POV-Ray : Newsgroups : povray.binaries.images : Starting a fresh cockpit - Select.jpg (42k b.u.) Server Time
24 Oct 2026 08:58:32 EDT (-0400)
  Starting a fresh cockpit - Select.jpg (42k b.u.) (Message 1 to 3 of 3)
Subject: Starting a fresh cockpit - Select.jpg (42k b.u.)
Date: 17 Oct 2000 18:56:28
Message: <39ecd91c@news.povray.org>
That about says it all. If I can figure out how to do the lamp (high
blower), the way I have in mind, I'll be happier.
On to the 'stores selector' panel.
Grim
Download 'Select.jpg' (43 KB)
Preview of image 'Select.jpg'
Subject: Re: Starting a fresh cockpit - Select.jpg (42k b.u.)
Date: 18 Oct 2000 04:05:02
Message: <39ED59AE.DA8BBC88@schunter.etc.tu-bs.de>
That looks good, I hope to see it 'built in' soon.
Did you use an image_map or object_pattern with text objects for the text ?
Concerning the lamp, i would suggest a transparent sphere (maybe some
radial/quilted, etc. normal) and emitting media inside.  You could also try a
glow.
Date: 19 Oct 2000 02:27:17
Message: <39ee9445@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:39ED59AE.DA8BBC88@schunter.etc.tu-bs.de...
It won't be real soon. I tend to get distracted and this is a scene I am
inspired to do a lot of detailed texturing for.
As I posted somewhere else, there's a ton of image maps involved with this
plane. The object_pattern function will find its way into my work, but I
didn't feel motivated to edit my work (and don't yet, anyway).
try a
> glow.
What I have so far, is a red tinted egg-shell lens (the High Blower push
button thing is all hollow). I want to put a lightbulb type object inside of
it, with a glowing element. I still haven't 'grokked' media, but I did try
it and wasn't happy. The current glow object was pretty easy to put in, but
I either have a problem with my object, or the glow too easily penetrates
solid objects (I put up a black solid box between a camera and a glow and
you could see the central glow area). Anyway, I wanted to see an open coil
like object glowing with a brilliant output. Like real light bulbs :)
I would post the result, but it doesn't differ much from this one.
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Thanks for replying, Christoph.
Grim
