POV-Ray : Newsgroups : povray.binaries.images : More of the same... (~132kau) Server Time
24 Oct 2026 17:43:34 EDT (-0400)
  More of the same... (~132kau) (Message 1 to 20 of 20)
Subject: More of the same... (~132kau)
Date: 28 Aug 2000 09:19:37
Message: <39aa66e9@news.povray.org>
Well, here it is. It took 11 hours to render at 800x800. That isn't quite
accurate, because my father slowed it down by trying to connect to the
Internet and checking e-mail. I was able to intercept him only after Outlook
Express had already opened. Anyway, the radiosity settings are as follows:
global_settings {ini_option "+QR"
 radiosity {
  pretrace_start .08 pretrace_end .001
  count 500 nearest_count 4
  error_bound .05 recursion_limit 1
  low_error_factor .05 gray_threshold 0
  minimum_reuse .015 brightness 1.5
  normal on max_sample 1 adc_bailout 0.01/1}}
I would like it if someone could explain the cause of the splotches under
the elf shoes. Whosoever can figure that out will allow me to test this on a
real scene, instead of on simple objects, which is what I'm itchin' to do.
Oh, BTW, if you must know: I post-processed it, but only to make the
light-gray areas white (you know, I adjusted the curves...). Enjoy.
Download 'arnoldic4.jpg' (93 KB)
Preview of image 'arnoldic4.jpg'
Subject: Re: More of the same... (~132kau)
Date: 28 Aug 2000 09:38:38
Message: <39aa6b5e@news.povray.org>
a
It looks like those shoes are dripping water on the floor :-)
seriously though.. maybe you should try some other patch objects and see if
the same thing happens.
Date: 28 Aug 2000 12:11:49
Message: <39aa8f44@news.povray.org>
Tony[B] <ben### [at] panamac-comnet> wrote:
: global_settings {ini_option "+QR"
:  radiosity {
:   pretrace_start .08 pretrace_end .001
:   count 500 nearest_count 4
:   error_bound .05 recursion_limit 1
:   low_error_factor .05 gray_threshold 0
:   minimum_reuse .015 brightness 1.5
:   normal on max_sample 1 adc_bailout 0.01/1}}
  Your radiosity will look a lot better if you use a recursion_limit higher
than 1.
  You can speed up the radiosity by specifying less-quality settings and
using an area light, but in this case that may be difficult since your
area light is a hemisphere...
Date: 28 Aug 2000 12:16:33
Message: <slrn8ql1pt.n32.steve@zero-pps.localdomain>
Moove the shoes and see if that splotch moves with them, it looks independent
to me.
  4:01pm  up 6 days, 20:19,  2 users,  load average: 1.20, 1.28, 1.25
Date: 28 Aug 2000 13:13:32
Message: <39aa9dbc@news.povray.org>
higher
> than 1.
It gets very bright when I do that. Also, the shadows disappear, IIRC.
Suppose you could add it to POV? :) Or perhaps Chris feels up to it?
Date: 28 Aug 2000 13:14:33
Message: <39aa9df9@news.povray.org>
> Move the shoes and see if that splotch moves with them, it looks
independent
> to me.
Nope, the splotch isn't independant. It only shows up under the shoes. I
will be trying other patch objects, as Ian suggested, to see if the same
problem occurs.
Date: 28 Aug 2000 14:44:38
Message: <39AAB316.7371F1D2@yahoo.com>
> higher
> > than 1.
when you increase your recursion_limit, cut your samples by a little
less than half and it won't come out too bright.  when i did r2d2,
recursion of only one made his white body come out gray.  i have some
questions about your settings.  does error bound 0.05 really matter?  it
seems really small. same question about low_error-factor.  here are my
settings:
radiosity {
    brightness       1.0
    count            100
    error_bound      0.2
    gray_threshold   0.0
    low_error_factor 0.5
    minimum_reuse    0.015
    nearest_count    3
    recursion_limit  2
    pretrace_start .08
    pretrace_end .001
    normal on}
Date: 28 Aug 2000 15:51:28
Message: <chrishuff-E4BF50.14525928082000@news.povray.org>
In article <39aa9dbc@news.povray.org>, "Tony[B]"
Try lowering the diffuse of every texture, and avoid pure white in
non-luminous objects. In reality, there are no perfectly reflective
surfaces, so when you add levels of recursion, the scene brightens. This
can't be compensated for automatically, you have to do it yourself.
As for the shadows...they look neat, but aren't exactly realistic under
those conditions.
Chris who? Me? Or Colefax, Young, Cason, etc...?
Add what to POV? Hemispherical area lights?
I think a more general area light is needed, maybe a parametric of some
sort. It would probably make adaptive sampling impossible or at least
less useful in cases, but could do any sort of sphere sections, cones,
or other shapes. And it would be better than having twenty different
types of area lights.
Of course, the fact that I have no idea how to even start doing this is
a problem...any volunteers?
Christopher James Huff
Date: 28 Aug 2000 18:06:21
Message: <39AAE27A.5B0DBC4F@kivisalo.net>
> surfaces,
Here are some real world reflectances.
      specular aluminum 95%,
      new snow 74%,
      concrete 40%,
      vegetation (mean) 25%,
      asphalt 7%.
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 28 Aug 2000 20:01:24
Message: <39AAFD2F.454AFC4C@yahoo.com>
that's useful.  is there a big list anywhere?
> > surfaces,
>       new snow 74%,
>       concrete 40%,
>       asphalt 7%.
Date: 28 Aug 2000 21:10:19
Message: <39AB0D98.E593B151@kivisalo.net>
I found this list and links  of spectral reflectances. My quess is that
the luminance should be used as pov diffuse value. When using radiosity
these values should be good starting point.
http://www.cs.utah.edu/~bes/graphics/spectra/
Date: 28 Aug 2000 22:49:21
Message: <39ab24b1@news.povray.org>
"Tony[B]" <ben### [at] panamac-comnet> wrote...
a
Try removing any highlighting (phong or specular) from the shoes.  POV's
highlighting sometimes returns values beyond the usual range, which can
cause some number formats to roll over and become negative.  It looks like
you've got some samples gathering negative light in there somewhere.
-Nathan
Date: 29 Aug 2000 00:13:13
Message: <39AB38FB.340F576B@unforgettable.com>
> :  radiosity {
> than 1.
No, it won't. Not for this kind of radiosity.
> using an area light...
...and you can speed up the whole render by just setting a camera and no
objects, but that isn't the point, is it?
-Xplo
Date: 30 Aug 2000 10:36:42
Message: <39ad1bfa@news.povray.org>
Xplo Eristotle <inq### [at] unforgettablecom> wrote:
:>   Your radiosity will look a lot better if you use a recursion_limit higher
:> than 1.
: No, it won't. Not for this kind of radiosity.
  And why not?
: ...and you can speed up the whole render by just setting a camera and no
: objects, but that isn't the point, is it?
  Ah, so there's no point in speeding up radiosity? Well, good to know.
You learn something new every day.
Date: 30 Aug 2000 12:00:31
Message: <39AD2FBE.BA4BD6F0@kivisalo.net>
Warp wrote:
> > [recursion_limit > 1 no good with sky sphere]
>   And why not?
It seems that the rad recursion doesn't stop at diffuse 0 surface.
No need to get light falling on a luminous surface for obvious reason.
Date: 31 Aug 2000 03:21:37
Message: <39ae0781@news.povray.org>
Really nice. Makes me want to spend more time studing radiosity.
Where does the chair come from?  It looks like it could have been
designed by Gerrit Rietveld (Dutch architect circa 1920).
Peter Warren
Proud Povray user since 1996
Date: 31 Aug 2000 12:51:49
Message: <39ae8d25@news.povray.org>
Bingo! I got it from the POV Objects Collection.
Date: 1 Sep 2000 17:05:00
Message: <39B019D8.AF4516D4@xs4all.nl>
Someone did a really horrible paintjob on it 8)
> Peter Warren
Date: 1 Sep 2000 23:00:56
Message: <39b06d68$2@news.povray.org>
Remco de Korte wrote in message <39B019D8.AF4516D4@xs4all.nl>...
Ha. Ha.
That gives me an idea. Write a macro which would 'paint'
a scene a la Mondrian. Which would randomly place colors
with the correct proportions (80% white 7% blue 5% yellow
3% red 5% black).
Gee, I only wish I had the talent!
Peter
Date: 2 Sep 2000 11:35:41
Message: <39b11e4d@news.povray.org>
I've been doing some experimenting, and have narrowed down the problem to
the reflection. It is the reflection on the shoes that causes the problem.
What can I do to have reflection and not have any dots?
