POV-Ray : Newsgroups : povray.binaries.images : Moon and Stars! OR..,What have I.... Server Time
24 Oct 2026 17:43:34 EDT (-0400)
  Moon and Stars! OR..,What have I.... (Message 1 to 22 of 22)
Subject: Moon and Stars! OR..,What have I....
Date: 31 Aug 2000 15:42:50
Message: <39aeb53a@news.povray.org>
....done??!!  Heeeeeelp!!!  ;o)
  Sort of hope you like it, any comments? (at all?)
   ~Steve~
Download 'Experment file copy.JPG' (63 KB)
Preview of image 'Experment file copy.JPG'
Subject: Re: Moon and Stars! OR..,What have I....
Date: 31 Aug 2000 18:58:18
Message: <39aee30a@news.povray.org>
Interesting. How did you get the interference patterns?
It's a bit dark, but you knew that. Could it have anything to with the way
you got the interference patterns?
H²
Date: 31 Aug 2000 19:31:44
Message: <slrn8qtnqk.uj3.steve@zero-pps.localdomain>
An interesting variation on the theme.
 11:28pm  up 10 days,  3:46,  2 users,  load average: 1.11, 1.03, 1.01
Date: 1 Sep 2000 01:02:54
Message: <39af387e$1@news.povray.org>
"Halbert" <hha### [at] capitalnet> wrote in message
news:39aee30a@news.povray.org...
> H²
      Hi Halbert, would you believe that the dark part is a sphere? It's
made from Spiral1, and has 2,616,100 'arms'!
  The sphere is scale 9. For some reason, I don't think that it is 'the'
sphere, I think that the camera is either looking 'inside' it now, or it is
a 'shadow' of the sphere. Perhaps someone can enlighten me as to what 'has'
happened?
   For some reason, I couldn't get a light under there, although, obviously,
there is a light there somewhere.
     Playing with this, with high figures for the arms, produced some very
interesting images, this one being one of the best, but if you play with
this, keep the arms between 2,111,000, and 2,700,000. If you keep around
these figures, and then scale the sphere down to 2, 3 or 4, it produces
quite a nice grey 'stony' texture as well.  The 'stars' though, I believe,
are the result of the arms 'intersecting' eachother?
   Glad you like it.     ~Steve~
Date: 1 Sep 2000 01:02:56
Message: <39af3880@news.povray.org>
Thanks Steve, I had quite a good play around with this. The moon was as
close as I could get it using stone texture 13. It sort of looks like one!
     It rendered at 59 seconds. I would have thought that it would be longer
than that, really.
   Glad you like it though,   ~Steve~
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
> Cheers
> Steve              email mailto:ste### [at] zeroppsuklinuxnet
> %HAV-A-NICEDAY Error not enough coffee  0 pps.
> web http://www.zeropps.uklinux.net/
> or  http://start.at/zero-pps
Date: 1 Sep 2000 02:54:33
Message: <39af52a9@news.povray.org>
You forget to use hollow?
Grim
"25ct" <25c### [at] lineonenet> wrote in message news:39aeb53a@news.povray.org...
>    ~Steve~
Date: 1 Sep 2000 03:46:58
Message: <39af5ef2@news.povray.org>
Hi Grim.  I didn't use hollow. What would that do? Would I be more able
to get a light on it then? I think it's the sheer size of the sphere that
won't let the light on it, I may be wrong...
~Steve~
"GrimDude" <vos### [at] yahoocom> wrote in message
news:39af52a9@news.povray.org...
> Grim
> >    ~Steve~
Date: 1 Sep 2000 04:23:11
Message: <39AF67B9.9A6A704C@schunter.etc.tu-bs.de>
> ~Steve~
For 'hollow' just look at Povray docu, if lighting does not work because the
light source is outside and the camera inside, you have to make the large sphere
shadowless.
Date: 1 Sep 2000 04:25:44
Message: <39af6808@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:39AF67B9.9A6A704C@schunter.etc.tu-bs.de...
able
that
> > ~Steve~
the
sphere
> shadowless.
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
     Thanks Christoph, I'll try it now...
   ~Steve~
Date: 1 Sep 2000 04:34:34
Message: <39AF6A19.336E4675@enst.fr>
> happened?
	My bet is that the camera is inside the sphere. If your lights are
outside then of course they won't light anything and all you'll get is
the ambient light. If you want light sources to do something, you should
either put them inside too or make the sphere shadowless or both.
"hollow" won't change anything unless you want to use fog or media.
		Jérôme
******************************* Jérôme M. BERGER
Date: 1 Sep 2000 04:40:44
Message: <39af6b8c@news.povray.org>
able
that
> > ~Steve~
the
sphere
> shadowless.
> Christoph
   Yes, that works. I have my light source on the small sphere now, although
the large sphere has lost the definition of the 'stars'. I also find that I
can't colour the large sphere, is this because Spiral1 is black and white by
default?
   ~Steve~
Date: 1 Sep 2000 04:45:26
Message: <39af6ca6@news.povray.org>
Sorry Jerome, I think we posted close to the same time :o)
    See my reply to Christoph, below.
     ~Steve~
"Jérôme Berger" <Jer### [at] enstfr> wrote in message
news:39AF6A19.336E4675@enst.fr...
is
'has'
> > happened?
> Jérôme
> * Doctor Jekyll had something * mailto:ber### [at] inamecom
> * to Hyde...                  * http://www.enst.fr/~jberger
Date: 1 Sep 2000 05:07:01
Message: <39af71b5@news.povray.org>
Well, for one thing Pov takes longer to render when you have the camera
inside of a non-hollow object? Your image reminded me of a camera inside of
a semi-transparent object.
I hope you work it out. :)
Grim
Date: 1 Sep 2000 06:07:28
Message: <39af7fe0@news.povray.org>
news:39af71b5@news.povray.org...
of
> Grim
    Hi Grim, you're right. The camera is inside the sphere. I had no idea
this could happen. This explains why I couldn't get a light on it, Doh!
   The next image here is just off the surface, with the scale of the sphere
at 4.1331. So this means also that my 'moon' is inside the large sphere!
Cool! :o)
   Quick question about the magnification; Is it possible to use PoV as a
microscope somehow? I've got 2,000,000+ 'arms' or lines on that sphere and
got down to 3 lines. What the magnification is, I shudder to think.....
  ~Steve~
Download 'Experiment file copy2 .JPG' (11 KB)
Preview of image 'Experiment file copy2 .JPG'
Date: 1 Sep 2000 20:22:42
Message: <slrn8r0bnr.s1.steve@zero-pps.localdomain>
>than that, really.
I did a hslf decent moon IMHO in my Halloween scene in the gallery on my
web site, it's a fairly straight forward texture, the source code's on
there aswell if you want to d/l it and have a look.
 11:06pm  up 11 days,  3:24,  2 users,  load average: 1.09, 1.09, 1.05
Date: 2 Sep 2000 03:15:34
Message: <39b0a916@news.povray.org>
Not sure about a microscope (I'm sure you could make on), but you can zoom
by using the camera's direction vector and a multiplier.
Grim
"25ct" <25c### [at] lineonenet> wrote in message news:39af7fe0@news.povray.org...
> of
> > Grim
sphere
> Cool! :o)
>   ~Steve~
Date: 2 Sep 2000 07:53:49
Message: <39b0ea4d$1@news.povray.org>
Cheers Steve, I've just had a look at it, and it's a nice moon, thanks.
About that image, how do you get the light to shine out of the pumpkin and
the other things? Do you actually place a light inside? Nice site by the
way, I still can't get over those screwdrivers :o)
  ~Steve~
as
one!
longer
> >than that, really.
> Cheers
Date: 2 Sep 2000 08:03:43
Message: <39b0ec9f@news.povray.org>
Hi Grim, yes, it was just a thought. I imagined being able to take a
really good photo of say, a bee, and then somehow placing it in PoV and then
zooming in on it until you could see each individual hair on the bee. I just
thought that it would be quite a good way of getting some interesting
textures like this, and maybe using them as backgrounds or something. I
wish!  ;o)
  ~Steve~
news:39b0a916@news.povray.org...
> Grim
camera
inside
> > of
> > > Grim
idea
> sphere
> > Cool! :o)
a
and
> >   ~Steve~
Date: 2 Sep 2000 16:00:27
Message: <39B01C36.1CBFCE25@earthlink.net>
"Disco Days" OR "Some good $%!# Man..."
>    ~Steve~
Date: 2 Sep 2000 18:40:03
Message: <slrn8r2tdv.287.steve@zero-pps.localdomain>
Yes there's a light inside the pumpkin, and the way it shines on the
floor/table just happened by accident so I left it like that, I also
made the inside of the pumpkin a brighter colour than the outside
by colouring the object that hollowed the inside of the pumkin out
a bright yellow, while leaving the outside that orange colour.
So to take the inside out I just did something like:
difference{
           object{Pumpkin_Shape}
                  pigment{Yellow}
                  scale 0.9
           pigment{Orange}
What looks like moonlight isn't actually coming from the moon, that's
just a mostly blue light that I placed behind the cat.
 10:03pm  up 12 days,  2:21,  2 users,  load average: 1.00, 1.00, 1.00
Date: 3 Sep 2000 07:13:57
Message: <39b23275@news.povray.org>
Thanks for that Steve, that's well handy! I'm going to have a play now.
....Ooooh! I love Sundays......   :o)
   ~Steve~
thanks.
and
> difference{
>                   pigment{Yellow}
>                   scale 0.9
>            pigment{Orange}
> Cheers
Date: 3 Sep 2000 07:14:51
Message: <39b232ab$1@news.povray.org>
I think....... good ^&£$@!! man!!
    :o)   ~Steve~
"SomeGuy" <rdm### [at] earthlinknet> wrote in message
news:39B01C36.1CBFCE25@earthlink.net...
> >    ~Steve~
> >  [Image]
