adjoining pixels is negligable, so if not seeing the picture as a
> whole you don't see the contrast.
Well, I see a light gray smudge that sometimes for brief "flashes"
develops a small dark spot in the center(the gray around the edges fades
out and the center darkens). I take it that isn't supposed to be what I
see...maybe monitor gamma. :-)
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3A13E633.26328EC4@kivisalo.net>, Kari Kivisalo
<kar### [at] kivisalo net> wrote:
> Another annoying image. Floating orb:
I see a sphere with an unevenly scaled black and yellow checker texture
above/in front of a plane with the same texture rotated 90 degrees. Am I
supposed to see something else?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Eye Puzzle (13+2 KBU) - optical_illusion_33.png [1/1]
Date: 18 Nov 2000 16:04:54
Message: <3A16EE89.AE53DCF8@faricy.net>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
8 a : a color produced by a pigment or dye mixture having some black
in it b : a color slightly different from the one under
consideration
By strictest definition a shade of a color has the same hue and lower
intensity. You can't have a shade of balck.
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> What circle ?
I take it it worked? :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Can too !
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > What circle ?
No. I don't see a circle. I see a hazy blurred grayish area surronded
by a white background but I don't see a circle per se.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Sure ya do, there's lots of 'em. Every set of points which is the same
approximate shade of white is a circle. :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
