I'm working on the second version of the IsoWood include, here is a preview
scene with some of the things i added.
There is still a lot to do, especially the documentation, so i don't know when
it will be finished.
Comments and suggestions for further additions welcome.
Christoph Hormann <chr### [at] gmx de>
Download 'iw_04.jpg' (88 KB)
Preview of image 'iw_04.jpg'
Hmm, where are the knotholes?
Grim
> Grim
I already made some experiments concerning that problem, but it's difficult,
because the 'classical' inverse black_hole warp technique does not work that
well. The color of the knotholes usually differs from the wood and black_hole
warps are spherical while realistic knotholes should have a more cylindrical
shape pointing away from the center of the wood pattern.
Aye. I've been looking at the new turbulence vector. That, and I believe
something like a spotted map, would get results. In otherwords, a complex
texture would most certainly be required. I have no doubt that warps,
blackholes, (whatever) could benefit diversity in the pattern, but not the
answer in getting the overall effect.
I started off iso woods by trying to recreate the T_Wood series, which I
then proceeded to 'dirty down' with knotholes. I still haven't gotten the
results I want, but I have a ton of projects going too. :)
Attached are 25 T_Woods less the knotholes.
Good luck!
Grim
Download 'TWood_Iso.jpg' (44 KB)
Preview of image 'TWood_Iso.jpg'
In article <3A09C60A.E9CAEBFC@schunter.etc.tu-bs.de>,
> difficult, because the 'classical' inverse black_hole warp technique
> does not work that well. The color of the knotholes usually differs
> from the wood and black_hole warps are spherical while realistic
> knotholes should have a more cylindrical shape pointing away from the
The displace warp could be of use here...or someone could patch the
black hole warp so the "type" keyword actually does something...
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
I already thought of displace warps, although it would not be usable in Povray
3.5.
With a 'type 1' displace warp i could also use the same pattern for the warp and
the different coloring of wood and knothole.
I'm not sure if i understood that right, could you explain it a bit more
detailed ?
I think displace warps are quite a good idea, i also try the black_hole warps
placed at the surface of the wood objects.
You should remember that layered textures can't be used in the IsoWood include.
BTW I already have quite a lot of color_maps and some pigments to be included
with IsoWood 0.2
> detailed ?
> with IsoWood 0.2
Yeah, I ran into this when I was trying to get a good oak texture, including
grains. I ended up doing a pigment map with the same coordinants as the
texture map, then added a texture field to the iso-wood includes. It's not
very general, though, since when tweaking one, you have to tweak the other,
by hand, but the increased effectiveness is worth it. I can now do things
like grains, having the dark wood rougher, while the light wood is smooth
and shiny (this is what the oak in my house is like) rather than just having
the depth be uniform.
If you want to see my tweaks, I can send them to you. I can also post a
picture if what I'm talking about isn't clear.
Geoff
> Geoff
That sounds interesting, i already made some tries with pigment_maps and would
be really interested to see your efforts.
Specifying the function pigment and texture separately is a bit problematic for
some additions i made like the distorted plank in the picture, but i think i
could find a solution.
The main point of my post? I have come to the conclusion that layered
textures are a requisite of wood. It is my observation that some of the new
additions to MegaPov will help us achieve realistic wooden textures and
surfaces. My work continues (very slowly) and I hope you clear away a few of
the problems I ran into initially.
Good luck!
Grim
In article <3A0BA60B.7D837F0C@schunter.etc.tu-bs.de>,
> the warp and the different coloring of wood and knothole.
With another patch that I plan on writing, you could scale a black hole
warp so it is a stretched sphere...
(this patch would simply let you apply transformations to warps)
That sounds interesting, it would also be useful to be able to control the
color of knotholes created with blackhole warps. One could create a
special function pigment for single warps, but it does not work with
repeat and turbulence. I don't know if it's easy to implement, but
something like a warp pigment would be useful.
Well, the other option is a texture map, which has much the same effect, I
admit. I created a very realistic wood grain by combining several wood
grain textures in a wood pattern. It doesn't have knotholes, but it's
pretty nice. I'll see if I can put together a close-up pic and post it.
Geoff
>> Geoff
Well, I finally managed to render the pic, but I can't figure out how to
post it using tin. Anyone out there who can help me?
Geoff
