POV-Ray : Newsgroups : povray.binaries.images : Down to Earth Server Time
24 Nov 2026 08:27:57 EST (-0500)
  Down to Earth (Message 1 to 26 of 26)
Subject: Down to Earth
Date: 9 Nov 2000 01:58:21
Message: <3A0A4B27.91D4E72E@pacbell.net>
Greeting Povlings,
A little isofun. Render time a whopping 16 min.. Thanks to Tor
for the inspiration and a few pieces or coding examples to work
from.
Ken Tyler
Download 'earthy.jpg' (97 KB)
Preview of image 'earthy.jpg'
Subject: Re: Down to Earth
Date: 9 Nov 2000 09:02:09
Message: <3a0aae61@news.povray.org>
Hey, guys, look! Ken posted something! And it looks cool! I'm marking this
day on my calendar...
Date: 9 Nov 2000 09:37:41
Message: <3A0AB6B5.45A2C929@schunter.etc.tu-bs.de>
Ken wrote:
> Greeting Povlings,
> from.
Oh, please don't tell us your rendering times, we all have to sit hours in front
of a hard working machine for such a thing and you just ... ;-)
Nice picture BTW.
Date: 9 Nov 2000 10:18:40
Message: <3A0AC0B0.34847CC2@pacbell.net>
Christoph Hormann wrote:
> Ken wrote:
> > Greeting Povlings,
> > from.
Should I try it as glass w/photons ?
> Nice picture BTW.
Thanks.
Date: 9 Nov 2000 12:03:13
Message: <3a0ad8d1@news.povray.org>
Most excellent, Ken! I am nearly green with envy!
Grim
Date: 9 Nov 2000 15:22:29
Message: <3A0B0785.1B5283F8@schunter.etc.tu-bs.de>
That would be great, but i suspect it would look somewhat chaotic.
Date: 9 Nov 2000 16:22:07
Message: <chrishuff-4DF25B.16221209112000@news.povray.org>
In article <3A0A4B27.91D4E72E@pacbell.net>, lin### [at] povrayorg
> from.
Journey to the Center of the Earth?
Christopher James Huff
Date: 9 Nov 2000 17:05:01
Message: <3A0B20AE.C5F29438@unforgettable.com>
I wouldn't say so, no.. but some crystals scattered around might look
cool (with dispersion and all that fun stuff).
Of course, you'd have to do actual modeling for that. *horror!*
I wonder what this would look like with radiosity...
-Xplo
Date: 9 Nov 2000 18:13:26
Message: <3a0b2f96@news.povray.org>
"Xplo Eristotle" <inq### [at] unforgettablecom>
 Not necessarily true...
Grim
Date: 9 Nov 2000 18:37:44
Message: <3A0B3567.583E3834@peak.edu.ee>
Ken wrote:
> Greeting Povlings,
"Povlings"?! *snort*
> from.
Interesting stuff, these iso-mazes. Good job on the lighting, gives it depth and
sort of a mysterious feel. Will the source be de-classified?
Margus Ramst
Date: 9 Nov 2000 20:10:38
Message: <3A0B4ABC.C53BBABB@online.no>
Ken wrote:
> Greeting Povlings,
This is not fair !  Now I wish I didn't know your
rendering time for this image. :(
I like the texture. How did you do that ?
I envy your possibilities to explore these worlds.
Tor Olav
mailto:tor### [at] hotmailcom
Date: 9 Nov 2000 22:43:58
Message: <3A0B6EA5.D9B80223@faricy.net>
Looks like some kind of revolting organic microscopy... :)
Date: 12 Nov 2000 00:44:43
Message: <3A0E2EB5.9A8A1553@pacbell.net>
I had a slow-assed P-200 until just a month ago. I feel for you.
I used pretty much the same method you used except I specified
a granite piment pattern and then used multiple colered lights
to give the actual color to the scene.
object {
   Toroid_Noise
      pigment { granite
       color_map {
                   [0.0 rgb .35]
                   [0.5 rgb .50]
                   [.75 rgb .35]
                   [1.0 rgb .75]
                scale .5
      normal { granite .25 scale .35}
  no_shadow
I envy your ability to understand isosurfaces and the math
behind them. I merely took your work and expanded upon it.
Have you tried feeding it a quilted pigment yet ? I have been
getting some interesting results using various slopes in the
pattern.
Date: 12 Nov 2000 00:48:25
Message: <3A0E2F93.C5084A1D@pacbell.net>
Thanks.
I based a good portion of this on Tor's toroidal iso-noise
source posted a while back. I then modified it to make it
my own. Unfortunately the original source for the image I
posted has since gone through serveral revisions and I doubt
I could recreate it if I wanted to. I am having way too much
fun with this stuff ! :)
Date: 13 Nov 2000 00:31:06
Message: <3A0F7C15.69110945@online.no>
> object {
>    Toroid_Noise
>       pigment { granite
>        color_map {
>                    [0.0 rgb .35]
>                    [0.5 rgb .50]
>                    [.75 rgb .35]
>                    [1.0 rgb .75]
>                 scale .5
>   no_shadow
Thank you Ken.
> pattern.
When I saw Greg M. Johnson's Cell city I thought that maybe
it was many pattern types that I hadn't seen yet.
So I browsed through the documentation and found the quilted
pattern, which I had never used before. I did a little test
with this pattern as well, but I was to tired to actual read
the documentation for this pattern. So the results that I got
wasn't what I thought they would be.
But now I'm very interested to see what images came from
your experiments with this pattern.
Tor Olav
Date: 13 Nov 2000 01:14:09
Message: <3A0F871F.C6024E4@pacbell.net>
It was mainly designed for use in normal statements which
coincidentally makes it ideally suited for isosurface work :)
Ooops... I have been trying so many things, and not saving
them, that I really have no working examples to share with
you. Last night I started playing with patterned pigments
and isosufaces. Wheee.....
Date: 13 Nov 2000 01:28:49
Message: <3a0f8a21$1@news.povray.org>
Now, Ken! I did suggest the anal approach after all. Every time you see a
cool result save your source under a new name. :)
Grim
Date: 13 Nov 2000 02:29:33
Message: <3A0F98CC.BC753DBE@pacbell.net>
I have well over 1000 .pov and .inc files because of compulsive file
saving activities over the years. Sometimes it is just fun to throw
caution to the wind and....
Date: 13 Nov 2000 12:01:40
Message: <3a101e74@news.povray.org>
Ahem! Only 1000? I would guess that would make things tidy, but...
I'll do a global search real quick...
Well! I'm shocked! Only 29,987 files. I must be slipping... :)
Grim
Date: 13 Nov 2000 15:23:18
Message: <slrn910j82.499.steve@zero-pps.localdomain>
I bet that that's including the scene examples that come with
all the different versions of pov that you have on your machine:
You Americans just don't know how to count:-/
I get 150 not counting other peoples stuff off NGs and off the web
and not counting all the demos that I've got with various patches
and versions of POV, and not counting any backups.  Before all of
thsi was taken into accout the figure was 939.
  7:34pm  up 33 days, 21:56,  2 users,  load average: 1.10, 1.11, 1.04
Date: 13 Nov 2000 15:43:39
Message: <3a10527b@news.povray.org>
Nope, just my artwork drive. The samples and fellow artists' stuff I keep
with Pov on the primary drive. I lot of those are duplicates with minor
changes, but I have found time to cull irrelevant copies from time-to-time.
I take it that other comment was a dig at our political system. heh, at
least we have something to count. I forget who it was that said, "Democracy
is the worse form of government, except for all the others." Probably
misquoted (sigh).
Grim
Date: 13 Nov 2000 16:42:35
Message: <chrishuff-946428.16424613112000@news.povray.org>
In article <3A0F98CC.BC753DBE@pacbell.net>, lin### [at] povrayorg
I've got 1423 .pov files, including MegaPOV demos, demos for my own
patches, and the official demo scenes. A couple are actually parts of
scenes, a few (especially isosurface files) have several different
things in them that really should be in separate files...
Date: 13 Nov 2000 16:46:41
Message: <3A1061B1.303DD4FB@pacbell.net>
I just got through with a manual recount and the number is now at
3434 - all of which are my own work and does not include example
scene files. I previously failed to count the files that I had
archived in .zip files. If I also included the images I have used
for HF's, bump maps, and image maps the numbers would be much
higher.
Date: 13 Nov 2000 23:24:01
Message: <3a10be61@news.povray.org>
Nope, I'm not gonna recount (even though Ken brought up an excellent point -
archives). (grin)
Grim
Date: 15 Nov 2000 09:06:25
Message: <slrn91427o.b7v.steve@zero-pps.localdomain>
That's some rendering going on there then.
>misquoted (sigh).
  3:12am  up 35 days,  5:35,  2 users,  load average: 2.90, 2.71, 2.38
Date: 17 Nov 2000 01:18:25
Message: <3a14cdb1@news.povray.org>
I've got 965 .pov files on my computer -- that includes all the demos that
came with the versions of POV that I've got, but doesn't include the .inc
files that I've created that are almost complete scenes in their own right.
Mark
