POV-Ray : Newsgroups : povray.binaries.images : on the right side I use shampoo "TRACE" Server Time
24 Oct 2026 08:59:52 EDT (-0400)
  on the right side I use shampoo "TRACE" (Message 1 to 8 of 8)
Subject: on the right side I use shampoo "TRACE"
Date: 17 Oct 2000 06:14:00
Message: <39ec2668@news.povray.org>
I know that there is similiar stuff
but I want check quality of some idea
this is my first try of universal hair generator
rather fast parsing but long rendering
(15h on Pentium 200MHz without other tasks)
instead random there is something like evenly
but customizable distributed hairs
now I want replace cones with sphere_sweeps
ABX
Download 'shampoo.jpg' (48 KB)
Preview of image 'shampoo.jpg'
Subject: Re: on the right side I use shampoo "TRACE"
Date: 17 Oct 2000 08:20:55
Message: <39EC4450.4FAF931C@enst.fr>
	It looks pretty good, can we see some code please?
	Try replacing them with a few triangles and make the whole thing a
mesh, it should render *much* faster...
		Jérôme
********************************* Jérôme M. BERGER
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 17 Oct 2000 10:00:55
Message: <39ec5b97@news.povray.org>
Jérôme M. Berger wrote in message <39EC4450.4FAF931C@enst.fr>...
#macro HairGenerator(Object,Count,Center,Range,Inside,Height)
  #local InsidePig=pigment{object{Inside color rgb 0 color rgb 1}}
  #local R0=1/sqrt(Count);
  #local way=0;
  #local theta=0;
  #while (theta<pi)
    #local way=way+2*pi*sin(theta);
    #local theta=theta+(pi/Count);
  #local part=way/Count;
  #local theta=pi/Count;
  #local last=0;
  #while (theta<pi)
    #local way=2*pi*sin(theta);
    #local startangle=-2*pi*last/way;
    #local stepangle=2*pi*part/way;
    #local way=way+last;
    #while (way>=part)
      #local way=way-part;
      #local startangle=startangle+stepangle;
      #local
PointInRange=Center+Range*<sin(theta)*cos(startangle),sin(theta)*sin(sta
rtangle),cos(theta)>;
      #local Normal=<0,0,0>;
      #local P0=trace(Object,PointInRange,Center-PointInRange,Normal);
      #if (vlength(Normal)!=0)
        #local P1=eval_pigment(InsidePig,P0);
        #if (P1.x != 0)
          cone { P0 R0 P0+Height*Normal 0 pigment { color rgb 1 } }
    #local last=way;
I plan add such parameters
1. height of hairs as pigment/pattern
2. direction of hairs as pigment/pattern
3. smoothnes of hairs as pigment/pattern
4. color of hairs as pigment/pattern
yes, faster to render but not faster to parse
and I know that it should be faster, but how
interpolate sphere_sweeps to mesh ?
ABX
Date: 18 Oct 2000 08:41:30
Message: <39ED9A79.55546D00@enst.fr>
> #end
	Thank you
	Well faster overall anyway...
	The question here is of course: do you really need the kind of detail a
sphere_sweep would produce? Unless you want to look at your hair from
very near, you'd be better off with a simple mesh...
		Jérôme
Date: 18 Oct 2000 10:31:40
Message: <39edb44c@news.povray.org>
Jérôme M. Berger wrote in message <39ED9A79.55546D00@enst.fr>...
yes, I agree
a
but if I want build universal macro not for single use ?
I want create looking good hairs from near and from far distance
I can code this with some "level of details" but what about animations ?
zoomed face has from far mesh and from near sphere_sweeps ?
what about distortion during changing of LOD ?
sphere_sweeps has bounding therefore outside head area they
are rather fast I think
and I think that it needs less memory
each sphere_sweep need 4 centers and 4 radius
(catmull or b-spline) - 4x3+4=16 float values for one hair
mesh ? I think that I need at least 6 smooth_triangles
with coordinates and normals to simulate one hair
it means 6x(3+3)x3=108 float values
at my posted image I use over 25000 hairs
ABX
p.s. I'am not sure in my calculations, I don't know
what exactly sphsweep.c and mesh.c put in memory
Date: 18 Oct 2000 10:35:48
Message: <39edb544@news.povray.org>
Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote in message
news:39edb44c@news.povray.org...
From my experience, sphere sweeps are VERY slow to render.
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Subject: nd Re: on the right side I use shampoo "TRACE"
Date: 18 Oct 2000 14:47:32
Message: <39EDF002.A4CC2C1F@inapg.inra.fr>
Same here. I always have to bound them manually, otherwise they get the
scene crawling. And the more components they have, the slower then get.
G.
Subject: Re: nd Re: on the right side I use shampoo "TRACE"
Date: 18 Oct 2000 18:40:09
Message: <39EE2427.4513C5C3@faricy.net>
ditto
